Old 01-26-2011, 12:28 PM
camtd is on a distinguished road
fomat for D and H values
Is there a preferred way to have the H and D values on each line?
Ex.
N320 G43 Z2. H22 M8
N330 G41 D22 X-4.05 Y-.01 (DIA. OFFSET)
Should the D and H be right after the G offset?
Thank You
Old 01-26-2011, 12:33 PM
dcoupar's Avatar
Is this a Fanuc or similar?
If so, the order within the block doesn't matter. Some people even put the D and the H on the same line. As long as the offset number is called prior to the G43 or G41/G42, it should pick it up just fine. I personally like to include the offset number in the same block like you have it.
Old 01-26-2011, 07:11 PM
Yes the controls are Fanuc.
Thank You
Old 01-27-2011, 10:28 AM
maz43's Avatar
maz43 is on a distinguished road
I prefer to put the D in the comp start up line.
need help with I and K values rod88 General Metalwork Discussion 17 06-08-2009 04:06 PM
V8 default values mjp Mastercam 2 01-01-2009 08:22 AM
Problem- - r values minner slinner BobCad-Cam 1 05-05-2008 08:09 PM
Help with integer values clarke200 Fanuc 2 06-26-2007 07:49 AM
Inverting values. jymdman Post Processors for MC 12 03-11-2007 01:32 PM
