Old 10-30-2010, 01:56 PM
CS900's Avatar
CS900 is on a distinguished road
4 axis coding
well i've walked myself into a corner that it looks like i need a bit of help getting out of. I'm trying to make an oring groove that wraps around the exterior of a cylinder. My attempts to hand code this have been less than successful so far, and i'm getting a bit pressed for time. So can anyone point me in the right direction here? And for reference this is what i'm trying to produce...
Old 10-30-2010, 02:26 PM
What type of machine are you running? Haas has a command G107 called Cylindrical Mapping, probably other machines have the same. This maps Y axis moves onto the periphery of a part mounted on the A axis. The Y axis is used to position the A axis exactly on the spindle centerline and then the G107 converts Y motion into the appropriate rotation of the A axis based on the diameter of the part. The motion is programmed as if it where a Y axis move.
Old 10-30-2010, 09:35 PM
CS900's Avatar
i'm actually running a home built mill, running mach3 for a controller. Just took a look, and it doesn't appear that mach3 has any sort of feature like that.
Old 10-30-2010, 11:06 PM
holbieone's Avatar
holbieone is on a distinguished road
trig it out
trig out the circle in the 2d plane so you have a point to point program with X and Y
then use the distance from the center of rotation to the center of the ball end mill and half the distance between Y's to calculate the degrees time 2 for A
then replace the A moves with the Y moves , so you end up with a program with X and A to form the o-ring grove
make sure you changes the signs for the proper A axis reversals
Old 10-30-2010, 11:14 PM
holbieone's Avatar
if you put X zero and A zero at the center of your o-ring circle all you need is to calculate for one quadrant of the circle and the just change the signs for the others
Old 10-31-2010, 06:33 AM
ger21's Avatar
Not sure if this supports G2/G3, but you can code it flat and then wrap it around your part.
CNCWrapper - Home Page
Download the demo and see if it'll work.
Old 10-31-2010, 09:52 AM
CS900's Avatar
yeah, i tried this method as well, but the result was very "choppy". I suppose I just need to use more points to smooth it out, but i was hoping not to have to sit down and code for 5 hours, lol. I suppose I could make an excel spreadsheet to do all the boring work.
good find! i'm going to give that a try right now.
Old 10-31-2010, 01:36 PM
CS900's Avatar
so...results thus far. tried out that cncwrapping program and it does NOT accept g02 and g03 commands. it's purely an x and y translator. So, I ended up writing an excel file to point several x and y coordinates for the circle that i needed. proceeded to take that code and ran it through the cncwrapping program and this is the result:
it'll work for what I need it for, but it doesn't look like i quite got as much a rotation as it should have. Any ways, thanks for the help guys!
Old 11-01-2010, 04:16 AM
Kiwi is on a distinguished road
Here is a VB program that gives some code.
Can modify if not what you need.
Problem- Roller cam coding greybeard Coding 6 10-23-2010 12:28 PM
5 axis manual coding themuffinman General Metal Working Machines 10 06-13-2010 07:48 PM
New to G-Coding Larry Myers G-Code Programing 4 09-20-2007 09:06 AM
G2/G3 Coding jrobson G-Code Programing 24 09-02-2006 12:54 PM
Coding own CAM program jonifootbalpl8r General CAM Discussion 2 04-10-2006 06:43 PM
