Old 10-24-2010, 07:16 AM
jorgehrr's Avatar
jorgehrr is on a distinguished road
Lathe Circular Interpolation C axis
Nakamura TW10 Fanuc 18T
Trying to save set up time. Very low volume job.
One of the operation require a .625 rough hole. I'll like to use a .5 dia. End mill already in the machine.
How do I interpolate to make a .5 end mill cut a .625 diameter hole.
This is how I'm planning on doing it:
Z0.0 is face of material.
After I engage C axis....
G and orientation codes...
G0X.0625Z.1
G1Z-.250
C360.F15. or H360.F15.
I'm trying to make C axis rotate 360 degrees to increase the hole diameter.
Please advice if this is a good way to do this.
Can I use X and Y axis like in a machine center instead??? G2 or G3 from the center of the hole??
Any input will be appreciate.
Regards.
Jorge.
Old 10-24-2010, 01:35 PM
dcoupar's Avatar
I think the H360. should work. I believe your feedrate will be in degrees per minute, so F15. will take about 24 minutes to make one rev.
Old 10-24-2010, 04:26 PM
jorgehrr's Avatar
So much for a set up reduction. LOL
Thanks for ur replay.
I have a small macro that will take care of the feed rate.
O9005*
#[#18] = #2/[[3.1416 * 2 * #7] * #2 /360] / #9*
M99
Again. Thank u very much.
Old 10-25-2010, 04:01 AM
sinha_nsit is on a distinguished road
Not possible, though I am not very sure.
Old 11-23-2010, 06:10 PM
steveptrs is on a distinguished road
Ok I have a very similar issue. I am looking for a formula to calculate feedrate in degrees per minute. Does anyone have anything?
Old 11-25-2010, 01:59 AM
dcoupar's Avatar
This might help...
File Type: pdf Feed Rate Calculation for Rotary Axis.pdf‎ (97.3 KB, 94 views)
Old 11-25-2010, 11:44 PM
g-codeguy is on a distinguished road
How long could it possibly take to mount a 5/8 inch drill?
Old 11-25-2010, 11:47 PM
Originally Posted by dcoupar View Post
This might help...
Thanks for the link. I have a couple old jobs I would like to try using these formulas on. Just to see how close my guesstimates are.
circular interpolation pmesilver Mach Mill 1 04-10-2010 07:20 AM
Newbie- Circular Interpolation Deadwood Mach Software (ArtSoft software) 3 01-11-2009 02:35 PM
circular interpolation sqatch Dolphin CADCAM 9 02-11-2008 12:02 AM
Circular interpolation problem L. Sakthivel Fanuc 3 10-17-2007 02:26 AM
question about circular interpolation warpedmephisto Benchtop Machines 13 03-22-2006 04:51 PM
