Need Help! Spindle rpm - variations
Results 1 to 2 of 2
Thread: Spindle rpm - variations
    Nov 2011
    Sweden
    Default Spindle rpm - variations
    Hi all,
    I am running a vertical lathe, EMAG VSC400.
    Because of vibrations I want to use the $TIMER-function to increase and decrease the rpm by 10%
    I tried this but got a syntax error on line 33! (there is no line 33)!
    $AC_TIMER[3]=0
    WHENEVER $AC_TIMER[3]>=6 DO $AC_TIMER[3]=0
    WHENEVER $AC_TIMER[3]<=2 DO S130
    WHENEVER $AC_TIMER[3]>=4 DO S120
    N130 G1 Z50 F.1
    N132 G1 Z49 F.06
    N134 G1 X72 F.1
    N135 $AC_TIMER[3]=-1
    Regards/
    Jorma
    Nov 2007
    Canada and Nothern ireland
    Default Re: Spindle rpm - variations
    The machine has a look ahead function and reads ahead so it is seeing that error somwhere else
    use the "Stoppre" command to make it look to the last line before going forward
    Stoppre
    $AC_TIMER[3]=0
    N130 G1 Z50 F.1
    N132 G1 Z49 F.06
    N134 G1 X72 F.1
    Stoppre
    If the timer doesnt work increase or decrease by declaring the spindle speed as an "R" value and can be changes at random
    S=R900 (value in user global parameter )
