Old 07-06-2010, 11:35 AM
ED209's Avatar
ED209 is on a distinguished road
Heidenhain CYCLE 19 Work Plane Tilt
I'm looking at cutting a dovetail that is tilted 10 degrees to the X-Y plane on the X-axis. I was wondering if someone could explain how the CYCLE 19 Working Plane function works. The machine is a 5-axis machine with a nutating head (B & C axis, with an A-axis rotary on X-axis). The control is a TNC 530, we also have a TNC 426 on a similar machine. Do I program the dovetail as if it was on the X-Y plane then tilt the B-axis 10 degrees & call the CYCLE 19 Work Plane Tilt & the control will take care of the change in coordinates or do I have to calculate the new coordinates based on the 10 degree tilt ?. Any & all input would be appreciated as I am very new to this 5-axis stuff.
Thanks.
Old 09-04-2010, 11:36 PM
kwanthay is on a distinguished road
Thanks.
Cycle 19 is good but plane spatial is better. Try to use plane spatial and you'll find that it's better and easier than 19.
Heidenhain iTNC 530 G200(pecking cycle) DULING G-Code Programing 3 02-02-2011 09:27 PM
Need Help!- Probing cycle ( heidenhain 530 ) mrdom General CNC (Mill and Lathe) Control Software (NC) 1 07-04-2009 02:18 AM
Need Help!- Heidenhain iTNC530, how to change plane? Martynas2 G-Code Programing 1 11-23-2008 09:58 AM
Mill/turn Multi axis work plane question bassn_07 Esprit 9 06-01-2008 03:07 AM
Help Tapping Cycle. Coolant off Heidenhain Roni General Metalwork Discussion 1 03-10-2007 01:22 AM
