Old 06-11-2010, 02:53 AM
yaji63 is on a distinguished road
Exclamation Help needed for incremental line numbering of a Gcode program
i have a peculiar requirement on one of my Fanuc machines. The machine supports Program restart, if by any chance there is an interruption, but i have to go to the line number (N & Number) where the program had stopped before interruption. This works if the programs has less than N9999 but most of my programs are much larger and hence the line number repeats and this is a problem.
I wanted to know if anyone out here knows any software or has a VBA piece of code which can add line numbers only at an increment of 100 lines or 1000 lines. this will solve my problem as even if i end up repeating a few lines it will not be as bad as running the whole program again or getting down to editing the program which is again a risk.
i did try using excel macro but excel does not support lines more than 69,000 and i have programs which have many more lines than these. I do know this is possible by taking a text file (NC program) and renumbering it by using excel as a front end tool through VBA macros but could not find a method to fulfill my requirement as i could not find codes to work on external files within excel.
Any help will be greatly appreciated
thanks a ton
Old 06-11-2010, 03:05 AM
P.Passuello's Avatar
P.Passuello is on a distinguished road
Have a look at NCPlot.
If memory serves me right the free version of NCPlot can add line numbers to a GCode file.
http://www.ncplot.com
Cheers
Peter
The ingenuity of idiots is unlimited.
http://www.youtube.com/user/cncnutz
Old 06-11-2010, 07:41 AM
Cheers
Peter
It is not about adding line numbers to every line but adding line number (N & numerical - Eg. N100 ) for every 100 lines or 1000 lines. This is not something which is available with most softwares.
Old 06-11-2010, 08:20 AM
Boots is on a distinguished road
What I have done in the past is only number the line where there is a tool change. You can MDI the proper tool into the spindle then do a search for the N number for that tool. Sence we only had a 20 tool changer it was easy to just have 20 N numbers. The N number matched the tool number so it's easier to search for your proper starting point. Every one has their own method......that was mine.
We all live in Tents! Some live in content others live in discontent.
Old 06-11-2010, 11:41 AM
stevo1 is on a distinguished road
I agree with Boots. I don’t know of any software that can add an N() every 100 lines. What Fanuc control do you have?
I do as Boots said. I don’t like all the N() addresses at every line so my machines are set to not enter them. Once my code is complete I put a N() at each operation/tool change.
Depending on your control you can start at various codes and not just the N(). Example some controls will allow you to start at an M6 for the tool change or on a comment in () parenthesis. IIRC even on a M1 or M0.
Stevo
Old 06-11-2010, 12:28 PM
HuFlungDung's Avatar
Moderator
If it were a really long program, using only 1 tool, I suppose you could break it up into sub program calls every 9999 lines. Hopefully, there is a place on the screen where you can see what the subprogram number was when you had to stop execution.
Old 06-11-2010, 08:12 PM
Kiwi is on a distinguished road
You may want to look at writing a small program using mawk programing language.
Old 06-12-2010, 03:55 AM
Don Diegoo
F.Sharifi is on a distinguished road
dear all
with CIMCO edit software you can oden file then with NC Function and insert Block Nr. ( Ctrl +T) all file inserted with incrimental block nr.
check it out
F.Sharifi
Old 06-12-2010, 09:15 AM
dcoupar's Avatar
I believe you can restart at a sequence number (N) or a block number (B). Check your Fanuc operator's manual to see if your model supports this.
Old 06-12-2010, 05:20 PM
Suggest you try saving the code with increment of 0.01 or 0.001
  #11   Ban this user!
Old 06-12-2010, 08:31 PM
Torsten's Avatar
Torsten is on a distinguished road
Smile
Originally Posted by yaji63 View Post
thanks a ton
Maybe a quick Qbasic program would work for you.
Qbasic came with the older versions of windows but still runs in XP.
try this.
INPUT "Input Filename "; Infile$
INPUT "Output Filename "; Outfile$
IF Outfile$ = "" THEN Outfile$ = "Numbered.txt"
IF Infile$ <> "" THEN
OPEN Infile$ FOR INPUT AS #1
OPEN Outfile$ FOR OUTPUT AS #2
N& = 0: I = 0
WHILE NOT EOF(1)
LINE INPUT #1, BLOCK$
I = I + 1
IF I = 100 THEN
N& = N& + 1
N$ = "N" + MID$(STR$(N&), 2, LEN(STR$(N&)))
PRINT #2, N$ + BLOCK$
I = 0
ELSE
PRINT #2, BLOCK$
END IF
WEND
CLOSE
PRINT "Finished renumbering " + Outfile$
END IF
PRINT "Program Exit"
  #12   Ban this user!
Old 06-24-2010, 11:51 PM
sinha_nsit is on a distinguished road
Yes. He appears to be using a CAM software with very fine resolution. This increases file size, as well as effective feedrate. A larger step distance may be considered.
If nothing works, the toolpath part of the program would need to be broken into several subprograms, to be called sequentially, as already suggested. The main program would be hardly a 50-line program.
fadal cnc 88 program limitation at line 734? Runner4404spd Fadal 12 03-04-2009 08:21 AM
Line numbering for mach3? fatal-exception ArtCam Pro 5 07-11-2008 10:18 AM
Incremental circle milling sub program Diggs G-Code Programing 25 01-07-2008 06:03 PM
Enable line 1 , gcode? Konstantin Mach Software (ArtSoft software) 6 07-29-2006 01:09 PM
line numbering xairflyer G-Code Programing 4 05-10-2005 02:22 PM
