Old 04-19-2010, 07:13 PM
briker is on a distinguished road
Move G54 form program
Hi guys I am new in this so i would appreciate any help.
all programs I have, are written from top of the work part and I always have to measure tools (height) for every part. So i would like to measure tools on table (bottom surface of part) and add height difference in program if it's possible.
...move G54 from program or something...
Old 04-19-2010, 10:41 PM
HuFlungDung's Avatar
Moderator
You can set your tools to any guage height that you wish. There is no requirement to use the top of the job. The difference between the gauge height and the job height goes in the Z register of your current work offset.
I would advise that you use a gauge height that is higher than your top of job to set your tools to, rather than directly to the table. This is because some controllers will give you grief if you do a toolchange and the machine executes the length offset as a distinct machine motion which will send the tool to Z0 of the current work offset. So if you set all the tools to a gauge above the job height, then you can avoid those crash situations. Some machines don't have enough travel to set a stubby tool directly to the table, anyway.
Old 04-20-2010, 10:29 AM
dcoupar's Avatar
Hope this helps.
The G54 Z can be any Work Coordinate (G54 - G59, etc.)
Name:	VMC Tool Setting.jpg‎
Problem- OI-TB move part program load to pendant BAFJB Fanuc 4 02-02-2010 03:35 PM
X axis handle jogs, but won't move in program WillRitter Haas Mills 10 10-25-2009 12:01 PM
Need help to program 4th axis move garyatfj Mastercam 1 04-01-2009 08:04 PM
Form 20 A EDM ramigary EDM Machines 0 11-27-2008 02:31 PM
The X-Axles... to move or not to move! Wild4aces Mechanical Calculations/Engineering Design 1 03-18-2005 01:26 PM
