| G-Code Programing Discuss G-code programing and problems here! |
Back to Basics! I have been given a program and told to run it just like it is. My problem is I do not recognize one of the parameters for G01. The program was for a Yasnac control on a Mori SL1 and I will be running it on a PUMA with FANUC 15T control. Here is the code N5 (NPR50.5) G51 G97T500S4500M3 G0-.02Z.05T505 G1ZoF.002 X.02 X-.376K-.024 G51 M1 What is the K-.024 for. I understand this in a drill cycle for peck depth but for linear interpolation? Thanks Geoff |
The K is an incremental command for Z- alot of that code would be accepted on a Yasnac without being in G91 mode(incremental). I don't think the 15t will buy it though, so you'll have to change it to Z- instead of K-. But it's just a chamfer, looks like .0084c with a .0156r tool. Robert
__________________ The beaten path, is exclusively for beaten men. |
| littlerob, I beg to differ. Every Yasnac I've ever seen has used W for incremental Z, not K. On a Yasnac, K is used for chamfering with the G11 command, but I've never seen it with G01 on a Yasnac. Are you sure your example came from a Yasnac? It looks more like a Haas (in Yasnac mode) program with that G51 in there. Most of the Fanucs (at least from the 6T on) will use K with a straight X and I with a straight Z feed to chamfer at the end of the line. I don't have any early 15T manuals, but I believe it should run. Get rid of the G51's though, I know the Fanuc will fail on that. |
| Dcoupar & Robert Here is What my edited file looks like at the present with the exception of the K parameter for the G01 N5 (NPR50.5) *This kennametal insert has a .005r G00T1104 G97S4500M3 G0X.02Z.05 G1Z0F.002 x-.02 X.376 (WHAT THE HECK DO I DO WITH THIS K-.024?) T1100 M1 Geoff |
X.376 K-.024 Z-.03 (IIRC this must be > than the K value). |
| Dave and Robert, The mentioning of the chamfer sent me to page 188 of my operators manual under Chamfering and Corner R. It lists the comand format as G01XbK+/-k; Specifies movement to point b with an absolute or incremental comand. Therefore I beleive the correct line for my program should read G01Z0F.002 X-.02 X.376K-.024 which will give me a 45deg chamfer starting at X.352,Z0 and ending up at X.376,Z-.024. Regards Geoff |
The K is to machine a chamfer when used in conjunction with G01. With a Fanuc control the next block must be a movement along the axis perpendicular to the axis containing the K. The code that you have now could be a bit risky to use, because without seeing the code that may precede the code you've posted, there is no movement to a tool change position. The G51 in your first sample program was to cancel the tool offset and return home. Accordingly, with a Fanuc control I would modify the program to something like this: Regards, Bill N5 (NPR50.5) *This kennametal insert has a .005r G28 U0.0 W0.0 G00T1104 G97S4500M3 G0X.02Z.05 G1Z0F.002 X-.02 X.376 K-.024 Z-0.025 (WITHOUT A Z MOVE AFTER THE CHAMFER BLOCK, THE CONTROL WILL ALARM) G28 U0.0 W0.0 M1 Alternatively, the last part of the program could be written as follows: X-0.020 X0.328 X0.376 Z-0.024 G28 U0 W0 M01 |
#10
I was wrong, Dcoupar is right about the coding. K for chamfer with G11 only. The inside joke is a member here on The Zone, who is really an authority on coding. With a very similar name to yours. But now I'm looking at post 3 and the answer is no, it will not leave a 45 chamfer. The tool starts at X-.02 and ends at X.376 with an (assumed) -Z movement of .024. Friends that's a tapered face not a chamfer!! It's all my fault . I agree with all posts (except mine), and the alternate toolpath that Bill posted is the easiest and correct. IF you want a 45 degree chamfer that will measure about .008. Don't forget to add the line X.328 line before the chamfer.Robert
#11
| I have an old 12t out on the floor which is still using G50’s. They have used the K values for chamfering in the past but IIRC the operator once told me it was related to using cutter comp. Now I do know on the Fanucs that U is for incremental X and W is incremental Z so if you need to make a chamfer in incremental mode then use U and W. I also agree with Dave and Angel that you should remove the G51 as I don’t see this listed in any of my Fanuc lathe G-codes. I only see it on my machining centers as “scaling”. Stevo |
#12
| Hi to you all, Thanks for the input. I have modified the program as follows to include a Z move to clear the material for a tool change as follows N5 (NPR50.5) *This kennametal insert has a .005r G00T1104 G97S4500M3 G0X.02Z.05 G1Z0F.002 x-.02 X.376K-.024 Z2.0 T1100 M1 Thanks Geoff |
| Parameters 281 and 282 on 0T | guhl | Fanuc | 1 | 10-25-2009 02:03 PM |
| Need Help!- Parameters, I think | heavy metal | Fanuc | 19 | 07-02-2009 01:48 PM |
| plc parameters | savancnc | Fanuc | 4 | 03-13-2008 08:37 AM |
| plc parameters | savancnc | General Electronics Discussion | 2 | 12-11-2007 02:48 AM |
| G83/G87 parameters | DocHod | Fanuc | 2 | 11-04-2007 01:54 PM |
