Old 05-11-2005, 05:21 PM
CNCRob's Avatar
Moderator
CNCRob is on a distinguished road
Question M code question- Whats the difference?
I was wondering what exactly is the difference between m0 and m01. Thanks-Robbie
Old 05-11-2005, 05:33 PM
MetLHead's Avatar
Gold Member
MetLHead is on a distinguished road
Robbie,
M00 is program stop. The program pauses at this code and waits for cycle start.
M01 is optional stop. The program pauses at this code only if the optional stop switch is on. This switch is usually located on the operators control panel.
Hope this helps,
Scott
Old 05-11-2005, 05:37 PM
Bear is on a distinguished road
Hi,Rob
some machines dont recognize M0,but do M1.some machines must have optional stop
switch turnned on to work and some turn off coolant & stop.
Bear.
Old 05-11-2005, 07:30 PM
DAB_Design is on a distinguished road
Another way to say it, is that M0 (program stop) is a forced stop. Spindle, coolant and movement stop and wait for cycle start.
M01 (optional stop) is at the operators discretion to stop. If the optional stop switch is on, then it acts as an M0. If the switch is not on, the control ignores it and continues on.
But as Bear points out, some controls handle things differently.
Dustin B.
I hear and I forget.
I see and I remember.
I do and I understand.
Old 05-12-2005, 05:28 PM
CNCRob's Avatar
Moderator
Hey Everyone, thanks for all of your answers. Im starting to make since of it. Is the optional stop switch a physical switch or a soft switch. Thanks-Robbie
Old 05-12-2005, 05:57 PM
psychomill is on a distinguished road
It can be either,.... even a 'button' and I've seen them on a key switch as well. Depends on your controller and machine make.
Old 05-12-2005, 07:34 PM
CNCRob's Avatar
Moderator
Oh Ok, Thanks guys
Old 05-20-2005, 11:50 AM
Gunner is on a distinguished road
Another thought on this subject is the uses of M00 and M01. An M00 would be used in instances where you want to stop the machine on every cycle, say to flip a part from side one to side two or remove chips that build up on a tool each time it does its operation. An M01 is normally programmed after every tool operation. In this way you can option option stop the machine after each op to check dimensions prior to the next tool starting. It's especially useful during setups and troubleshooting.
Gunner
Old 05-20-2005, 03:25 PM
CNCRob's Avatar
Moderator
Thanks Gunner
looking for g code 3d from bobcadcam or simmilar for indexer lpt v5 with g code soft troyswood Ability Systems - LPT Indexer and G-Code 2 12-24-2006 09:21 PM
parametric programming Karl_T CamSoft Products 21 05-24-2005 02:58 PM
Newbie question sdrc92126 Benchtop Machines 3 09-02-2004 02:11 AM
I need sample G code program bunalmis G-Code Programing 1 08-24-2004 03:50 AM
Getting The Most Out of CNCzone's Posting Features CNCadmin CNCzone.com FAQ 0 03-01-2003 11:08 PM
