| G-Code Programing Discuss G-code programing and problems here! |
I'm learning g code. I'm capable of a few simple things like cutting out a square or circle in absolute or incremental mode. I can transfer to a subroutine and back. I can drill holes etc. I want to hog out the center of a box and leave the wall at the thickness I want. Actually, I can already do this, but I only know how to do it using a plunge in the z axis to the depth needed. What I want to know is how to do a ramp cut. Let's say I've already moved to 1,1 and I've got the spindle 0.100 above the surface area I want to hog out. I've already got cutter comp on and coolant on. I want to do my ramp CUT from X 1.0 Y 1.0 TO X5.0 Y 1.0 WHILE RAMPING IN THE Z AXIS DOWN 0.15. What is the correct syntax please? Thanks in advance, Gary |
| Plunge entry is not possible with an endmill because it does not have cutting edges at the center of the bottom. Ramp entry with, say, 10 degree angle, or helical entry (provided you have helical interpolation available on your machine) would need to be done. Or, use a slotdrill. |
| G41 has no role to play in entry. After entry to desired depth, G41/G42 would need to be invoked for lateral machining. If you are using a slotdrill, just a single move G01 Z_ F_ to the desired depth would do. |
| Part of my confusion was about wanting to keep X and Y absolute while making z incremental at the same time. I've got that sorted out now. We tested my program last night and it worked great! I agree that cutter comp is not required to make it work. We wanted to use a ramp cut for the tool we selected. It seems some end mills are designed with cutting sides so they can be used as slot drills too. The shop I used deliberately buys their end mills with cutting sides for their applications. The terminology gets a little muddled as a result, but thanks for helping to make sure we used the appropriate tool. Thanks for the reply and your help!. |
Cheers, BW
__________________ Try G-Wizard Machinist's Calculator for free: http://www.cnccookbook.com/CCGWizard.html |
| Slotdrill: slot + drill You can machine a slot as well as drill a hole. Typically, a slotdrill has 3 flutes whereas an endmill has 4 (perhaps because the chips during drilling would come out more easily if the helix angle is large). A slotdrill has less rigidity. Moreover, it has to run at a higher RPM. |
Traditionally, a slot drill will have 2 flutes. It's become moot though, because at this stage any endmill that has cutting edges such that it can plunge may be referred to either as a slot drill or a center cutting endmill. As I said, it is more common to use the term center cutting endmill in the US and slot drill overseas. See for example John Stevenson's excellent account of how this came to be: http://groups.yahoo.com/group/CAD_CA.../message/37726 Cheers, BW
#10
| Thanks also for the link which has a nice discussion. |
#11
I've been working with NCPlot V1.2 and another simulator called CNCsimulator by Microtech. CNCsimulator is more robust, but doesn't know what to do with subprogram calls or subroutine calls. I've also tried to work with a simulator that is available to when you buy training modules at immerse2learn.com but it seems to be in the middle of some kind of development problem at the moment. It looks great, but after lots of attempts, I just can't get it to install. Is there a well known and reliable CNC software simulator out there that knows most of the drilling variants and can do subroutines at least? |
| easy Newb question | aslatte2 | Mechanical Calculations/Engineering Design | 4 | 03-26-2010 05:10 PM |
| Need Help!- *Easy* V21 point translation question. :) | speedofsound | BobCad-Cam | 4 | 06-19-2008 09:05 PM |
| easy wiring question | swarfmacdaddy | Stepper Motors and Drives | 4 | 01-12-2008 04:01 PM |
| Easy question, Hard solution | CBNDude | Mechanical Calculations/Engineering Design | 11 | 06-10-2005 01:04 PM |
| easy to answer question | senor J. | Mach Software (ArtSoft software) | 2 | 01-27-2005 06:34 PM |
