Old 04-27-2010, 05:46 PM
santivelez is on a distinguished road
DeskCNC can't import .DXF file from Corel Draw
Hello
I'm new in the CNC industry.
I have several crown molding figures the machine seller gave me.
He said I could edit the .dxf file in corel to make a file withe multiple shapes instead of only one, then use deskCNC to make the g-code and then cut them using Mach3.
I bought all the softwares needed, and when I load the single crown files he gave me, everything works fine, but after making the new edited file with the various shapes in corel, and exporting it as a .dxf file, when I import it in deskCNC I get the following error:
A SPLINE was detected but not read. Explode all SPLINE'S before loading
I've never used these softwares before, so I'm a bit confused and frustrated.
I would really appreciate it if anybody can help me out.
I'm using Corel Draw X4, deskCNC, and Mach3.
Thank you very much and please excuse my bad english (I'm from Colombia, South America)
Santiago
Tags
corel, coreldraw, deskcnc, dxf, g-code
Newbie- Corel draw medicsteele Laser Engraving & Cutting Machines 3 06-13-2009 11:15 AM
Corel Draw 12 millman52 General CAD Discussion 4 11-17-2008 10:24 PM
Learning Corel Draw 12 Bigtoy302 CNC Plasma and Waterjet Machines 3 03-06-2008 04:14 PM
Corel Draw x3 Export to dwg - import to ALibre Design - not editable cnc_gary Alibre Design 5 09-29-2007 10:34 AM
Where to get Corel Draw? WarrenW General CAM Discussion 7 12-29-2005 03:07 AM
