Need Help! M CODES AND G52
Results 1 to 3 of 3
Thread: M CODES AND G52
    Sep 2008
    Unhappy M CODES AND G52
    Hi everybody, i need your help i have to run this control and realized that works with different codes, like M51,1 is equivalent to M04 but i dont have idea of what do the rest of M codes mean, the codes are following:
    M51,n
    M52,n
    M54,n
    M55,n
    M56
    M57,n,t,n
    M58,n,t,n
    M59n,t
    M60,n,t
    M61,n,t
    M63
    M64
    M65
    M66
    M67
    M51,1
    M52,1
    THE ONLY brand name that shows up in the screen of the control is OMNICO CORP. CNC SYSTEM 2600 V. 5.2 thankyou for your time and help and if you know how to run it in single block it would be great , thank you.
    Registered gene rhodes's Avatar
    Nov 2008
    U.S.A.
    lathe? mill? 2-axis? 3-axis?
    Oct 2008
    united states
    there is a web site called hire tek contract cad/cam cnc programming that has some of the standard m and g codes for mills and lathe if you have a manual for your cnc it should have all of your g and m codes in it
M CODES  AND G52
M CODES  AND G52
