| G-Code Programing Discuss G-code programing and problems here! |
I bought a used vertical lathe Hitachi Seiki with Fanuc 20l. I have a problem with the c-axis programming. When I enter M19 in MDI spindle is placed in position, but I do not know how to after choose another position - 90 °. I tried the M19 c90 M19 C = 90 M19 S90 ,.... but nothing happens. Does anyone can tell me how to positioning spindle to 90 ° or to some other position. Thanks! |
| Thank you for your proposed solution. I tried everything, but does not place the spindle in the desired position. The only thing that works is that the spindle is placed in position in the order of M19 and there holds. |
M19 is used to reference the spindle - not the C axis. In spindle mode - M19 sends the spindle to 0. In C axis mode - M19 does nothing, but G1 C90 F? will move it.
__________________ The Fanuc Support Center Team www.fanuc-support.com |
| Are you just trying to orient the spindle with M19 or are you actually trying to do some machining on the part using c axis? Here is a simple center drilling operation using c axis for your reference if this is what you are trying to do. This is for a Mori with Fanuc control but maybe it'll work on your Hitachi. Rick (#2 C,DRILL) M5 M45 (Engage c axis) G0G28H0 (Zero c axis) G30U0W0 T0700 G97S875M13 (Start milling/drilling spindle) G98X1.4905Z1.1T0707M8C45.F100. (Position turret & c axis: must use IPM) Z.1 G1Z-.53F50. Z-.805F2.5 G0Z-.53 C135. (Position c axis) G1Z-.805 G0Z-.53 C225. (Position c axis) G1Z-.805 G0Z-.53 C315. (Position c axis) G1Z-.805 G0Z1.1 G30U0W0T0700M9 M5 (Stop milling/drilling spindle) M46 (Disengage c axis) M1 |
| PLC and motor for spindle positioning | Dan.antes | WoodWorking | 3 | 01-10-2010 10:26 AM |
| Servo and positioning | zdzisio1980 | Servo Motors and Drives | 2 | 08-15-2009 11:31 PM |
| Absolute Positioning | Cartierusm | DIY-CNC Router Table Machines | 28 | 10-07-2008 04:10 PM |
| 320 Positioning Error | elogicca | Gecko Drives | 2 | 07-08-2008 11:33 AM |
| Fanuc 18T positioning | bigalow | Fanuc | 0 | 11-06-2007 09:10 PM |
