Old 06-06-2005, 05:12 PM
rfstar is on a distinguished road
C & Z Feed rate
How do you calculate the C & Z Feed rate Both Axis moving at the same time, I have tried but can never figure it out so I guess at it
Thanks In Advance
Randy
Old 06-07-2005, 08:01 AM
DAB_Design is on a distinguished road
Since C axis is a little uncommon, I'm first going to ask what axis it is.
We have 1 milling machine with C axis (X Y Z B C). It is a rotary head machine, the head can turn 360degrees 27 times(9999.999degrees) before the software on the controller won't handle any more. Since it is positioned in degrees, the feedrate needs to be in 'inverse time'.
If yours is similar, do a google search for "inverse time feedrate calculation" (without the ""). Click the first page listed (actually a .pdf document). Scroll down to page 8. It gives an example with and formula(s).
Dustin B.
I hear and I forget.
I see and I remember.
I do and I understand.
Old 06-09-2005, 04:52 AM
ghyman's Avatar
ghyman is on a distinguished road
What control / application?
Feedrates for C/Z moves vary from one control to the next.
Some apply the feedrate to the Z-axis move, and let the C-axis fend for itself.
Others, like Dustin mentioned, will do a degrees per minute type of feedrate, And I've even had the "pleasure" of working with a control that would allow you to program a normal IPR/IPM feedrate for the C axis, and the Z-axis move would get to the endpoint at the right time, but you may have buried the tool!
Old 06-09-2005, 09:21 AM
BillPSu is on a distinguished road
The feedrate calculation will have to be based on the distance away from the centerline of the C axis. 5" from centerline and moving 360 degrees per minute yields 31.4 IPM. If movement on Z axis causes movement toward or away from centerline the feedrate will increase or decrease as the position changes.
Old 06-20-2005, 10:03 PM
oldjohn's Avatar
oldjohn is on a distinguished road
G'day
Mate, I'm waiting for you to answer what sort of machine it is but you dont seem very interested in having the right answer. If it is a lathe fitted whith C Axis I can help.
John
Old 06-21-2005, 04:15 PM
Yes, Im Sorry it's a Lathe with fanuc 18T Control Hitachi seiki super Hicell 250 with XYZC and B axis
Thanks in Advance
Old 06-21-2005, 10:08 PM
oldjohn's Avatar
G'day
Good that you got back. I'm assumming the C axis is the rotary axis. Is it not?
I'll scan the pages with the calculations from my "bible" and post them to you. Just wait a litlle, but I have it. Last night I was up till 10 past 5 AM. sending posts to forums. My way of enjoying life in retirement.
John
Old 06-22-2005, 12:38 AM
oldjohn's Avatar
G'day again
Here are the files on cutting speeds and feed calculations for C/Rotary axis. Open attachment.
John
Need Bridgeport EZ-Track G-Codes to build post soweebee Bridgeport and Hardinge Mills 13 01-28-2006 01:10 AM
Advice needed for Mill Feed Rate raytor Benchtop Machines 4 03-25-2005 01:11 PM
Feed rate question studysession General Metal Working Machines 6 10-30-2004 01:00 PM
How can I up my feed rate ? ynneb DIY-CNC Router Table Machines 7 07-12-2004 09:40 PM
feed rate issue with arcs. balsaman TurboCNC 6 06-26-2003 08:25 AM
