| G-Code Programing Discuss G-code programing and problems here! |
| Depending on your control the normal calls are: G70 (Finishing Cycle) G71 (OD or ID turning cycle) G72 (Facing Cycle) Depending on your control the cycles are sometimes different in their build up. Fanuc 6T Cycle Line requires a one line cycle as follows: G71 P1 Q7 D4000 R2.0 U0.5 W0.2 F0.1 G71 - Is the cycle type P1 - is the first profile line sequence number Q7 - is the last prifile line sequence number D4000 - is the depth of cut in microns R2.0 - is the clearance of the X axis when rapid traversing back for the next cut in mm U0.5 - is the amount of material to be left on the OD (X) incremental W0.2 - is the material to be left on the shoulders (Z) incremental F0.1 - is the feed rate (either in mm/rev or mm/min depending on your feed type) On later controls a two line cycle is required as follows: G71 U4.0 R2.0 G71 P1 Q7 F0.1 U0.5 W0.2 LINE 1 G71 - Is the cycle type U4.0 - is the depth of cut in mm R2.0 - is the clearance of the X axis when rapid traversing back for the next cut in mm F0.1 - is the feed rate (either in mm/rev or mm/min depending on your feed type) LINE 2 G71 - Is the cycle type P1 - is the first profile line sequence number Q7 - is the last prifile line sequence number U0.5 - is the amount of material to be left on the OD (X) incremental W0.2 - is the material to be left on the shoulders (Z) incremental Excuse me for being a metric type person. You must first move to your start position eg: Z clearance from the face of you billet and X to the outside diameter of your billet. I might be a bit rusty here as it was a while ago but it is something like this->> ONE LINE CYCLE (Fanuc 6T) Billet diameter is 80mm G0 X80.0 Z2.0 (Start Position before commanding the cycle) G71 P1 Q7 D4000 R2.0 U0.5 W0.2 F0.1 N1 G0 X32.0 N2 G1 Z0.0 N3 G1 X40.0 Z-4.0 N4 G1 Z-30.0 N5 G1 X60.0 Z-60.0 N6 G1 Z-75.0 N7 G1 X80.0 G70 P1 Q7 F0.02 (This line is optional - If you command this line after the roughing cycle it will read sequence number N1 - N7 and do one complete finish profile cut) TWO LINE CYCLE Billet diameter is 80mm G0 X80.0 Z2.0 (Start Position before commanding the cycle) G71 U4.0 R2.0 G71 P1 Q7 F0.1 U0.5 W0.2 N1 G0 X32.0 N2 G1 Z0.0 N3 G1 X40.0 Z-4.0 N4 G1 Z-30.0 N5 G1 X60.0 Z-60.0 N6 G1 Z-75.0 N7 G1 X80.0 G70 P1 Q7 F0.02 (This line is optional - If you command this line after the roughing cycle it will read sequence number N1 - N7 and do one complete finish profile cut) The build up of an ID profile is the same but you start at your drill hole diameter prior to executing the cycle and your R, U and W figures are negitive figures. I hope this helps
__________________ "A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't" Greetings From Down Under Dave Drain Akela Australia Pty. Ltd. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| N1(ROUGH AND FINISH TURN CYCLE) G97 S2500 M13 M98 P1 T0101 G50 S5500 G96 S1000 G0 X.550 Z.050 G71 U.060 R.010 G71 P21 Q22 U.030 W.005 F.008 N21 G0 X0 G1 G99 Z0 F.OO8 X.375 C-.015 F.003 Z-1.250 F.005 N22 X.550 G70 P21 Q22 (Finish cycle) M98P1 M1 M30 |
The post is 5 years old, what is your program look like post it on here.
__________________ The best way to learn is trial error. |
![]() Probably was trying to leave .08 stock boring without the minus sign. ![]() ![]() One of the reasons I don't visit the machining sites very often anymore, is you offer help, and never get a reply. Did it work? Still having a problem? Personally I like to know if my suggestions helped or not. I'm not looking for a pat on the back if they work, I just want to know if they got the job running okay. If my suggestion didn't work, then what did they have to do to get the job running? I like learning myself. It should be a 2-way street. I offer a suggestion. It works. Fine. It doesn't, but you found out what was needed to make it run, then share that information. Maybe I can use it later. |
__________________ tanvon malik http://www.visinia.com (CNC Programming Blog) |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
