Old 07-14-2010, 07:30 PM
rckdef is on a distinguished road
G-Code fo 3-Axis Mill
I need a 3-Axis Mill program to check out my Torchmate Machine.
Can anybody tell me where i can download one. Something simple
will do! rckdef
Old 07-14-2010, 10:59 PM
n174k is on a distinguished road
Try this.
File Type: txt CIR DIA SQ.txt‎ (684 Bytes, 133 views)
Old 07-16-2010, 06:15 PM
3-Axis Mill
Thats great but i would like to try something a little more complicated
like the shape of a computer mouse. A shape with changing curves
My interest is in cutting foam shapes for molds of aircraft parts.
I would like to check out this machine before investing in more software.
If anybody can guide me to a G-Code i can download to to do this check
i would be happy........ Thanks.......rckdef
Old 07-16-2010, 07:20 PM
MrWild is on a distinguished road
How much can you spend? How much time do you have? None are stone simple for what you want. 3D can go the limit of $$$$ free to over 20k.
HeeksCAD is free
Vectric Cut3D is $400
MasterCAM is 14k
Cut3D is easiest to pick up for CAM, but what do you have for CAD? Again, free to $$$$.
Old 07-16-2010, 10:13 PM
psychomill is on a distinguished road
.... Boy, ain't that rich?
From
Something simple
will do!
To
(I know.... not helping this.... Carry on!) ..
It's just a part..... cutter still goes round and round....
Old 07-17-2010, 02:22 AM
It is simple once you've spent time figuring things out, and I just had a brain fart. Vectric has trials and include examples that will spit out code for you. My first 3D on the JGRO was the rooster in Cut3D. Very simple and easy to set up.
Old 07-17-2010, 12:09 PM
3-Axis Mill
My CAD is Solidworks, i do not have a CAM yet. First i want to mess around
with a bit of Code to see how my Torchmate machine handles it. I am capable
of programing simple 3-D objects OK. A part with multiple curves ? i don't
know. Thats why i would like to see a bit of code to get a better understanding of it. Any suggestion!
rckdef
Old 07-19-2010, 05:50 PM
3-Axis Mill
MrWild
Your brain fart worked very well! I liked the Rooster, plenty curves.
It seems simple enough. i lucked out on the postprocessor they did
not have one for the Torchmate but there was one with a fgc.
extention which Torchmate uses. So 3-D Cut will work in Torchmate
Thanks rckdef
Need Help!- 4th axis code? revlimit Haas Mills 14 06-05-2010 09:32 PM
Need Help!- 4 axis g-code help THend G-Code Programing 3 03-25-2009 06:27 PM
G code help C-X axis slkret G-Code Programing 1 05-10-2008 08:53 AM
zero axis key code? drafterman Mach Software (ArtSoft software) 2 03-06-2008 08:18 AM
Z-Axis Arc G-Code? GTmike400 G-Code Programing 16 01-27-2006 11:15 AM
