Old 02-24-2010, 07:40 AM
smaida10 is on a distinguished road
G19 Cutter Comp
Hello-
Is it possible to use cutter comp, on Z and X when cutting an arch on the YZ plane.
If possible could someone show me a program example of a cut on a YZ G19 cut, with tool length comp, and tool dia comp.
Old 02-24-2010, 08:09 AM
dcoupar's Avatar
Yes it is. G19 sets the workplane for both arcs and cutter comp. Please try the following example well above the part.
T1M6
G00 G54 X0 Y0 S5000 M3
G43 Z0.1 H1
G19 G41 Y-1. D1 (TURN ON COMP IN YZ PLANE)
G03 Y1. J1. (CUT 1" RAD. CW ARC)
G01 G40 Y0 (TURN OFF COMP)
G00 G17 Z1.0
beege's Avatar
beege is on a distinguished road
That depends upon your machine and control/options. Some only have XY comp available.
G00
G17G43H1Z1. (FOR THE TOOL HOLDER LENGTH)
G19G43H10X.1(FOR THE HORIZONTAL TOO LENGTH, TIP TO SPINDLE CENTERLINE)
G01X0F10.
G41D20Y0Z0(COMP LEFT OF PROFILE)
G02Y-.5Z0R.25 or G02Y-.5Z0J-.25K0
G01G40Y0Z1.
etc...
makes a semicircle on the left right of a block, Radius .25. Always picture the geometry in the G19 plane as if looking at it from the X positive side of the machine.
Cutter Comp Farmers Machine CamSoft Products 6 11-18-2009 10:33 AM
M2 cutter comp help nlh Mazak, Mitsubishi, Mazatrol 2 06-02-2009 11:59 AM
Cutter comp on an id hole< cutter diam.?? PaintItBlue Haas Mills 5 05-05-2008 06:30 PM
Cutter Comp? donl517 Fadal 5 07-03-2007 08:36 AM
18-it cutter comp newcinhypro Fanuc 1 01-25-2006 08:00 PM
