Old 06-10-2010, 06:29 AM
welderfabrod is on a distinguished road
G02 G03 in MDI EMC2
Hi Guy's trying to cut an arc in EMC2 MDI without much luck.
I just need a arc that runs into a bore to create a bellmouth for the intake for a small jet engine sound simple enough. But for some reason not so.
My Lathe is in Radius mode.
The bore is 38.9mm. dia. the arc has a radius of 11.800mm. The arc starts at X27.535 Z0 which is where I position the cutter before commanding the G03 and ends at X19.450 Z-11.200 so my centre offsets are X3.715 Z-11.200
So My Gcode is G03 X19.450 Z-11.200 I3.715 J-11.200
What I get is the error Start=(X27.535 Y0.000), Centre=(X31.25 Y-11.200), End=(X19.450 Y0.000) r1=11.8001 r2=16.269
First thing is why does the error show Y instead Z when I'm in lathe mode.
Second whats wrong with my Gcode.
I tried to put this on the EMC2 forum but kept getting error in email message.
Any ideas Thanks Rod
Old 06-14-2010, 04:19 AM
Nobody have any ideas of this problem.
Rod
Old 06-14-2010, 07:39 PM
Torsten's Avatar
Torsten is on a distinguished road
Try this
G01 X27.535 Z0.
G18 G03 X19.45 Z-11.2 I3.715 K-11.2
Old 06-15-2010, 03:23 AM
Thanks Torsten I posted this on the EMC2 forum as well I got the same answer from John. But why should a G18 be needed when I'm set up in lathe mode and therefore surely always in G18. John also struggled with this for a while apparently. This can be very confusing. Perhaps its just a legacy thing as I believe EMC2 was inteneded for mills when it was originaly writen.
I'm going to try the G18 today.
Thanks Rod
Old 06-15-2010, 02:14 PM
Thanks torsten worked fine just put the J in out of habbit from the mill, bit dumb I gues. but I hadn't realised I needed the G18 if I was in lathe Mode.
So thanks for that.
Rod
Need Help!- EMC2 Jamy LinuxCNC (formerly EMC2) 32 08-17-2009 11:03 PM
Newbie- 3D DXF EMC2 or 2D only? klaymonster LinuxCNC (formerly EMC2) 7 01-14-2009 04:22 PM
EMC2 Jamy General CAD Discussion 2 12-11-2008 12:02 AM
Need Help!- M8 still not being red by EMC2 SpeedsCustom LinuxCNC (formerly EMC2) 27 04-13-2008 03:36 PM
EMC2 to diy CNC dakiller322 LinuxCNC (formerly EMC2) 11 10-05-2007 12:16 AM
