| G-Code Programing Discuss G-code programing and problems here! |
I need help with duplicating similar cutting patterns. I am not sure if mirror image is the way to go. I have attached an example of the program I am working with. Any help would be greatly appreciated! |
| Both have their advantages and disadvantages, it depends a bit on the program. If the program is large, and the machine is not equipped with much memory, then using the Mirror Image function would have an advantage. The cutting program could go in a sub and called from the main with Mirror Image on and off. The biggest disadvantage with doing a straight Mirror Image is that one cutter path will use Climb Milling, whilst the other will use Conventional Milling. Your example program has been programmed so that the cutting method for the Mirrored Detail is the same. If the machine has sufficient memory, or the facility for DNC, I would prefer to duplicate the code so that the cutting method was consistent. Regards, Bill |
What the program does is cut out a dog bone shape from flat specimens. It does this in a repeat process. What I am looking to do is add more stacks with an offset of say 2 to 3 inches between stacks. How do you write the program to duplicate the initial program to repeat after offsetting in the Y direction. Does anyone know where to get a free G code simulator? |
| Use a G92 off set at the end of the program G00"X" 'KEEP THE SAME AS IN YOUR PROGRAM" Y3.0 "Z" SAME AS PROGRAM G92X0.0Y0.0Z0.0 That should just move everything in Y by 3.00" But dont forget to put a G92 at the start of your program to cancel out the G92. I would write you a full program but im sorry I dont have too much time today. This should help you out Good Luck~! |
What I tried using was a G97 code that resets the work coordinate system to where ever you choose then did the same thing you did. I was just wondering if there was a way to shortcut the copy and paste of the whole program to do the cutting. Is there a way to reference the whole thing in a one line? |
A simple way to achieve your result is how I would do it with a Fanuc control. 1. Put the cutting component of your original program into a Sub Program 2. From your main program you would drive to the start point in X and Y and call the Sub. 3. Move the desired offset for the next repeat, set the coordinate system and call the sub again. 4. you can keep doing this as many times as required. Alternatively, do as in 1 above, but when you call the Sub from the main program, pass the parameter to have it repeat a number of tines. If you do it this way, you would have to make the shift offset and the setting of the coordinate system within the Sub. An example of the Sub call with repeat is as follows for a Fanuc control. M98 P1000 L4 The the above line Sub program 1000 would be called and repeated 4 times. Post the make and model of the control and I'll do a program for you. Regards, Bill |
| ok you can try a sub program it will be the fastest way without copying code... you can try this to get you headed in the right direction... sorry I cant be of more help im crazy busy today..Good Luck and keep the chips flying! (CALL SUB PROGRAM) M98P1000 L24 "HOW MANY TIMES TO SHIFT" N271M30 (SUB PROGRAM) 1000(SUB PROGRAM#) N272G91G0"INC.MOVE"Y3.0 N273G92X0Y0Z0 M99 |
| Need Help!- My Milling OKK with fanuc 6M can't recognize G-code & M-code | nessei | Fanuc | 4 | 03-29-2011 08:39 AM |
| Converting Fanuc G code to Seimens 840D G code | Jasbinder | Siemens Sinumerik CNC controls | 2 | 02-20-2011 10:02 AM |
| Newbie- Takeout Unused G Code commands in Mastercams Generated G Code | shneek | Mastercam | 8 | 12-15-2010 02:32 PM |
| learning g code or cad-cam code output? | slow_rider | G-Code Programing | 3 | 02-27-2010 08:48 PM |
| looking for g code 3d from bobcadcam or simmilar for indexer lpt v5 with g code soft | troyswood | Ability Systems - LPT Indexer and G-Code | 2 | 12-24-2006 09:21 PM |
