Old 11-12-2010, 07:06 AM
nabil_elbadri is on a distinguished road
multiple repetitive threading cycle
hi gents
i need to understand very good the value P for G76 in the first line, as you know P letter contains 6 digits each 2 digits represent function, i need to understand the second digits which are responsible for the retract value , how to calculate this value , i tried to understand it from the lathe operator's manual but it didn't work in my head, so if any one could help me and explain in details and support the explanation with an example with dimension i will be really apreciate it.
controller is fanuc 21i TB & GE FANUC AlphaX
thnx in advance for any help
Old 11-12-2010, 07:22 AM
chucker's Avatar
chucker is on a distinguished road
G76
This file should help I can not take credit for wrighting it I downloaded it for somewhere may have been here
File Type: doc Using the G76 is easy but does have its limits.doc‎ (24.5 KB, 74 views)
Old 11-12-2010, 03:55 PM
thank u for ur reply chucker, the file u sent me explained the same way as the manual that i have, i didn't understand the part of explanation
(- second 2 digits is % of the lead or pullout exiting the thread- 00
00 = almost no angle at pullout and 99 = 9.9 leads away start out ),
if i have 4 mm lead and i want to pull out in 45 deg, and thread lenght is 50mm , how much valu i put in second 2 digits???
thank u for ur reply again , and i am waiting for an answer
rgs
Old 11-12-2010, 05:54 PM
dcoupar's Avatar
rgs
I would put 00 if your thread ends in a thread relief groove or need to obtain maximum full thread up to a shoulder, and 10 if not. I don't think you can calculate an exact distance that will give you a 45 degree lead out. Does your part drawing call for exactly 45 degree lead out?
Old 11-12-2010, 10:58 PM
sinha_nsit is on a distinguished road
Ex.: P031560
03 = number of finishing passes (01 to 99 allowed)
15 = chamfer amount (00 to 99 allowed)
60 = angle of thread (80, 60, 55, 30, 29 or 0 can be selected)
Chamfer distance = chamfer amount / 10 * lead of thread
So, in this example, chamfer distance is 1.5 times lead.
The chamfer distance is the distance covered along Z-axis during angled retraction.
The angle is always 45 degree only, irrespective of chamfer distance.
If you do not want the end of the thread to get spoiled, use minimum 05 as chamfer amount.
Too large a value would skip last few threads (so, you would need to specify a larger thread length, in order to obtain the desired threaded length).
Sinha
Edit: I am not sure, but I concluded from an earlier discussion on this forum that if you specify a value smaller than 05, the control would use 05 only. Actually, smaller than 05 is not logically correct, unless there is a groove at the thread end.
Old 11-14-2010, 04:19 PM
now i understand it very good
thank u very much sinha and thanks for all ppl who replied to me.
lets have some
Multiple operations in the same cycle Lugy Mastercam 6 08-20-2010 03:08 PM
CL2000 I.D Threading cycle cutshaw Mori lathes 4 04-24-2009 06:24 PM
G78 threading cycle on Fanuc 0i-TD Deco-Doctor G-Code Programing 3 01-06-2009 11:35 AM
Threading cycle chrisryn Parametric Programing 1 06-12-2008 03:04 PM
repetitive cycle on Fanuc 21 TA DHYSTA Fanuc 11 08-16-2007 08:46 PM
