| G-Code Programing Discuss G-code programing and problems here! |
I have a small mill (A2ZCNC) with a Sherline rotary table vertically mounted so axis is parallel with X or horizontal (now that makes me unsure of what this axis is correctly referred to). Anyway tonight I was playing with some manually written G code and lowering the z and then moving the X back and forth, retract Z, rotate the A 60 degrees (or whatever that axis is called, I do call it A in my code) and basically repeat. It gives me a wrench flat and or flat sides down a otherwise round bar. That got me starting to think about how a ballscrew is made. I see it as Drop Z to first cut depth at starting point of X. Engage A and X at the same time (this is where my question lies). If I wanted A to rotate 720 degrees over the next 2" of X travel. One of the feedrates are going to override the other, right? Purely a hypothetical measurement not a real ballscrew. It really gives me a little more possibility with a wee little Sherline. Almost like a lathe with a milling head. I really think it would allow for some interesting twists in bar stock with out using the lathe. The other cool thing was that I could perform quite a few more functions without ever taking the part out. Similar to Simpson36's(?) machine making hose barbs. So how would I write that? ( 1 full rotation of A while X is traveling 1" and Z is fixed) Anyway any tips would be great. |
| Simultaneous control is possible if you have a 4-axis control. You use G01 only, with all four axis distances/angle. Feedrate of rotary axis ("A" is parallel to X, "B" parallel to Y and "C" parallel to Z. So, you have A-axis on your machine) is in deg/min, if commanded separately. If you use a linear axis as well as a rotary axis in G01 (as in your case), the commanded feedrate would be along the tangential direction of tool movement, i.e., along the spiral toolpath. This way you can generate a uniform pitch. If you need a complex contour, defined by lines/arcs, on the circumference, you need to have cylindrical interpolation available on your machine. |
| sinha, Thanks for the response. I do have 4 axis available. Maybe I am understanding you on how to use G01. I was under the impression that "A's" feedrate was overriden by "X's" and it appears it is. So can I write it like this? G01 Z0 F1 (clear of workpiece) G01 X0 F6 (starting point of X) G01 A0 F360 (starting point of A) G01 Z-.0125 A720 X2.25 F6 (would this plunge the Z in .0125, rotate 2 revolutions while starting at X0 and traveling to X2.25? Would it cut a spiral along the X axis with 2 revolutions over 2.25"?) |
| Mach 3 arc problem possibly | Chris64 | Mach Software (ArtSoft software) | 5 | 10-28-2009 05:50 PM |
| 3 axis simultaneously with 4th | Stebedeff | Mastercam | 5 | 01-17-2009 01:37 PM |
| G19 and G16 simultaneously | geodudi | G-Code Programing | 2 | 06-04-2008 08:22 AM |
| hm 30 milling machine - about to possibly buy one | domonic_cnc_guy | Benchtop Machines | 6 | 01-29-2008 05:01 PM |
| x2 potentiometer possibly bad, help | h_2_o | Benchtop Machines | 9 | 12-12-2006 10:18 PM |
