| G-Code Programing Discuss G-code programing and problems here! |
I can't figure out how to get my toolnose compensation working when milling with the turret. So i would appreciate if someone with experience with SV32 could give me a program example. I have been trying a lot of things. But I'm getting an fault when activating toolnose compensation. PS: Sorry for my english. It's a long time since I've used it last. |
| for toll comp in a Turn/Mill machine you must befamilliar with the differance of a Lathe and Mills Both Horizontals and Verticals. Because this is what you have 3 machines in 1. you have to change you "PLANE SELECTION" G17 G18 G19 depending if you are turning, milling on the face, or milling on the diameter. |
| It is a "long" time since I've had the error. So I don't remember the error. I had to use another solution. At the moment I'm doing it this way. G1 Yx. Fx G17 G2 Bx Y-x. Rx Fx G17 G2 Bx Yx. Rx. Fx That is how i recall it. But it would be a lot easier if I could just regulate the R-value in my offset instead of my program. The error says something about the original plane selection. I'm not by the machine until monday night, so i can't give the exact error message. Don't you have a suggestion for an example that are supposed to work with Fanuc16i? |
| Tool Turret Fault Alarm on TL-1 with no Turret? | Edster | Haas Lathes | 10 | 02-08-2010 08:35 AM |
| Need Help!- BackLash Compensation | bearracecars | General CNC (Mill and Lathe) Control Software (NC) | 0 | 05-20-2009 10:36 PM |
| Need Help!- RAM compensation 15M | PTtec | Fanuc | 11 | 09-25-2008 04:32 AM |
| Backlash Compensation | cnccustom | Mach Mill | 1 | 11-21-2007 07:33 PM |
| Bolt on Turret 'v' VDI Turret | scappini | General Metalwork Discussion | 0 | 07-20-2006 06:59 AM |
