Old 10-02-2010, 03:28 PM
lildave26 is on a distinguished road
looking for numbers to do a 30' angle
new to this site so thought id throw this out there any help would be great my lap top went down so trying this starting point is Z0 X2.285 30'ANGLE TO X2.541.. THANX FOR ALL HELP
Old 10-02-2010, 03:51 PM
holbieone's Avatar
holbieone is on a distinguished road
X2.541 Z0.1478
Old 10-02-2010, 04:14 PM
When you are dealing with 30, 45 or 60 degrees it is almost mental arithmetic if you remember the ratios between the sides of the appropriate triangle, see the picture for the 30 - 60 - 90 triangle.
The 45 - 45 - 90 triangle is even easier, when the two short sides are 1 unit long the hypotenuse is 1.4142.
And I suppose I should correct my picture from 1.732 to 1.7321, rounded up from 1.7320508.
Old 10-02-2010, 08:13 PM
holbieone's Avatar
b = X2.541 - X2.285
b = .256
A = 30
a = b x tan(A)
a = .1478
Need Help!- Wild numbers! ozzie34231 SolidCam 10 06-11-2010 04:55 PM
Need Help!- serial numbers 1234567 Fanuc 2 02-13-2010 05:03 AM
Block Numbers phoodieman Mastercam 2 01-22-2008 03:40 PM
Line numbers batmill G-Code Programing 11 09-16-2007 03:25 AM
RFQ - 2 part numbers mcmmach Employment Opportunity 1 05-19-2006 10:18 AM
