Old 05-14-2010, 04:21 AM
Dale gribble is on a distinguished road
Problem with mirror images
Hi, I making the letter Z from three pieces of M.D.F. 18mm thick. if you see the cad image, I created the middle Z first then added dowel holes, then copied the one to the right. I then mirror imaged the one to the left. When cutting on my router I drilled through the middle Z and then only half way on the two outer Z's. These holes are for lining up when gluing. I then cut the Z out with tabs to hold the part.
The middle and the copied Z to the right are the same shaped, but my mirrored image Z to the left is a different shape in places, see photo's of misalignment. I'm racking my brain to find out whats going on. It's seem something to do with the mirror image. I've also cut an A using the same process which had the same problem. I'm using the camware to calculate the cutter compensation which is mastercam x3. Machine operating system is Mach 3. Any insight to this problem would be gratefully recieved.
kind Regards
Dale gribble
Name:	Z CAD DRAWING.JPG‎
ID:	107151   Click image for larger version
Name:	PLAN VIEW OF Z small.jpg‎
ID:	107152   Click image for larger version
Name:	MISALIGNMENT OF Z small.jpg‎
ID:	107153   Click image for larger version
Name:	MISALIGNMENT OF Z 2 small.jpg‎
Old 05-14-2010, 06:49 AM
christinandavid's Avatar
christinandavid is on a distinguished road
If you have used a straight-forward mirror image then you will be moving the cutter clockwise around one part and counter clockwise around the other. The cutter could be deflecting off centreline, digging in one part and pushing off another. This effect could be more pronounced on tighter radii with higher surface speeds.
DP
Old 05-14-2010, 12:54 PM
Hi, DP
I've programmed both images to cut clockwise / climb mill, and yes you are right they are two different images and will have different cutting forces in various places. It's not clear as to the scale of the parts from the pics but these are 200mm 8" high, and the misalignment is 1mm / .04". a lot of deflection. I roughed out all three images out first plus .1mm / .004" then finished with two .05mm /.002" passes. feed-rate is 4000mm/m 157"/m @ a depth of cut 1.5mm / .06". I'll do some trials just cutting the mirror image and make sure the finishing cuts are cutting all the way round the part, I my need to leave more on and do more finishing passes. the router cutter is a long series, this could be a wee bit shorter. After saying all of the above the finish on the part is crisp and shows no sign of digging in or push off.
Dale
Old 05-15-2010, 07:00 AM
I think you've eliminated that possibility then...
Suggest you mirror a simpler symmetrical shape with datum on centreline and check that the software is pumping out the same figures for mirror image/non-mirror image.
DP
Old 05-15-2010, 11:05 AM
Good idea, I'll try that.
Regards
Dale
Old 05-18-2010, 12:23 PM
Hi, sorted the problem.
I checked out the cam ware by mirroring a square and g code was fine. it then occurred to check the squareness of gantry, it was out. the error was adjustment of one of my home switched on one of my dual lead screws. I made a fine adjuster with an m6 bolt in stead of just knocking the switch left or right. Also none of my three squares I had at home to check it were, well, square. I got my hands on a calibrated square and the machine now runs fine. I've only had the machine up and running for 2/3 months and all my part so far have been one offs and until you make multiples of the same parts then that shows up any errors with your machine set up. also mirroring image will double any out of squareness. thanks for your help DP
Regards
Dale
images aprentiss HURCO 1 10-12-2008 09:18 AM
Importing Images .bmp, .jpg chase78 Mastercam 13 05-08-2007 09:18 AM
None of images showing up rustamd Forum Questions or Problems 3 03-16-2007 11:37 AM
Problem uploading images for new thread! widgitmaster Forum Questions or Problems 1 07-15-2006 11:49 PM
Attached images? jharmon Forum Questions or Problems 7 11-16-2005 11:31 AM
