Old 06-26-2010, 04:45 PM
vagelism22678 is on a distinguished road
IGS FILES TO GCODE
Hello to all.
I am new to this hobby.
I have built a cnc axminster x2 milling machine and I have some 3D modeling files.
So now the next step...How I will make this file to g-code?
This is a 3d model and I want to make it g-code in 6 different steps, one for each side of the metal piece that I have.
Any idea? What software may I use?
THANK YOU FOR YOUR TIME.
Old 06-26-2010, 04:48 PM
harley4ever is on a distinguished road
Try surfcam. Not sure what your looking to spend tho.
Old 06-27-2010, 02:50 AM
I want to transfer this 3d shape to a piece of metal. I think it will need more than 10 tools and manyt times to turn the piece upside down or left write because I have only a 3 axis machine.
So I want a program to generate all this work for me and prompt me any time I have to change tools and change the side of the piece.
Thank you!
Old 07-06-2010, 09:11 PM
Cknoble1 is on a distinguished road
It's a little more complex than that...
You first need a software like mastercam or some other programming software.. One you have the software... you need to import your iges files, set your origins and set tool operations for each process. If you get the software and need help. I would be more than willing to assist you. Topic is too broad right now.
3d cad files to gcode eloid DIY-CNC Router Table Machines 1 07-15-2009 09:43 PM
Need help converting dxf files to Gcode Jackflash65 LazyCam 0 12-02-2008 08:25 PM
Converting Illustrator files to Gcode files acoop101 General Metal Working Machines 1 06-05-2008 03:53 PM
Newbie- Need suggestions for massaging simple GCode files. AluminumDave G-Code Programing 13 03-09-2008 07:01 AM
I have a problem with my gcode or my conversion to gcode , everything is tiny? NickLatech G-Code Programing 0 03-10-2005 12:46 PM
