Old 12-29-2010, 11:47 AM
yaji63 is on a distinguished road
Question Auto copying NC code to various Z levels
does anyone know of any application which can copy NC code generated for one particular Z level to be copied into different Z levels automatically without me having to do it manually in notepad (which i do now) ? I do not want to use program nesting or program repeat and i want all the Z levels in one single program.
Old 12-29-2010, 03:11 PM
angelw is on a distinguished road
Originally Posted by yaji63 View Post
An Editor/Comms package that I wrote has that feature. You specify the start and finish block that you want to copy, the Z level increment for each copy, and the total Z depth. The routine copies the code using the Z level increment. If the full depth is not evenly divisible by the Z increment, the last Z level is at full depth.
If the control you're using the code with has the User Macro option, Fanuc, Yasnac and Haas all use a similar syntax and the following code can be modified to suite and will result in a program that will keep repeating X,Y code at various Z levels until down to full depth.
Regards.
Bill
#1=0 (Z cut in variable - initial value of Z start level)
#2=-5.0 (Cut in amount each Z level)
#3=-23.0 (Full depth)
N10 #1 = #1 + #2
IF [#1 LT #3] TH #1 = #3
G01 Z#1 F100
X300.0 F500
Y200.0
etc
IF [#1 GT #3] GOTO10
Remainder of program
Old 12-29-2010, 10:55 PM
Smile
I do not want to use custom macro in this case and hence this requirement. What Editor/Comms package are you talking about which can do this job ?
[QUOTE=angelw;870794]An Editor/Comms package that I wrote has that feature. You specify the start and finish block that you want to copy, the Z level increment for each copy, and the total Z depth. The routine copies the code using the Z level increment. If the full depth is not evenly divisible by the Z increment, the last Z level is at full depth.
Old 12-30-2010, 12:31 AM
Send me your email address via PM and I'll send you details.
Regards,
Bill
Old 12-31-2010, 04:55 AM
Attached are a few screen images of my Editor/Comms package.
Editor1.zip
Pictures Z Level1 through to Z Level4 shows the sequence to copy code to various Z levels and is as follows:
1. Highlight code to be copied. (Z Level1 picture)
2. Select Level Repeat from the Tool Bar Menu. Z Level Calculator form will appear (Z Level2 picture)
3. Complete the various Text Box inputs and Mouse Click Calculate and the expanded Z Levels will be displayed in the main Text Box (Z Level3 picture)
4. When satisfied, Mouse Click Paste + Exit. The Code in the Z Level Calculator form will be copied to the main Editor Window (Z Level4 picture)
Picture DNC1 is a general view of the Editor during a DNC (Drip Feed) session. The cursor keeps pace with the code being currently executed by the machine tool and indicates the next block.
Regards,
Bill
Auto Tool Zero VBA Code gives Syntax Error kiltjim Mach Wizards, Macros, & Addons 2 02-02-2009 05:32 PM
Need Help!- Copying Blocks billiards HURCO 4 10-26-2008 05:58 PM
Auto cad 3d draw to g-code jorgeneo560 Autodesk Software (Autocad, Inventor etc) 5 08-03-2008 12:27 AM
Dongle copying JR1050 General CAM Discussion 23 12-27-2007 11:32 AM
When I hit "Cut Auto" the code generates seanreit BobCad-Cam 0 11-27-2007 07:05 PM
