Old 12-13-2010, 04:51 AM
Farzaneh_2010 is on a distinguished road
write gcode for circle with 4 small circle inside it
hello.I want to write to G-code for circle with 4 hole in 4 side of circle. i must use G81.but I do not know how start it and what GCode is need.
in fact a circle with 4 small circle inside it around 4 side.
please help me.
Old 12-13-2010, 07:39 AM
ggborgen is on a distinguished road
G81 for circles?
If you want to use G81, I take that you are drilling these circles and not
interpolating these circles. The common G81 line requires:
Z= depth
R= reference plane
f= feed rate
But if you are interpolating these circles, you would want to use G3 to climb mill and G2 to conventional mill. And in order to help you any further I would need a little more information, than a circle with four circles inside it. Good Luck
Old 12-13-2010, 07:54 AM
Give use a drawing.
Old 12-13-2010, 10:24 AM
fizzissist's Avatar
fizzissist is on a distinguished road
Originally Posted by Geof View Post
Give use a drawing.
The part may be a standard centrifuge mount........
Not to be disparaging, but your talents may be wasted here, judging from the 3 months of posts by this guy. I'm all for helping newbies, but there's a whole lot of homework that isn't being done.
Need Help!- TCC crash during pocket milling, polyline inside circle StephanWenger TurboCAD/CAM 13 12-02-2010 08:36 AM
inside circle cutting problem glenthemann G-Code Programing 25 12-08-2009 04:00 PM
Gcode for circle Chrille86 G-Code Programing 3 04-19-2009 08:42 PM
cut circle bbrown2005 Mach Wizards, Macros, & Addons 2 02-04-2009 06:41 PM
Problem- circle AngelT Mach Mill 1 06-30-2008 08:59 AM
