Old 11-10-2010, 07:48 AM
arobustus is on a distinguished road
I need some help with the DPRNT (DPRINT) command. Anyone out there using it?
This snippet is in exact parallel to the sample in the manual. It is for testing purposes, to get the hang of using the command:
O2233(SAMPLE DPRINT)
POPEN
DPRNT[C**X#502[3]Z#503[3]]
PCLOS
M30
It outputs the C and the X then raises "FORMAT ERROR IN MACRO". I know some of these manuals (the one I am using is FANUC B-63524EN/01, 16i-TB,18i-TB, 160i-TB, 180i-TB, pp 333,334 ) sometimes contain errors. If you have DPRINT commands that work could you post or send them to me along with the output they generate?
Old 11-10-2010, 10:52 AM
dcoupar's Avatar
POPEN
DPRNT[C** X #502 [3] Z #503 [3]]
PCLOS
M30
Have you tried spacing out the characters in the block (as per the example in the manual)?
Old 11-11-2010, 12:52 AM
sinha_nsit is on a distinguished road
Replace [3] by [53] which means five integer and three decimal digits.
Sinha
Old 11-11-2010, 07:47 AM
guypb is on a distinguished road
I was going to suggest the same:
You need 2 digits in the square brackets:
DPRNT[C**X#502[44]Z#503[44]]
4+4 is the number of characters output where 4 are after the decimal point. If you wanted to output the number as an integer it would be say [40] where you only want the first 4 digits output and no values after the decimal!
are you printing your probe offsets by chance?
Old 11-11-2010, 11:44 PM
dcoupar's Avatar
Oops. I was looking at the BPRNT not the DPRNT.
DPRINT Command 18Mi RLMTS Fanuc 9 11-09-2011 03:15 PM
Problem- DPRINT with EThernet Torsten Fanuc 3 07-15-2010 07:30 PM
DPRNT COMMAND harinct Machine Problems, Solutions , Wireless DNC, serial port 0 12-21-2009 04:38 AM
# sign using dprint Buddy Swanson Parametric Programing 0 01-04-2009 12:45 PM
Need Help!- DPRNT command in Yasnac J100 hense Machine Problems, Solutions , Wireless DNC, serial port 0 09-23-2008 01:38 AM
