| G-Code Programing Discuss G-code programing and problems here! |
I have a very basic (3) axis Home Built Milling Machine. I drive the stepper motors with K-Cam from a Desktop Computer. K-Cam shows the out line of the part just fine, but when I put any diameter in ( G41 T001 ), it will only read the first 2 lines of code and stops!!? I used this format on another, very simple, out line, and it seems to work, but here it don't !!? I have ask this question on the Kellyware Forum, but no body responds? Any help would be much appreciated. [Tangs] % G90 M03 G17 G41 T001 G00 X0.44136 Y1.52635 G02 X.75154 Y1.59142 I1.48397 J-2.68099 G02 X2.23070 Y1.70326 I2.13091 J-6.81568 G01 X4.47936 Y1.70326 G01 X4.47936 Y1.45326 G01 X2.22936 Y1.45326 G03 X1.97936 Y1.20326 I2.22936 J1.20326 G01 X1.97936 Y.67052 G03 X2.22246 Y.42061 I2.22936 J.67052 G01 X4.07824 Y.36491 G03 X4.23909 Y.51678 I4.08290 J.52109 G01 X4.24348 Y.63493 G01 X4.66894 Y.62318 G01 X4.66453 Y.50424 G03 X4.81641 Y.34374 I4.82072 J.49993 G01 X5.58288 Y.32284 G01 X5.57598 Y.07294 G01 X2.25725 Y.16956 G03 X1.62836 Y.16293 I2.01989 J-7.25898 G03 X1.00620 Y.07372 I1.86606 J-3.71669 G01 X0.44136 Y1.52635 G40 M05 G00 X0 Y0 M30 |
| I use Mach3 G41 is "Start cutter compensation left" T001 is Tool 0001 This line "G02 X.75154 Y1.59142 I1.48397 J-2.68099" You have to have the controller in the right IJ mode "Absolute or Incremental" for this to work correctly If your using Cam the PP also has to be set so they are all reading from the same hymn sheet Phil |
| Don't use KCAM, but try adding a leadin move before the G41, and also try calling the T1 before the G41. I think you also had a G3 instead of a G2. Do you get an error? It seems to run fine in Mach3. [Tangs] % G90 M03 G17 T1 G0 X0 Y0 G41 G00 X0.44136 Y1.52635 G02 X.75154 Y1.59142 I1.48397 J-2.68099 G02 X2.23070 Y1.70326 I2.13091 J-6.81568 G01 X4.47936 Y1.70326 G01 X4.47936 Y1.45326 G01 X2.22936 Y1.45326 G03 X1.97936 Y1.20326 I2.22936 J1.20326 G01 X1.97936 Y.67052 G03 X2.22246 Y.42061 I2.22936 J.67052 G01 X4.07824 Y.36491 G02 X4.23909 Y.51678 I4.08290 J.52109 G01 X4.24348 Y.63493 G01 X4.66894 Y.62318 G01 X4.66453 Y.50424 G03 X4.81641 Y.34374 I4.82072 J.49993 G01 X5.58288 Y.32284 G01 X5.57598 Y.07294 G01 X2.25725 Y.16956 G03 X1.62836 Y.16293 I2.01989 J-7.25898 G03 X1.00620 Y.07372 I1.86606 J-3.71669 G01 X0.44136 Y1.52635 G40 M05 G00 X0 Y0 M30
| Also, what size is the tool? In Mach3, if the tool was larger than .1, it would'nt run correctly.
| Ger21, I re-wrote the program according to your suggestions. Nothing changes! I did notice one thing, I would go a couple of lines father if I set the tool diameter at .100, same with the way you wrote and the way it was originally written. That G03 move down in the program is correct, I'm climb milling and it's a counter clockwise move. When I designed this part, I made sure that all inside radiuses were larger than .125, in order to use a .25 end mill. You say it don't work with Master3 and a .25 Dai. end mill ! |
| OK, I figured out that your code is written with Absolute IJ mode, and I was running it in Incremental IJ mode. Once I switched, it runs fine in Mach3, even with a 1/4" tool. It's possible that it's a bug in KCAM, as it appears that comp is a newer feature in that software.
| G74 What am I doing wrong?? | Hennessy | General Metalwork Discussion | 4 | 01-24-2010 10:46 AM |
| What am I doing wrong | BOBINETTE | Mach Wizards, Macros, & Addons | 4 | 01-03-2010 12:49 AM |
| 10 IPM, am I doing something wrong? | jupdyke | Mechanical Calculations/Engineering Design | 8 | 09-16-2009 10:26 AM |
| Not sure what I'm doing wrong | chuy | Mastercam | 4 | 08-01-2007 03:28 AM |
| anyone know what i am doing wrong | pauluk | Digitizing and Laser Digitizing | 14 | 02-16-2006 10:48 AM |
