Old 06-29-2005, 12:59 PM
endmill is on a distinguished road
Probe sets work offsets
Help! I have Fanuc 15m control one on Niigata one on a Daewoo. They both use probes to det work offsets. I can get all the probe macros to work on the Daewoo except for the macro that writes to the work offsets (G54-59) It all works fine on the Niigata. All the effective parameters are the same. Does this have something to do with ladder logic? I'm stumped..
Old 06-29-2005, 02:13 PM
psychomill is on a distinguished road
Have you done a file compare on the macro routines to see if any code (or variable used) is different? Don't change it necessarily, the machine may need it or use it in a different way. Just see if the subs (programs) are different. Just guessing here...
Old 06-29-2005, 02:16 PM
They are the same subs and programs
Old 06-29-2005, 03:49 PM
Any alarms or just 'nothing happens'? Maybe the variable sets are different on the Daewoo for machine position and/or offset position. Will any of the macros (Bore/Boss, point, web etc) set any offsets? Or all of them work but won't set an offset?
Old 06-29-2005, 04:06 PM
All the probe macros call another to make the offsets. They all call the same macro to set the offsets. I am baffled no alarms no nothing. The program keeps running. It just doesn't make the offsets, thus it positions wrong after it exits probe routine, and goes back to the main program.
Old 06-29-2005, 04:48 PM
May need to bust out the Daewoo programming manual (if you have one) and a probe programming manual (if you have one) and step through the macro. Verify that the variables its using to set the coordinates are correct for the machine. If you MDI the same variables for offsets will it set?
Old 06-30-2005, 07:11 AM
I've busted them out over thru and on the behind. It will set with a G10Pi just not with the macro. I should have time today to look closer at the daewoo manual. Fanuc told me nothing. Thanks for the ideas. The boss said to call Fanuc. I told him it was personal now, just me and daewoo.
Old 06-30-2005, 10:07 AM
Try this in MDI....
G90
#5221=5. (Sets G54x)
#5222=5. (Sets G54y)
#5223=5. (Sets G54z)
You should see a "5." in G54 XYZ.
Now try this, move your machine to some position by jogging or handle. Make sure you move X,Y and Z. Now don't move the machine and in MDI try this:
G90
#5241=#5021
#5242=#5022
#5243=#5023
Now check G55 position. It should match your current 'machine position'.
Old 06-30-2005, 10:38 AM
I got it...In the ladder logic. G5.7 is a protect switch for key4 or on the pcdgn screen searchb for g5 this shows the bits bit 7 is off should be on. this is read from an eprom chip. Fanuc will have to burn a new eprom or we will have to manually set this at power on each day. I'll go with the Fanuc option.
Thank you for your help
Old 06-30-2005, 10:56 AM
Wow! Thats unusual... Glad you found the problem. Most problems I've seen were up front.
Old 06-30-2005, 11:10 AM
Al_The_Man's Avatar
Usually the machine tool builder is responsible for taking care of this (Daewoo).
You may have to get them to ship one out, and may be it was an oversight on their part originally.
  #12   Ban this user!
Old 01-14-2009, 10:27 AM
Eddieconklin is on a distinguished road
Angry Slow Set-ups need Renishaw Probing 101 help
I need some help,
I have a machine Job shop with 10 horizontals and 6 verticals. Our set-ups are slow and our operators have never worked with renishaw probes are non contact lasers. We have manual tool setter. We have a demand of about 50 set-ups a day with the average job box of about 7 pieces. Can anyone explain what the probes and laser can do to help me ? And are there any other things we can do to reduce our set-ups
Eddie
CNC lathe tool and work offsets mm4039 General Metalwork Discussion 18 06-15-2005 11:45 AM
Tool offsets plateroomred CamSoft Products 7 05-28-2005 02:43 PM
Parallel Sets? rcazwillis General Metalwork Discussion 14 05-02-2005 09:25 PM
Work Offsets new2cnc Mastercam 3 04-30-2005 10:04 AM
Setting Work & Tool offsets Shizzlemah Fadal 7 04-16-2005 12:04 PM
