3dprintforums logo
CNCzone Network:  RFQwork :: 3Dprintforums :: Welderzone :: Google+ :: Our Facebook :: Twitter :: SiteMap
Results 1 to 4 of 4
Thread: 3/4"-14 npt exterior thread
    Oct 2007
    Rep Power
    Smile 3/4"-14 npt exterior thread
    Please help.....
    Looking for a program to do a 3/4"-14 npt exterior thread on a lathe. I cannot figure out from the machinery's handbook how to figure out the "x" number in the 2nd G76 line......
    Would someone explain how to come up the the "x" in the G76 cycle for both inside and outside threads. I can figure out the tapers to rough turn or bore the stock to. I can also figure out the "r" value in the G76 line, but not the x......
    PLEASE HELP!!!!
    THANKS!
    Registered Karl_T's Avatar
    Mar 2004
    Dassel,MN,USA
    Rep Power
    12
    Here is a blurb on G76 threading. If you are doing an NPT thread you will have to use the R(i) value to taper the thread. The value is an interger number with 1 being equal to .0001" and is the difference in radius from Z start to Z finish. Hope this helps you out.
    G76 P(m)(r)(a) Q(min) R(fin)
    G76 X(fin) Z(len) R(i) P(k) Q(1st) F(L)
    WHERE
    m = SPRING CUTS (01)
    r = CHAMFER AMOUNT(00)
    a = TOOL ANGLE (80 60 55 30 29 0)
    min = MINIMUM DEPTH OF CUT
    fin = FINISHING ALLOWANCE
    fin = ROOT DIAMETER
    len = LENGTH OF THREAD
    i = THREAD RADIUS DIFFERENCE
    k = THREAD HEIGHT (RADIUS)
    1st = 1ST CUT DEPTH
    L = THREAD LEAD
    Nov 2003
    canada P.Q.
    Age
    61
    Rep Power
    11
    which program are you using to drive your lathe..Turbocnc mach3 etc...
    Andy
    May 2007
    Rep Power
    7
    Programs are for a 45 degree chamfer at .890 diameter.
    .016R finishing tool
    X.8539Z0
    G3X.8836Z-.0062R.021
    G1X1.0288Z-.0787
    X1.05Z-.42
    Z-?
    .031R finishing tool
    X.8239Z0
    G3X.8748Z-.0105R.036
    G1X1.0284Z-.0873
    X1.05Z-.4348
    Z-?
    Threading cycle for a machine such as a Hardinge, Daewoo, Mori, etc.
    X1.08Z.3
    G76P000155Q30
    G76X.9575Z-.85P570Q130R-.0358F.0714
    Threading cycle for an older machine
    X1.08Z.3
    G76X.9575Z-.85I-.0358K.057D150F.0714A50.
    This should get you in the ballpark.
