Old 01-12-2011, 08:49 AM
andy_trm is on a distinguished road
Smile Help with Arc centers i,j,k
hi,
would it be possible for someone to explain how the g02 & g03 codes work with I,J & K
I am unsure how these are calculated
thanks so much
Old 01-12-2011, 09:00 AM
dcoupar's Avatar
I = X-axis arc center location
J = Y-axis arc center location
K = Z-axis arc center location
Depending on the control, I, J (and K) can either be the absolute coordinates of the arc center, or as in Fanuc, Yasnac, Haas, Mitsubishi, etc. I, J (and K) are the distance and direction from the start-point of the arc to the center.
Old 01-12-2011, 09:03 AM
Perfect Circle's Avatar
Perfect Circle is on a distinguished road
Here is some info
Go to Page 235
CNC programming handbook: a ... - Google Books
Old 01-12-2011, 10:05 AM
dcoupar's Avatar
Here's an example for Fanuc.
Note that you can also specify the radius using R instead of the arc-center. So either of the following would work:
G03 X-1.3991 Y-0.3897 I-0.5433 J-0.8792
-or-
G03 X-1.3991 Y-0.3897 R1.0336
There are a couple of limitations when using R:
1. If the arc is 180 degrees or less, specify R
2. If the arc is greater than 180 degress, specify R-
3. If it's a full circle, you must use I and/or J.
Name:	Fanuc Arc-Center Example.jpg‎
Hurco Turning Centers AA17351 Product Announcements & Manufacturer News 1 07-21-2010 11:58 PM
The Big Machining Centers DeusExMachina Benchtop Machines 16 06-18-2009 07:36 AM
Live Centers vs. Dead Centers? I'm Confused JWB_Machining General Metalwork Discussion 11 04-03-2009 09:45 PM
Monarch machining centers HuFlungDung General Metal Working Machines 15 02-23-2009 09:57 PM
Live Centers peter@slater General Metalwork Discussion 4 11-26-2008 03:18 PM
