Results 1 to 4 of 4
Thread: APT_CL-Has anyone used APT in this century?
    Sep 2007
    I need help in understanding APT-CL.
    Recently I have gained the responsibility to program an operation that uses APT. At first it was a bit daunting; I thought it was archaic, but after I dug into it I discovered how practical it is.
    Although I am picking it up, if anyone could give me a little insight about the post process, tables and processes I would greatly appreciate it.
    Registered BobWarfield's Avatar
    May 2005
    Rapid, I don't have a huge amount of info for you. What I can tell you is that APT is a representation of the internal geometry created by the CAM program. Most CAM directly processes APT or the internal geometry data structures when it shows you a simulation. This is why a lot of folks find g-code driven simulators useful--they find problems your CAM simulator won't.
    There are generic post processors and other utilities out there that can process APT. I think Vericut will process APT, though not totally sure of that.
    It's pretty cool to access the geometry directly on CAM that supports APT. Not really archaic, it is just incomplete compared to g-code because CAM only needs a subset of the g-code.
    Cheers,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
    Apr 2008
    Is this any help?
    APT360 Programmers Manual
    http://ied.unipr.it/silve/meaz/origini-APT.pdf
    There's a guy on here, Dan Falck, that can probably tell you just about anything you want to know about APT
    Jan 2011
    Oh My, I used APT in the last Century, both APT and ADAPT. As I recall
    the CL data is rather sstraightforward, with distinct codes arranged with XYZ coord data.
    You would need a CL data format guide, and with that you could process the CLDATA
    with your choice of programming language (C++ VB). I don't know of any current OTS
    packages that can deal wih the CLDATA, but there's so much out there...
    The CLDATA by default was created in a binary file, but there is a switch (CL read?) that
    output CLDATA in an ASCII file.
    (GO LEFT Line 1, Go right Line 2)
  1. Need Help!- GE Mark Century 2000 Manual
    By RDMoore in forum G-Code Programing
    Last Post: 02-16-2010, 05:57 PM
  2. Bringing the Art of Scraping into the 21st Century?
    By Oldmanandhistoy in forum Linear and Rotary Motion
    Last Post: 12-23-2009, 02:32 PM
  3. Need Help!- GE Century 2000 Controler
    By TheLinkster in forum Controller & Computer Solutions
    Last Post: 10-26-2009, 10:15 AM
  4. Mark Century 2000 Dnc Problem
    By ozgurm in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 02-18-2009, 12:22 AM
  5. Century 82050 Question
    By meerkatguy in forum General Waterjet
    Last Post: 11-15-2006, 03:41 PM
