Old 05-14-2010, 01:41 AM
millcat is on a distinguished road
Red face 5 axis rigid tap
with fanuc 30i, will following work?
G0 G54 G90 X0 Y0 A0 B0 M3 S840
G43.2 Z3. H1
Y-2. A-10. Z.5
GO1 Y-1. Z-1. F30. ( Y, Z ARE NOT TRUE, JUST PLACEHOLDERS)
Y-2. Z.5 M04
G0 X0 Y0 A0 Z3.
OF NOTE IS LACK OF G84.1
BUT G84.1 DOES A Z DOWNFEED SO I DON'T SEE HOW I COULD BE USED
FOR A VECTORED HOLE.
I DO SEE HOW IT COULD WORK BECAUSE IT REVERSES OUT ON SAME
VECTOR. MY CONCERN IS PREPRATORY COMMANDS HANDLED BY G84.
SUCH AS FEED SPEED OVERRIDE DISABLE, IPR(G95) VS IPM, MAYBE A G8
(DISABLE RAMPING) AND OF COURSE M04.
FOR A SHORT WHILE I HAD A MASTERCAM X4 5-AXIS EVAL POST.
IT HAD A G169 5-AXIS DRILL TAP CYCLE BUT THE POSTED CODE LOOKED
AS ABOVE AND THE 30i MANUALS HAVE ONLY G84, (AND G63 OF WHICH I'M
NOT FAMILIAR) AND I COULD FIND NO DESCRIPTION OF A 5-AXIS DRILL
TAP CYCLE IN DOCS.
IS THIS MY ONLY CHOICE AND IF SO HOW DO I HANDLE FEED SPEED
OVERRIDE?
THANKS
Old 05-16-2010, 01:17 PM
Jonnis is on a distinguished road
Not sure if this helps.. but in my mori seiki i just use the G68.1.. it tilts the coordinates.. and then i can use drill and tap cycles in any degrees
What exactly is Rigid tapping? Why people always ask does it do rigid tapping? cjchands General Metalwork Discussion 23 12-19-2008 08:19 AM
V-RAM vs RIGID RAM jshank Bridgeport and Hardinge Mills 13 06-01-2008 08:19 AM
Rigid tap 100 Haas Mills 7 05-11-2007 11:53 AM
Tl-1, Rigid Tap DEAN Haas Mills 9 02-10-2006 04:12 PM
The most rigid 4-5 axis design Zathras General Metal Working Machines 15 10-12-2005 09:16 PM
