Old 07-21-2010, 08:01 PM
Larry Myers is on a distinguished road
Need M19 advise
Hi All
I am looking for a little advise concerning the use of M19, spindle orientation, on my VMC. I have a Sharp 2412 with a Fanuc Oi-Mate controller.
Here’s what I want to do: I have a 1” X 1” X 1” pocket in a piece of aluminum. The corners have a 0.0625 radius. I want to clean up the corners with a broaching tool that I had made for me. I realize that there are different schools of thought in terms of broaching with a milling machine. For now, I would like to put those thoughts aside.
The broaching tool has a 0.5” X 0.5” square end (bottom cutting surface) that has a concave bottom for cutting and chip removal. It has a tapered shank 1.5” (upwards) to a 1” shank that will fit into a tool holder.
I want to move the tool to line up the corner of the tool with the corner of the pocket. This is assuming that that the tool is properly positioned in the tool holder. I want to drop the tool down in Z just to shave off the about 0.002” off of a wall and then retract it to a safe distance above the pocket, and then move it again to shave off the adjacent wall. Then onto another corner.
Here is a simple program. 0,0 is in the center of the square. You will see that for this example, I am not concerned about exact X and Y coordinates. I am more interested in the format of what I am attempting.
O02500 (CORNER BROACHING)
N1 G20
N2 G00 G17 G40 G49 G80 G90
N3 T1 M06 (broaching tool)
N4 G00 G90 G54 X-0.25 Y0.25 M08
N5 G43 H1 Z0.1
N6 G01 Z-1.0 F20
N7 Z0.1F100
N8 M09
N9 M30
For the life of me, I can not find any information on how or where to put M19. I want to lock the spindle in one position. There is no spindle lock on my machine. I know that if I press the SPINDLE ORIENTATION button on the machine, it will rotate the spindle back and forth and then lock it in place. The only way that I can find to unlock it is to hit the reset button. But then I really do not know what I am doing!
Any advise will sure be welcome. Many thanks in advance!!!!!
Larry Myers
http://www.colfaxtactical.com
I also posted this in the Sharp machine forum here in CNCzone. But it is usually pretty quite there.
Old 07-22-2010, 03:14 AM
sinha_nsit is on a distinguished road
Without spindle lock, your method may not work.
M19 is given before tool change.
Old 07-22-2010, 09:30 AM
psychomill is on a distinguished road
If the spindle has a brake (not necessarily a "lock") then you should be able to command it at any given time after tool change. If you have an ATC and it's a flange taper machine (like CAT, BT, HSK (some forms), etc), it should "lock". Code it here:
N1 G20
M19
N5 G43 H1 Z0.1
N6 G01 Z-1.0 F20
N7 Z0.1F100
N8 M09
N9 M30
You can check it by hand to make sure it "locked". Just be careful because "lock" and "brake" are two different things. Generally, "lock" is a different M code but most verticals don't have this. Need to be sure you don't overcome the brake when broaching. Might need to add a bit of dwell if your machine starts moving before orient is complete.
As for releasing it, some MTBs write in the ladder to release the brake when commanded a M5. Some release if you command a M3S0. For sure if you command a M3 with a low speed (like S30) then the orient will release. But if all you're doing here is broaching with this tool, then you don't need to release it. Just tool change to the next tool and move on.
note: Another option some spindles have is the ability to orient to a specific angle. Generally something like "M19S900" for example would orient the spindle at 90°. Codes can change a bit depending on the builder. Not all machines have this. There's another way to do this through parameters which you can write over then change back in a program but that's a bit more sketchy if not careful.
It's just a part..... cutter still goes round and round....
Old 07-22-2010, 10:44 AM
M19
Thanks Psycomill
I'll try it
Larry
Old 07-23-2010, 01:55 AM
Can we have more info about the difference between lock and brake?
In layman's language, how can the spindle be locked without a brake?
What is the mechanism?
Old 07-23-2010, 07:24 AM
Superman's Avatar
Superman is on a distinguished road
My understanding of LOCK and BRAKE
Lock is where the position is held stationary by a motor, the motor would pulse +ive and -ive to keep it close to the set position. Likening it to keeping the car in gear on a slope and using the accelerator (just) to stop rolling forward or backward.
Brake is where the rotation is restricted by a physical clamp, like using the handbrake on a car. It must be released before motion is resumed.
Rotary axes on a machine are usually held in position by a "lock", but if higher cutting forces are experienced, which could make the axis move, an M-code can be applied to activate a physical "brake"
Old 07-23-2010, 11:06 AM
Superman explains one type of distinction..... This can also be reversed.....
Machine builders describe "lock" and "brake" and even "clamped" slightly different from another builder. The point is to understand what is being described for each word with each machine and/or builder.
For the most part, it is as Superman describes. Brakes are also used when feeding on a rotary axis. Some 5X and Mill/Turn machines have this (sometimes referred to Mid-Brake). On those machines, they'll often have another setting for locking which may be called "Clamp".
On other machines, the builder may refer to a locked condition, but the reality is that is an electrical brake (motor pulse).
Bottom line, understand the equipment you're using.
Old 07-23-2010, 05:15 PM
jamesu229 is on a distinguished road
Possible lock code
I do not know if it will apply to your machine or not, but our new fadals have the fanuc oi and the lock code is 189, 19 is only orientation.
Old 07-23-2010, 05:56 PM
dcoupar's Avatar
Larry,
Your machine uses M19 Spindle Orientation ON and M20 Spindle Orientation OFF.
There is no clamp or lock on your spindle, only orientation.
Old 07-24-2010, 03:14 AM
So, after commanding M19 (only), is it possible to change the spindle orientation manually by applying
1. virtually no torque, or
2. some torque, or
3. large torque?
  #11   Ban this user!
Old 07-25-2010, 01:47 AM
dcoupar's Avatar
2. some torque, or
3. large torque?
I believe that while oriented with M19 applying too much torque will cause an alarm (over current or some such thing).
  #12   Ban this user!
Old 07-26-2010, 05:01 AM
This means that M19 is only for alignment purpose where one wants to have a particular orientation for the tool in the spindle. A separate mechanical brake (actuated by some M-code) is necessary if the spindle is required to remain locked in this position even in case of large torque. If so, an application like broaching may not be possible without a brake.
Looking for M19 advise Larry Myers Sharp CNC 3 07-21-2010 10:05 PM
looking for advise phill05 General CNC (Mill and Lathe) Control Software (NC) 0 03-09-2010 02:19 AM
1st CNC - Need Advise gerryv Benchtop Machines 2 10-31-2007 02:29 AM
need some advise joey1117 Benchtop Machines 0 09-01-2007 09:47 PM
New some advise. fishmasterdan CNCzone Club House 3 07-05-2006 06:02 PM
