Old 07-18-2010, 02:05 PM
aaronson is on a distinguished road
Post stretagy for multiple head machine
I have a multiple head machine - Shoda.
The machine has 4 main spindles (Colet type) and 4 piggyback spindles that are mounted on each of the mains.
The 4 main spindles are positioned on the Z-axis carriage with manually adjusted spacing on the Y-axis. The piggybacks are attached to the mains and have a fixed X-axis shift relative to the mains.
The mains are selected as T1 - T4 and the piggybacks as T11-T14. No M6 is required to effect a spindle selection. An M3 lowers the spindle to a manually preset position via a pneumatically controlled slide.
The control is a Fanuc 21iM-A.
Do you recommend using type-C tool offsets in the X, Y and Z axises or setting a work coordinate system for each of the spindles ?
Thanks,
-itai
Need Help!- Post-processor for 5 sim. axes Head-Table type machine with Sinumerik 840D long.hv SolidCam 4 08-11-2010 09:01 AM
Need Help!- Post stretagy for multiple head machine aaronson Post Processor Files 0 07-18-2010 11:34 AM
Multiple programs one post? pp-TG Mastercam 4 07-12-2008 01:57 PM
How do I post multiple images in my thread? Rekd CNCzone.com FAQ 0 04-03-2004 05:10 PM
post multiple pictures georgebarr Forum Questions or Problems 2 02-26-2004 01:23 AM
