Old 12-17-2010, 05:38 AM
moghul is on a distinguished road
TOOL CHANGER MACRO ENTERING IN FANUC OM
HI ALL
I HAVE MACHINE WITH FANUC OM Control. i was lost its all parameters . when i re enter all parameters its work fully but tool changer command M6 is not working . machine has an error on m6 alarm ps86 .
how can i enter tool changer macro in machine?
manualy tool changer is in full working with some commands m19.m21,m22 nad some others but not works automaticly.
help me in this problem.
thanks
shabbir
moghul40@yahoo.com
Old 12-17-2010, 05:54 AM
Green Button is on a distinguished road
Here good instructions, which i found few years ago.
1. Put the machine in MDI mode
2. Hit "Para/Diagn" button and find PWE. The "Para/diagn" button is right under the "Position" button. (para meaning parameter)Make sure your not in Diag, you need to be in Parameters.
3. You need to turn "PWE=1" I believe it's one page up once you hit para button to find PWE. You'll get an Alarm as soon at you turn PWE on, but it's ok.
4. Then change parameter 10 bit 4 to unprotect the 9000 series programs.
(note this bit could be in different place, its marked NE9)
5. While you have the programs unprotected, back them up!!!
6. Once the programs are unprotected , y have to make that toolchange programs and put in correct number. Y will find somewhere whas the prg number.
Program should be something like this (this is not correct, look from manuals)
G00G30X0.Y0.Z0. (tool change position)
M19(spindle orientation)
pot down
unclamp
tool arm rotate to grap tools
tool arm down
tool arm rotate
tool arm up
clamp
toolarm rotate to neutral
pot up
7. Put parameter 10.4 back to where it was and turn off the PWE
Old 12-17-2010, 10:31 AM
stevo1 is on a distinguished road
PS86 is an alarm when trying to communicate with the machine via RS232. So I am confused on when you are getting the alarm. When trying to load the macro program? You make it sound like you are getting the alarm when programming an M6.
Do you have the original macro program from the machine?
Stevo
Old 12-18-2010, 05:26 AM
when i send a program witch have M6 command then ps86 occur. if m6 is not in program then all is ok and machine is running normal.thanks all
i will try with parameter 10 and in book tool change macro is progrm o9003.
thanks
shabbir
Old 12-20-2010, 07:57 AM
So IOW you don’t have a tool change macro in the machine memory and when you try to load it from a PC it alarms out with PS86? And anytime you run a program in the control and it sees an M6 the control alarms out with a different alarm?
Can you tell me the settings of the following parameters? 220 thru 229, 230 thru 239 and 240-242
I reread your post and what I am now getting out of it is if you are sending a program via RS232 from a PC to the control it will alarm out with PS86 if there is a M6 inside the program but if you send a program that does not have a M6 then it will load the whole program with no alarm??
Stevo
Old 12-20-2010, 08:28 AM
yours_prabhat is on a distinguished road
Smile PRABHAT MISHRA
PLEASE CHECK PARAMETER NUMBER 230 TO 236 SOME WHERE YOU HAVE WRITTEN IS 6 THAT MUST BE 0 I WILL LET YOU KNOW THE EXACT PARAM NUMBER TOMORROW
REGARDS
Old 12-20-2010, 08:30 AM
LightToolSupply is on a distinguished road
There is a great book I sell called Fanuc CNC Custom Macros that might be helpful.
Fanuc CNC Custom Macros: Training & Reference Books: Light Tool Supply
# Offers many practical do's and don'ts while covering all the popular Fanuc control systems exclusively.
# Provides the basis for exploring in great depth the extremely wide and rich field of programming tools that macros are.
# Numerous examples and sample programs are used throughout that serve as practical applications of the techniques presented and as the basis of ready-to-run macro programs.
# Includes a CD containing all of the sample programs.
Thank you,
Michael Elson
Light Tool Supply
Precision Tools, Machine Shop Tools, Cutting Tools | Light Tool Supply
Sample Fanuc Tool change macro dpuch G-Code Programing 6 06-01-2011 08:13 PM
Entering Tool Offsets in Mill Geof Haas Mills 49 02-21-2011 10:09 PM
Takisawa Mac-v4 tool changer Fanuc 6m BrianM03 General Metal Working Machines 1 08-14-2009 10:38 AM
Kao Ming Tool Changer w/Fanuc OMC Control DaveMCINC Fanuc 1 01-14-2009 05:14 PM
mazak v5/fanuc 6mb tool changer mastercam post edit wild01 Post Processor Files 1 10-26-2006 08:44 AM
