| G-Code Programing Discuss G-code programing and problems here! |
Hello, Does anyone know something about FCRSYS for A-B 8600 Osai. Namely I have a problem to force the machine to load data from Tape reader instead mass storage, since HDD is dead and I have BTR which emulates reader and they says that drip feed works perfectly. Thank you in advance |
| Hope it helps Loading from Punched Paper Tape Using a Reader This procedure requires the activation of the paper tape reader driver. If the connection is made with the system CPU, write the following minimum FCRSYS: *2 XAREAD, 09,0,3 * If the connection is made with the display board, write the following minimum FCRSYS: *2 XAREAD,09,1,3 * Loading from a Magnetic Cassette This procedure requires the activation of the magnetic cassette reader driver. If the connection is made with the system CPU, write the following minimum FCRSYS: *2 XATEAC,OB,0,3 * If the connection is made with the display board, write the following minimum FCRSYS: *2 XATEAC,OB,1,3 * |
| Hi, I need help on the following issue with OSAI 8600 with Herbert Preoptive 8 Lathe. I was able to fix some of the hardver problems and startup the OSAI 8600 controller. I am trying to do a "System Clearout" which means that some of the memory segments have to be erased. I have got the following message during the process "" FILMS1 29 OUT OF MEMORY. this means that " A non existing address has been addressed with the DEBUG utility". I have typed the correct memory segment (using the manual) and it is giving this error message. Please help me on this or tell me who can I turn to related to my issue. Thanks Ferenc |
| hello We have recently bought Utas ( Osai A-B 8600 Control )cnc turning Machine with an OSAI – Allen Bradley 8600 control system. This unit when purchased by us was not working We are kindly request help in guiding us to sort out the below mentioned problem.( We change the battery cause the one we get it in the control was totaly Empty) When the machine is powered on the following messages are shown on the screen: SERIES 8600 o.s ver 4.0 DISC???? BUBBLE???? CMOS???? EPROM???? ***INIT ABORTED*** thank you for responding Many Thanks in advance, Regards mohammadreza dolatabady |
| Osai A-B 8600 | karmoleed | Europe Club House | 19 | 03-22-2012 09:14 AM |
| OSAI A-B 8600 SOFTWARE | baba1511 | Europe Club House | 2 | 01-11-2012 12:29 AM |
| CNC Series 8600 ''Init Aborted | baba1511 | Europe Club House | 0 | 01-27-2010 06:32 PM |
| OSAI A-B 8600 SOFTWARE | baba1511 | CNCzone Club House | 3 | 10-21-2008 11:37 AM |
| Osai 8600 | PaulWCNC | General CNC (Mill and Lathe) Control Software (NC) | 1 | 07-09-2008 02:29 PM |
