Old 09-13-2010, 02:17 AM
Farzaneh_2010 is on a distinguished road
G02 draw circle
hello
sorry.my English is very weak i hope that you understand my message
i am trying to write a program g-code with delphi
but i have problems about G02 and draw a circle becuse i can not use Arc
and i had to draw a circle with lines.please help me to find a solution for this
problem.how draw line and what kind of parameters i need?
please help me
Old 09-13-2010, 03:02 AM
praneshkumarpj is on a distinguished road
Hi
In order to draw a circle using lines consider the equation of the circle X^2+Y^2 = R^2
You know the radius of the circle. Consider a point on circle. Let it be (X1,Y1).
Now increment the X1 value to X2 = X1+0.01 and calculate the corresponding Y2 value from equation Y2 = squareroot(R^2 - X2^2).
Iterate the process by incrementing the X value to 0.01 until Xn = X1 + 2R.
So now u will get a set points and by joining those points you will get a semicircle.
Proceed in the reverse way i.e. from Xn to X1 to get the other semicircle.
Old 09-13-2010, 03:28 AM
Originally Posted by praneshkumarpj View Post
Hi
Thankyou
u mean the new equation of the circle is x2^2+y2^2=R2^2
but i want to write this equation in delphi or other programming langauge.for
example in delphi it write by lineto(x,y)
so how i can write it?
Old 09-14-2010, 01:46 PM
samu's Avatar
samu is on a distinguished road
i dont think it is a good idea to set a linear increment, cause it is a trigonometric function. With a linear increment, acuracy won't be the same all aroud the circle.Instead, use an angular increment.
A=Angle
R=radius
I=increment
Do this loop while A is less that the value you want to reach
X=cosA*R
y=sinA*R
lineto(x,y)
A=A+I
Old 09-15-2010, 06:13 AM
sinha_nsit is on a distinguished road
Right.
Old 09-28-2010, 02:38 AM
Originally Posted by Farzaneh_2010 View Post
Thankyou
you have to iterate the equation several times and use the numeric values arrived from the equation
Draw Bar g29cc Novakon Systems 2 08-12-2010 08:58 AM
Need Help!- How to draw this? SPEEDRE Solidworks 9 06-15-2009 09:10 PM
cut circle bbrown2005 Mach Wizards, Macros, & Addons 2 02-04-2009 06:41 PM
Need Help!- ?s on How to draw a Hex. Stampede BobCad-Cam 12 02-03-2009 08:26 PM
Need Help!- okk-mha-400 draw bar Ethan H OKK 0 10-07-2008 08:39 PM
