| G-Code Programing Discuss G-code programing and problems here! |
| I cannot get this machine to run a M98Pxxxx sub program in EIA. Machine skips right over the M98 Pxxx command and goes to the next position. It also does not recognize the G98 command when drilling tapping. I need to jump over clamps ect. It alarms out with alarm# 425 Alarm B unusable g code 62. Does anyone have a list of M&G codes for this machine? Thanks, Al |
You are programming with Fanuc format ... the OSP is different : M98 P1234 would be CALL O1234 No G98 ... you need : G71 Z ( this is your initial plane ... this block is prior to your canned cycle call ) M53 is G98 M54 is G99 Hope this helps ... Real World machine Shop Software at ... Kentech Inc. - Real World Machine Shop Software Want to convert your Fanc programs to OSP ... or OSP ones to Fanuc ?? Check out CNC XChange from Kentech Inc. |
| What is the OSP command that would work the same as the Fanuc M99? I want the program to keep running untill I stop it. This is a new (old) machine and I would like to keep it cycling the program it's going to be running for a day or two to see if there are any problems with it. Thanks, Al |
The command RTS is used at the end of a subprogram ... like M99 on the Fanuc. Real World Machine Shop Software at ... Kentech Inc. - Real World Machine Shop Software |
| Try this link out Okuma Lathe G M codes G-codes M-codes Hope this helps you, though its for a lathe =/ Good Luck~! |
| right before the end of the program. Enter this exactly; GOTO N100 on the second line, at the top of the program enter this; N100. This will loop the main. Robert
__________________ The beaten path, is exclusively for beaten men. |
| Need Help!- OKUMA CADET MATE | Antonio Arguijo | Okuma | 13 | 10-09-2011 08:26 AM |
| Okuma Cadet Software | ryanh114 | Okuma | 5 | 05-29-2011 03:57 PM |
| Need Help!- cadet 4020 tool change problem | Hash01 | Okuma | 1 | 11-18-2010 01:54 AM |
| ATC Sequence problem Cadet 4020 | mbm | Okuma | 2 | 04-03-2010 01:35 PM |
| Okuma cadet mate 4020 -OSP700M 1999 | Taehk | Okuma | 2 | 06-21-2009 09:23 AM |
