03-04-2010, 05:00 AM
emt super 80 barfeeder problem | | Hi!
I have a problem with my bar feeder (emt super 80). We haven't used it since I came to this company, and I only have an instruction manual translated in very poor English. The bar feeders menu is in Dutch (!?) I know some German and I could understand the setting of parameters but l don't have any data for starting it in auto mode. And also have no clue of what l should write in the cnc program to make it work. The late has a Fanuc 20i system. Simply opening the chucks with M11 inside program wouldn't start the bar feeder. Pushing start cycle on the bar feeder while in auto mode is only possible when chucks are closed, and that has no logic, because when the bar hits the rear of the chucks the bar feeder gives me an error, and I don't think it should work in this way. So if anyone had similar problems or worked with such a bar feeder(emt super 80) and knows the way l should proceed with programing ant the bar feeder itself l would be very thankful.
Matyi |
