Old 07-10-2010, 05:39 AM
vagelism22678 is on a distinguished road
g code multiplier
Hello to all.
I am new to CNC hobby. I have an axminster x2 milling machine and now I am making my first steps to gcode.
I wonder if there is a free program that multiplies the gcode in a scale that the user needs.
For instance I have an image converted to gcode and I need to make it bigger 5 times. The hard way is to multiply each step individually but takes time...and many mistakes can occur.
Thank you for your time.
Old 07-10-2010, 06:16 AM
ger21's Avatar
If you use Mach3, you can scale each axis by a factor of 5.
Old 07-10-2010, 06:26 AM
GCODE MULTIPLIER
Well I make my first steps here so I dont work with any cad cam program.
I use a ready sample of gcode and I run it with turbocnc.
Thank you.
Old 07-10-2010, 09:28 AM
H.O H.O is offline
H.O is on a distinguished road
Like Gerry says, if you're using Mach3 as the controller you can enter 5 as the scale for the X- and Y-axis in the scale DROs on the screen. If you're using a control software that doesn't have this feature a cruel and dirty way of doing it is to simply change the steps per unit so that the machine moves 5 times as far as it's commanded to.
/Henrik.
Step Pulse Multiplier RotorRouter Gecko Drives 15 08-02-2010 01:00 PM
Step multiplier, Why use it ? Larken Viper Servo drives 1 03-03-2009 11:13 PM
pulse multiplier Beyazbalina Stepper Motors and Drives 0 03-25-2007 04:37 AM
Multiplier confusion Mike F Servo Motors and Drives 2 01-03-2005 01:36 PM
G340 multiplier gbon2 Gecko Drives 7 12-15-2004 09:26 AM
