Old 06-20-2005, 10:32 AM
micromillnick is on a distinguished road
Talking making Gears with 3 axis cnc
hi all,
i need/want to make a couple of gears (big tooth small dia) so i can make a HP gear pump, the machine can do it i dont doubt and autocad can draw it so thats no problem, what i need is some way of inputting the right tooth form into autocad. I only need a two dimensional representation as i plan to cut out the gears i need from plate.
Thanks in advance.
Nick
Old 06-20-2005, 02:55 PM
braidmeister's Avatar
braidmeister is an unknown quantity at this point
http://www.cadopolis.com/prodCWD-Gear.asp
http://sofengsvc.com/#gearpack
Bobcad will also do gears...
-Brady
Old 06-20-2005, 04:18 PM
Gears
thanks mate, i'll give those a go tomorrow!
Nick
Old 06-21-2005, 07:26 AM
ok had a play with those programs, unfortunatly one runs in dos which my XP machine doesnt like and the other is not compatable with my very old version of autocad (R14) so its back to the drawing board :-(
nick
Old 06-21-2005, 10:31 AM
duluthboat's Avatar
duluthboat is on a distinguished road
FeatureCam has a great little pull down for gears. If you supply the required information I’ll send you the profile in a R14 dwg file.
Old 06-21-2005, 11:30 AM
very kind of you, i basically want a large toothed gear of relatively small diameter im thinking about 20mm dia with just perhaps 6 teeth. the reason for this is i want to make a gear pump. I did find a natty little LSP for gears on the web called GEAR.LSP but it will only let me do a minimum of 14 teeth at that size, which i guess will still work but perhaps at a lesser volume per given speed.
The Spindle size would be a convenient at 6-10mm, pressure angle etc is not critical as its job is to pump.
thanks again
Nick
Old 06-21-2005, 12:18 PM
duluthboat's Avatar
Just one gear, or will there be two that will mesh.
Old 06-21-2005, 12:54 PM
just one really, i plan to make two the same then they can mesh together.
Thanks again!
Nick
PS Feature Cam sound very useful, is it expensive?
Old 06-21-2005, 12:56 PM
oldjohn's Avatar
oldjohn is on a distinguished road
Smile
G'day
Do you have an address where I can send you a Mastercam file of a 6T 20 OD. You can then wirecut it. Icannot send an attachment. The format is not compatible.
John
Old 06-21-2005, 12:59 PM
thanks john,
its
pulseweld-at-dsl.pipex.com
(apologies for the long hand ,ive used the -at- instead of @ so i dont get spammed)
Nick
  #11   Ban this user!
Old 06-21-2005, 01:17 PM
duluthboat's Avatar
Looks like oldjohn has got it. Let us know if you need more help.
  #12   Ban this user!
Old 06-21-2005, 01:51 PM
oldjohn's Avatar
Hi micromillnick
I sent two emails to you, one with -@- was returned to me. then I sent one wiith @ I don't know if you got it. It hasn't come back. tell me if you got it.
John
Making money with CNC Johnuk CNCzone Club House 26 12-13-2009 10:46 AM
3 axis CNC Router with AC/DC Brushless motors (Need help with electronic Design) StressedMech General Electronics Discussion 8 05-15-2005 11:26 AM
Where can I buy 4-5 Axis Wood CNC for making Car Parts ?? Calico Commercial CNC Wood Routers 0 02-27-2005 07:21 PM
5 axis metalworking cnc nimda General Electronics Discussion 3 02-15-2004 11:17 AM
5 Axis Rotery Head Home Cnc Router mace DIY-CNC Router Table Machines 22 09-18-2003 11:29 AM
