Old 05-04-2005, 04:46 PM
crashwg is on a distinguished road
Where do I start?
Ok, so I'm quite intrigued by the whole concept of CNC routers and I'm hoping to build one in the next year or two.
When I do get arround to building one I want to be a seasoned profesional when it comes to G-Code though which is pretty much the purpose of this post.
I have autocad 2000 installed on my computer currently and I have 2004 & 2005 I believe somewhere arround my house, I would just have to find them.
I downloaded MicroTech CncSimulator the other day also so I should be able to test anything I can actually get converted into G-Code once I figgure out how that program works!
So that's pretty much where I'm at now. I'd like to start of small, maybe just simulating 2D designs and working from there.
Now what? Are there any tutorials out there that would be helpful to someone with no experience like myself? Maybe some examples that the author has documented start to finish so I can see what goes into the whole deal?
Thanks in advance!
Old 05-04-2005, 06:03 PM
Bubba's Avatar
Bubba is on a distinguished road
Crashwg,
Personally, I think you are jumping ahead of the cart! If you want to LEARN g-code, I think you need to HAND CODE simple shapes first. Cad is fine, and you can plot out the shapes and then figure out how to do the code by hand.
Then, when you finally enter into the world of using a Cam program (converts the drawing file into G-code), you will be able to look at the coding to see where problems are if they occur.
Its kind of like learning to drive. If you learn on a standard shift, the move to an automatic is easy; however, I have seen cases of people who have learned to drive on an automatic that no matter how hard they tried could not master a standard transmission!
Art
Old 05-04-2005, 06:29 PM
Al_The_Man's Avatar
I agree, if you hand code some shapes and run them in the simulator, you can see the results. There are plenty of turorials on the web as in http://www.jjjtrain.com/vms/cnc_intro_code.html
I would suggest starting with simple linear and circular interpolated moves first and then include M codes such as spindle etc. Then progress from centreline programming to tool dia and length offset, followed by fixture offsets where the part zero is re-positioned.
Next canned routines such as peck drilling or threading.
For maximum flexibility, study macro and parametric programming which makes G code programming very powerfull.
I have two references I use which I find excellent, first is 'Computer Numerical Control Programming' by Michael Sava and Joseph Pusztai, try and get it if it is still in print.
The second which complements the first is 'Computer Numerical Control' by Warren S. Seames, published by SME.
Old 05-06-2005, 01:19 PM
corrie is on a distinguished road
Hello all I,ve got a ?Lets say I,m cutting out a square for example and my initial Z plunge is .25 into my material,after completing the four sides and coming back to the initial place where I first did my .25 plunge,do I have to add another .25 onto the initial .25 in order to plunge down .25 extra?Or do I write a new line of code with the addition.Cheers.
Old 05-06-2005, 02:10 PM
ger21's Avatar
It depends what you want to do. Are you asking how to mill the part? Tell us what you want the tool to do, or give us some sample code.
It's a good idea to start a new thread for a new question, rather than posting in a thread with a different (although similar) topic .
Old 05-06-2005, 04:24 PM
Hey ger21 sorry about that,what I want to do, is to have the router keep going along at different Z levels but from the start point each time.Somewhat spiral cuting along the same path.Was just wondering if a new z level was to be given from the start plunge or would that # take over from the other,thanks.
Old 05-06-2005, 05:36 PM
ger21's Avatar
Ideally, with a router, I try to never plunge straight down. It will burn up bits quicker and put a load on the router it wasn't designed for. (Assuming a standard handheld router). Try this:
G1 X0 Y2 Z0 (lower tool to top of workpiece)
G1 X0 Y0 Z-.25 (move to bootom left corner while ramping down)
G1 X2 Y0
G1 X2 Y2
G1 X0 Y2
G1 X0 Y0 Z-.5 (ramp down for the next pass)
G1 X2 Y0
G1 X2 Y2
G1 X0 Y2
G1 X0 Y0 (clean up the ramp)
Lift the tool.
This is just 1 way to do it. I think this is what you're asking, but I'm not completely clear. The above example uses absolute coordinates. You can also program in incremental coordinates, which would be relative from the previous positions.
Old 05-06-2005, 06:30 PM
Thanks Ger21 I,m going to give that a go.By what you stated you should give the Z a little more -Z to get the required depth that one is after.Cheers.
Old 05-06-2005, 07:27 PM
ger21's Avatar
Whatever depth you want, is the depth you set in the code.? The example I posted was making 2 passes to get to a depth of .5. That's what I thought you wanted to do.
Old 05-07-2005, 09:46 AM
g92 x0 y0 z0
g00 z0.1
g00 x.25 y6
g01 x14 y1 z-.125 f10
g01 x16.50 y2.50
g01 x14.25 y6.25
go1 y8.25
g01 x16.50 y12
g01 x14.50 y13.50
g01 x.25 y8.50
g01 y6 z-.125 f10
g01 x14.50 y1
g01 x16.50 y2.50
g01 x14.25 y6.25
g01 y8.25
g01 x16.50 y12
g01 x14.50 y13.50
g01 x.25 y8.50
g01 y6 z-.125 f10........g00 z0.1 Call me thick .So in a g1 lineal move you can include a -Z move?And if the line feed rate is lets say 10 does the Z feed become the same?Or does it not matter due to the fact that X and Y are in motion.does this code make sence.
Old 05-07-2005, 10:29 AM
ger21's Avatar
How deep do you want to cut? I think all your X14.xx should be the same.
A g1 move is a straight line from the current location to the position specified on the line. If the Z is a different depth, then the cut will ramp up or down. The tool will move at the specified feed rate along that path.
g00 z0.1
g00 x.25 y6
g01 x14 y1 z-.125 f10 (This should be X 14.25, or 14.5, not sure)
From this point on, everything will be at F10
g01 x16.50 y2.50
g01 x14.25 y6.25
go1 y8.25 (this line won't work, should be G zero. You have G (letter "O"))
g01 x16.50 y12
g01 x14.50 y13.50
g01 x.25 y8.50
g01 y6 z-.125 f10
g01 x14.50 y1
From this point on, you are repeating what you already did.
g01 x16.50 y2.50
g01 x14.25 y6.25
g01 y8.25
g01 x16.50 y12
g01 x14.50 y13.50
g01 x.25 y8.50
g01 y6 z-.125 f10
  #12   Ban this user!
Old 05-07-2005, 10:53 AM
Thanks,the material is 3/4 inch thick and I only want to cut down to about 7/8 of that.According to my drawing and the points that are plotted out there are two different X14,s one being x14.25 and x14.50.I,ll have to run it and see what becomes,thanks for your help.
Tools advice needed for start pigifly General Metal Working Machines 5 12-10-2009 03:18 PM
Cycle Start button kaleem1 Mach Software (ArtSoft software) 7 12-24-2005 02:05 PM
Cap start motor wiring kong General Electronics Discussion 8 05-25-2005 12:40 PM
Would like to built a twinn... need help to start. CrazyRonny I.C. Engines 5 03-09-2005 12:09 AM
Where is a good place to start? Binow DIY-CNC Router Table Machines 1 07-16-2004 02:52 PM
