Old 07-07-2005, 11:47 AM
trubble2rubble is on a distinguished road
new post processor or excel macro or...
I have started to do programming for a new customer using a older version of Cimatron. (version 8) The only difference between the output toolpath is for 2 axis circular moves. They both use I and J, but one seems to be incremental coordinates, the other absolute. Three axis output does not use I and J, so I'm okay there. Does anyone know how to edit a post for Cimatron, or is it possible to change I and J coordinates from incremental to absolute using a macro in Excel? Or is it possible to change the machine to get it to work with incremental coordinates? New machine I'm programming for is a Hurco with an Ultimax III control.
Thanks for any suggestions.
t2r
Old 07-08-2005, 07:12 AM
Kiwi is on a distinguished road
trubble
I don't know about Cimatron.
Can you get the code into Excel with the 'I' figures all in one column and all the 'J' in another?
Post a few blocks of your code that you require altered (also the block before each G02/G03 so the absolute can be calculated) and I'll see if I can write you a Macro.
Kiwi
Old 07-15-2005, 10:47 PM
Did t2r find a solution?
He asked for help but never responded to an offer.
Old 07-16-2005, 08:20 AM
found
Turns out the machining center in question has an "industry standard Fanuc" input option. Once selected, the programs output from the existing post run fine with the addition of a "%" at the beginning of the program.
Thanks very much for offering your help.
t2r
Post-processor robert123 Employment Opportunity 1 12-15-2011 01:59 AM
Heidenhain Tnc 430 Post Processor ilst Post Processor Files 12 12-10-2009 09:54 AM
post processor help jrrhotrod Post Processor Files 8 01-14-2005 03:45 PM
post processor jimini Carken Products (Deskam, DeskCNC etc) 1 10-02-2003 10:55 AM
Post processor for CNCadmin General CAM Discussion 4 06-24-2003 06:22 PM
