Need Help! Turning Hexagon on 2 axis Lathe
Results 1 to 4 of 4
Thread: Turning Hexagon on 2 axis Lathe
    Jul 2013
    Default Turning Hexagon on 2 axis Lathe
    Any know how to make these program for cutting hexagon or square on 2 axis lathe without using live tooling. Please send me program or any suggestions that can help
    https://youtu.be/DajrTlI8IWA
    https://youtu.be/R1LJ1yQBrKQ
    Feb 2013
    Brazil
    Default Re: Turning Hexagon on 2 axis Lathe
    Very, very interesting!
    Feb 2013
    Brazil
    Hello my friend, how are you?
    I was like it very much. And would like to help you.
    I tried to do some mathematical deduction about a square inscribed inside a circle and get some success.
    I will try to do this now using a hexagon but I think it will keep some mathematical rules about angles, etc.
    Turning Hexagon on 2 axis Lathe-square-01-jpeg
    Turning Hexagon on 2 axis Lathe-square-02-jpeg
    If you still have a CNC lathe we can do some tests do make it.
    Feb 2013
    Brazil
    Hello my friend, I have been working on this.
    I think I have got a solution.
    This is the mathematical solution for Hex.
    Turning Hexagon on 2 axis Lathe-hex1-jpeg
    Turning Hexagon on 2 axis Lathe-hex2-jpeg
    Basically there are 6 triangles inscribed inside a circle. Each triangle is 60 degress.
    d0 = R
    d15 = R . cos (30)
    d30 = R
    d45 = R . cos (30)
    it continues until the blank does a 360 degrees revolution.
    I thought as a tradicional: X-Z axis as a lathe.
    ** Z axis is the longitudinal axis - and is a continuous movement
    ** X axis is the transversal axis - and is a go-and-back movement (the important axis)
    ** A axis is the rotary axis - and is a continous movement (turning the blank).
    By that, the G-code will be like:
    Code:
    g0 x15
    x0 z5
    M3 S1000
    f800
    a0.000   z0.000   x9.955
    a1.000   z-0.000   x9.911
    a2.000   z-0.001   x9.866
    a3.000   z-0.001   x9.821
    a4.000   z-0.001   x9.777
    a5.000   z-0.001   x9.732
    a6.000   z-0.002   x9.687
    a7.000   z-0.002   x9.643
    a8.000   z-0.002   x9.598
    a9.000   z-0.002   x9.553
    a10.000   z-0.003   x9.509
    a11.000   z-0.003   x9.464
    a12.000   z-0.003   x9.419
    a13.000   z-0.004   x9.375
    a14.000   z-0.004   x9.330
    a15.000   z-0.004   x9.285
    a16.000   z-0.004   x9.241
    a17.000   z-0.005   x9.196
    a18.000   z-0.005   x9.151
    a19.000   z-0.005   x9.107
    a20.000   z-0.006   x9.062
    a21.000   z-0.006   x9.018
    a22.000   z-0.006   x8.973
    a23.000   z-0.006   x8.928
    a24.000   z-0.007   x8.884
    a25.000   z-0.007   x8.839
    a26.000   z-0.007   x8.794
    a27.000   z-0.007   x8.750
    a28.000   z-0.008   x8.705
    a29.000   z-0.008   x8.660
    a30.000   z-0.008   x8.705
    a31.000   z-0.009   x8.750
    a32.000   z-0.009   x8.794
    a33.000   z-0.009   x8.839
    a34.000   z-0.009   x8.884
    a35.000   z-0.010   x8.928
    a36.000   z-0.010   x8.973
    a37.000   z-0.010   x9.018
    a38.000   z-0.011   x9.062
    a39.000   z-0.011   x9.107
    a40.000   z-0.011   x9.151
    a41.000   z-0.011   x9.196
    a42.000   z-0.012   x9.241
    a43.000   z-0.012   x9.285
    a44.000   z-0.012   x9.330
    a45.000   z-0.013   x9.375
    a46.000   z-0.013   x9.419
    a47.000   z-0.013   x9.464
    a48.000   z-0.013   x9.509
    a49.000   z-0.014   x9.553
    a50.000   z-0.014   x9.598
    a51.000   z-0.014   x9.643
    a52.000   z-0.014   x9.687
    a53.000   z-0.015   x9.732
    a54.000   z-0.015   x9.777
    a55.000   z-0.015   x9.821
    a56.000   z-0.016   x9.866
    a57.000   z-0.016   x9.911
    a58.000   z-0.016   x9.955
    a59.000   z-0.016   x10.000
    a60.000   z-0.017   x9.955
    a61.000   z-0.017   x9.911
    a62.000   z-0.017   x9.866
    a63.000   z-0.018   x9.821
    a64.000   z-0.018   x9.777
    a65.000   z-0.018   x9.732
    a66.000   z-0.018   x9.687
    a67.000   z-0.019   x9.643
    a68.000   z-0.019   x9.598
    a69.000   z-0.019   x9.553
    a70.000   z-0.019   x9.509
    a71.000   z-0.020   x9.464
    a72.000   z-0.020   x9.419
    a73.000   z-0.020   x9.375
    a74.000   z-0.021   x9.330
    a75.000   z-0.021   x9.285
    a76.000   z-0.021   x9.241
    a77.000   z-0.021   x9.196
    a78.000   z-0.022   x9.151
    a79.000   z-0.022   x9.107
    a80.000   z-0.022   x9.062
    a81.000   z-0.023   x9.018
    a82.000   z-0.023   x8.973
    a83.000   z-0.023   x8.928
    a84.000   z-0.023   x8.884
    a85.000   z-0.024   x8.839
    a86.000   z-0.024   x8.794
    a87.000   z-0.024   x8.750
    a88.000   z-0.024   x8.705
    a89.000   z-0.025   x8.660
    a90.000   z-0.025   x8.705
    a91.000   z-0.025   x8.750
    a92.000   z-0.026   x8.794
    a93.000   z-0.026   x8.839
    a94.000   z-0.026   x8.884
    a95.000   z-0.026   x8.928
    a96.000   z-0.027   x8.973
    a97.000   z-0.027   x9.018
    a98.000   z-0.027   x9.062
    a99.000   z-0.028   x9.107
    a100.000   z-0.028   x9.151
    a101.000   z-0.028   x9.196
    a102.000   z-0.028   x9.241
    a103.000   z-0.029   x9.285
    a104.000   z-0.029   x9.330
    a105.000   z-0.029   x9.375
    a106.000   z-0.029   x9.419
    a107.000   z-0.030   x9.464
    a108.000   z-0.030   x9.509
    a109.000   z-0.030   x9.553
    a110.000   z-0.031   x9.598
    a111.000   z-0.031   x9.643
    a112.000   z-0.031   x9.687
    a113.000   z-0.031   x9.732
    a114.000   z-0.032   x9.777
    a115.000   z-0.032   x9.821
    a116.000   z-0.032   x9.866
    a117.000   z-0.033   x9.911
    a118.000   z-0.033   x9.955
    a119.000   z-0.033   x10.000
    a120.000   z-0.033   x9.955
    a121.000   z-0.034   x9.911
    a122.000   z-0.034   x9.866
    a123.000   z-0.034   x9.821
    a124.000   z-0.034   x9.777
    a125.000   z-0.035   x9.732
    a126.000   z-0.035   x9.687
    a127.000   z-0.035   x9.643
    a128.000   z-0.036   x9.598
    a129.000   z-0.036   x9.553
    a130.000   z-0.036   x9.509
    a131.000   z-0.036   x9.464
    a132.000   z-0.037   x9.419
    a133.000   z-0.037   x9.375
    a134.000   z-0.037   x9.330
    a135.000   z-0.037   x9.285
    a136.000   z-0.038   x9.241
    a137.000   z-0.038   x9.196
    a138.000   z-0.038   x9.151
    a139.000   z-0.039   x9.107
    a140.000   z-0.039   x9.062
    a141.000   z-0.039   x9.018
    a142.000   z-0.039   x8.973
    a143.000   z-0.040   x8.928
    a144.000   z-0.040   x8.884
    a145.000   z-0.040   x8.839
    a146.000   z-0.041   x8.794
    a147.000   z-0.041   x8.750
    a148.000   z-0.041   x8.705
    a149.000   z-0.041   x8.660
    a150.000   z-0.042   x8.705
    a151.000   z-0.042   x8.750
    a152.000   z-0.042   x8.794
    a153.000   z-0.042   x8.839
    a154.000   z-0.043   x8.884
    a155.000   z-0.043   x8.928
    a156.000   z-0.043   x8.973
    a157.000   z-0.044   x9.018
    a158.000   z-0.044   x9.062
    a159.000   z-0.044   x9.107
    a160.000   z-0.044   x9.151
    a161.000   z-0.045   x9.196
    a162.000   z-0.045   x9.241
    a163.000   z-0.045   x9.285
    a164.000   z-0.046   x9.330
    a165.000   z-0.046   x9.375
    a166.000   z-0.046   x9.419
    a167.000   z-0.046   x9.464
    a168.000   z-0.047   x9.509
    a169.000   z-0.047   x9.553
    a170.000   z-0.047   x9.598
    a171.000   z-0.047   x9.643
    a172.000   z-0.048   x9.687
    a173.000   z-0.048   x9.732
    a174.000   z-0.048   x9.777
    a175.000   z-0.049   x9.821
    a176.000   z-0.049   x9.866
    a177.000   z-0.049   x9.911
    a178.000   z-0.049   x9.955
    a179.000   z-0.050   x10.000
    a180.000   z-0.050   x9.955
    a181.000   z-0.050   x9.911
    a182.000   z-0.051   x9.866
    a183.000   z-0.051   x9.821
    a184.000   z-0.051   x9.777
    a185.000   z-0.051   x9.732
    a186.000   z-0.052   x9.687
    a187.000   z-0.052   x9.643
    a188.000   z-0.052   x9.598
    a189.000   z-0.052   x9.553
    a190.000   z-0.053   x9.509
    a191.000   z-0.053   x9.464
    a192.000   z-0.053   x9.419
    a193.000   z-0.054   x9.375
    a194.000   z-0.054   x9.330
    a195.000   z-0.054   x9.285
    a196.000   z-0.054   x9.241
    a197.000   z-0.055   x9.196
    a198.000   z-0.055   x9.151
    a199.000   z-0.055   x9.107
    a200.000   z-0.056   x9.062
    a201.000   z-0.056   x9.018
    a202.000   z-0.056   x8.973
    a203.000   z-0.056   x8.928
    a204.000   z-0.057   x8.884
    a205.000   z-0.057   x8.839
    a206.000   z-0.057   x8.794
    a207.000   z-0.057   x8.750
    a208.000   z-0.058   x8.705
    a209.000   z-0.058   x8.660
    a210.000   z-0.058   x8.705
    a211.000   z-0.059   x8.750
    a212.000   z-0.059   x8.794
    a213.000   z-0.059   x8.839
    a214.000   z-0.059   x8.884
    a215.000   z-0.060   x8.928
    a216.000   z-0.060   x8.973
    a217.000   z-0.060   x9.018
    a218.000   z-0.061   x9.062
    a219.000   z-0.061   x9.107
    a220.000   z-0.061   x9.151
    a221.000   z-0.061   x9.196
    a222.000   z-0.062   x9.241
    a223.000   z-0.062   x9.285
    a224.000   z-0.062   x9.330
    a225.000   z-0.062   x9.375
    a226.000   z-0.063   x9.419
    a227.000   z-0.063   x9.464
    a228.000   z-0.063   x9.509
    a229.000   z-0.064   x9.553
    a230.000   z-0.064   x9.598
    a231.000   z-0.064   x9.643
    a232.000   z-0.064   x9.687
    a233.000   z-0.065   x9.732
    a234.000   z-0.065   x9.777
    a235.000   z-0.065   x9.821
    a236.000   z-0.066   x9.866
    a237.000   z-0.066   x9.911
    a238.000   z-0.066   x9.955
    a239.000   z-0.066   x10.000
    a240.000   z-0.067   x9.955
    a241.000   z-0.067   x9.911
    a242.000   z-0.067   x9.866
    a243.000   z-0.067   x9.821
    a244.000   z-0.068   x9.777
    a245.000   z-0.068   x9.732
    a246.000   z-0.068   x9.687
    a247.000   z-0.069   x9.643
    a248.000   z-0.069   x9.598
    a249.000   z-0.069   x9.553
    a250.000   z-0.069   x9.509
    a251.000   z-0.070   x9.464
    a252.000   z-0.070   x9.419
    a253.000   z-0.070   x9.375
    a254.000   z-0.071   x9.330
    a255.000   z-0.071   x9.285
    a256.000   z-0.071   x9.241
    a257.000   z-0.071   x9.196
    a258.000   z-0.072   x9.151
    a259.000   z-0.072   x9.107
    a260.000   z-0.072   x9.062
    a261.000   z-0.072   x9.018
    a262.000   z-0.073   x8.973
    a263.000   z-0.073   x8.928
    a264.000   z-0.073   x8.884
    a265.000   z-0.074   x8.839
    a266.000   z-0.074   x8.794
    a267.000   z-0.074   x8.750
    a268.000   z-0.074   x8.705
    a269.000   z-0.075   x8.660
    a270.000   z-0.075   x8.705
    a271.000   z-0.075   x8.750
    a272.000   z-0.076   x8.794
    a273.000   z-0.076   x8.839
    a274.000   z-0.076   x8.884
    a275.000   z-0.076   x8.928
    a276.000   z-0.077   x8.973
    a277.000   z-0.077   x9.018
    a278.000   z-0.077   x9.062
    a279.000   z-0.077   x9.107
    a280.000   z-0.078   x9.151
    a281.000   z-0.078   x9.196
    a282.000   z-0.078   x9.241
    a283.000   z-0.079   x9.285
    a284.000   z-0.079   x9.330
    a285.000   z-0.079   x9.375
    a286.000   z-0.079   x9.419
    a287.000   z-0.080   x9.464
    a288.000   z-0.080   x9.509
    a289.000   z-0.080   x9.553
    a290.000   z-0.081   x9.598
    a291.000   z-0.081   x9.643
    a292.000   z-0.081   x9.687
    a293.000   z-0.081   x9.732
    a294.000   z-0.082   x9.777
    a295.000   z-0.082   x9.821
    a296.000   z-0.082   x9.866
    a297.000   z-0.083   x9.911
    a298.000   z-0.083   x9.955
    a299.000   z-0.083   x10.000
    a300.000   z-0.083   x9.955
    a301.000   z-0.084   x9.911
    a302.000   z-0.084   x9.866
    a303.000   z-0.084   x9.821
    a304.000   z-0.084   x9.777
    a305.000   z-0.085   x9.732
    a306.000   z-0.085   x9.687
    a307.000   z-0.085   x9.643
    a308.000   z-0.086   x9.598
    a309.000   z-0.086   x9.553
    a310.000   z-0.086   x9.509
    a311.000   z-0.086   x9.464
    a312.000   z-0.087   x9.419
    a313.000   z-0.087   x9.375
    a314.000   z-0.087   x9.330
    a315.000   z-0.088   x9.285
    a316.000   z-0.088   x9.241
    a317.000   z-0.088   x9.196
    a318.000   z-0.088   x9.151
    a319.000   z-0.089   x9.107
    a320.000   z-0.089   x9.062
    a321.000   z-0.089   x9.018
    a322.000   z-0.089   x8.973
    a323.000   z-0.090   x8.928
    a324.000   z-0.090   x8.884
    a325.000   z-0.090   x8.839
    a326.000   z-0.091   x8.794
    a327.000   z-0.091   x8.750
    a328.000   z-0.091   x8.705
    a329.000   z-0.091   x8.660
    a330.000   z-0.092   x8.705
    a331.000   z-0.092   x8.750
    a332.000   z-0.092   x8.794
    a333.000   z-0.093   x8.839
    a334.000   z-0.093   x8.884
    a335.000   z-0.093   x8.928
    a336.000   z-0.093   x8.973
    a337.000   z-0.094   x9.018
    a338.000   z-0.094   x9.062
    a339.000   z-0.094   x9.107
    a340.000   z-0.094   x9.151
    a341.000   z-0.095   x9.196
    a342.000   z-0.095   x9.241
    a343.000   z-0.095   x9.285
    a344.000   z-0.096   x9.330
    a345.000   z-0.096   x9.375
    a346.000   z-0.096   x9.419
    a347.000   z-0.096   x9.464
    a348.000   z-0.097   x9.509
    a349.000   z-0.097   x9.553
    a350.000   z-0.097   x9.598
    a351.000   z-0.098   x9.643
    a352.000   z-0.098   x9.687
    a353.000   z-0.098   x9.732
    a354.000   z-0.098   x9.777
    a355.000   z-0.099   x9.821
    a356.000   z-0.099   x9.866
    a357.000   z-0.099   x9.911
    a358.000   z-0.099   x9.955
    a359.000   z-0.100   x10.000
    a360.000   z-0.100   x9.955
    a361.000   z-0.100   x9.911
    a362.000   z-0.101   x9.866
    a363.000   z-0.101   x9.821
    a364.000   z-0.101   x9.777
    a365.000   z-0.101   x9.732
    a366.000   z-0.102   x9.687
    a367.000   z-0.102   x9.643
    a368.000   z-0.102   x9.598
    a369.000   z-0.103   x9.553
    a370.000   z-0.103   x9.509
    a371.000   z-0.103   x9.464
    a372.000   z-0.103   x9.419
    a373.000   z-0.104   x9.375
    a374.000   z-0.104   x9.330
    a375.000   z-0.104   x9.285
    a376.000   z-0.104   x9.241
    a377.000   z-0.105   x9.196
    a378.000   z-0.105   x9.151
    a379.000   z-0.105   x9.107
    a380.000   z-0.106   x9.062
    a381.000   z-0.106   x9.018
    a382.000   z-0.106   x8.973
    a383.000   z-0.106   x8.928
    a384.000   z-0.107   x8.884
    a385.000   z-0.107   x8.839
    a386.000   z-0.107   x8.794
    a387.000   z-0.108   x8.750
    a388.000   z-0.108   x8.705
    a389.000   z-0.108   x8.660
    a390.000   z-0.108   x8.705
    a391.000   z-0.109   x8.750
    a392.000   z-0.109   x8.794
    a393.000   z-0.109   x8.839
    a394.000   z-0.109   x8.884
    a395.000   z-0.110   x8.928
    a396.000   z-0.110   x8.973
    a397.000   z-0.110   x9.018
    a398.000   z-0.111   x9.062
    a399.000   z-0.111   x9.107
    a400.000   z-0.111   x9.151
    a401.000   z-0.111   x9.196
    a402.000   z-0.112   x9.241
    a403.000   z-0.112   x9.285
    a404.000   z-0.112   x9.330
    a405.000   z-0.113   x9.375
    a406.000   z-0.113   x9.419
    a407.000   z-0.113   x9.464
    a408.000   z-0.113   x9.509
    a409.000   z-0.114   x9.553
    a410.000   z-0.114   x9.598
    a411.000   z-0.114   x9.643
    a412.000   z-0.114   x9.687
    a413.000   z-0.115   x9.732
    a414.000   z-0.115   x9.777
    a415.000   z-0.115   x9.821
    a416.000   z-0.116   x9.866
    a417.000   z-0.116   x9.911
    a418.000   z-0.116   x9.955
    a419.000   z-0.116   x10.000
    a420.000   z-0.117   x9.955
    a421.000   z-0.117   x9.911
    a422.000   z-0.117   x9.866
    a423.000   z-0.118   x9.821
    a424.000   z-0.118   x9.777
    a425.000   z-0.118   x9.732
    a426.000   z-0.118   x9.687
    a427.000   z-0.119   x9.643
    a428.000   z-0.119   x9.598
    a429.000   z-0.119   x9.553
    a430.000   z-0.119   x9.509
    a431.000   z-0.120   x9.464
    a432.000   z-0.120   x9.419
    a433.000   z-0.120   x9.375
    a434.000   z-0.121   x9.330
    a435.000   z-0.121   x9.285
    a436.000   z-0.121   x9.241
    a437.000   z-0.121   x9.196
    a438.000   z-0.122   x9.151
    a439.000   z-0.122   x9.107
    a440.000   z-0.122   x9.062
    a441.000   z-0.123   x9.018
    a442.000   z-0.123   x8.973
    a443.000   z-0.123   x8.928
    a444.000   z-0.123   x8.884
    a445.000   z-0.124   x8.839
    a446.000   z-0.124   x8.794
    a447.000   z-0.124   x8.750
    a448.000   z-0.124   x8.705
    a449.000   z-0.125   x8.660
    a450.000   z-0.125   x8.705
    a451.000   z-0.125   x8.750
    a452.000   z-0.126   x8.794
    a453.000   z-0.126   x8.839
    a454.000   z-0.126   x8.884
    a455.000   z-0.126   x8.928
    a456.000   z-0.127   x8.973
    a457.000   z-0.127   x9.018
    a458.000   z-0.127   x9.062
    a459.000   z-0.128   x9.107
    a460.000   z-0.128   x9.151
    a461.000   z-0.128   x9.196
    a462.000   z-0.128   x9.241
    a463.000   z-0.129   x9.285
    a464.000   z-0.129   x9.330
    a465.000   z-0.129   x9.375
    a466.000   z-0.129   x9.419
    a467.000   z-0.130   x9.464
    a468.000   z-0.130   x9.509
    a469.000   z-0.130   x9.553
    a470.000   z-0.131   x9.598
    a471.000   z-0.131   x9.643
    a472.000   z-0.131   x9.687
    a473.000   z-0.131   x9.732
    a474.000   z-0.132   x9.777
    a475.000   z-0.132   x9.821
    a476.000   z-0.132   x9.866
    a477.000   z-0.133   x9.911
    a478.000   z-0.133   x9.955
    a479.000   z-0.133   x10.000
    a480.000   z-0.133   x9.955
    a481.000   z-0.134   x9.911
    a482.000   z-0.134   x9.866
    a483.000   z-0.134   x9.821
    a484.000   z-0.134   x9.777
    a485.000   z-0.135   x9.732
    a486.000   z-0.135   x9.687
    a487.000   z-0.135   x9.643
    a488.000   z-0.136   x9.598
    a489.000   z-0.136   x9.553
    a490.000   z-0.136   x9.509
    a491.000   z-0.136   x9.464
    a492.000   z-0.137   x9.419
    a493.000   z-0.137   x9.375
    a494.000   z-0.137   x9.330
    a495.000   z-0.138   x9.285
    a496.000   z-0.138   x9.241
    a497.000   z-0.138   x9.196
    a498.000   z-0.138   x9.151
    a499.000   z-0.139   x9.107
    a500.000   z-0.139   x9.062
    a501.000   z-0.139   x9.018
    a502.000   z-0.139   x8.973
    a503.000   z-0.140   x8.928
    a504.000   z-0.140   x8.884
    a505.000   z-0.140   x8.839
    a506.000   z-0.141   x8.794
    a507.000   z-0.141   x8.750
    a508.000   z-0.141   x8.705
    a509.000   z-0.141   x8.660
    a510.000   z-0.142   x8.705
    a511.000   z-0.142   x8.750
    a512.000   z-0.142   x8.794
    a513.000   z-0.143   x8.839
    a514.000   z-0.143   x8.884
    a515.000   z-0.143   x8.928
    a516.000   z-0.143   x8.973
    a517.000   z-0.144   x9.018
    a518.000   z-0.144   x9.062
    a519.000   z-0.144   x9.107
    a520.000   z-0.144   x9.151
    a521.000   z-0.145   x9.196
    a522.000   z-0.145   x9.241
    a523.000   z-0.145   x9.285
    a524.000   z-0.146   x9.330
    a525.000   z-0.146   x9.375
    a526.000   z-0.146   x9.419
    a527.000   z-0.146   x9.464
    a528.000   z-0.147   x9.509
    a529.000   z-0.147   x9.553
    a530.000   z-0.147   x9.598
    a531.000   z-0.147   x9.643
    a532.000   z-0.148   x9.687
    a533.000   z-0.148   x9.732
    a534.000   z-0.148   x9.777
    a535.000   z-0.149   x9.821
    a536.000   z-0.149   x9.866
    a537.000   z-0.149   x9.911
    a538.000   z-0.149   x9.955
    a539.000   z-0.150   x10.000
    a540.000   z-0.150   x9.955
    a541.000   z-0.150   x9.911
    a542.000   z-0.151   x9.866
    a543.000   z-0.151   x9.821
    a544.000   z-0.151   x9.777
    a545.000   z-0.151   x9.732
    a546.000   z-0.152   x9.687
    a547.000   z-0.152   x9.643
    a548.000   z-0.152   x9.598
    a549.000   z-0.152   x9.553
    a550.000   z-0.153   x9.509
    a551.000   z-0.153   x9.464
    a552.000   z-0.153   x9.419
    a553.000   z-0.154   x9.375
    a554.000   z-0.154   x9.330
    a555.000   z-0.154   x9.285
    a556.000   z-0.154   x9.241
    a557.000   z-0.155   x9.196
    a558.000   z-0.155   x9.151
    a559.000   z-0.155   x9.107
    a560.000   z-0.156   x9.062
    a561.000   z-0.156   x9.018
    a562.000   z-0.156   x8.973
    a563.000   z-0.156   x8.928
    a564.000   z-0.157   x8.884
    a565.000   z-0.157   x8.839
    a566.000   z-0.157   x8.794
    a567.000   z-0.157   x8.750
    a568.000   z-0.158   x8.705
    a569.000   z-0.158   x8.660
    a570.000   z-0.158   x8.705
    a571.000   z-0.159   x8.750
    a572.000   z-0.159   x8.794
    a573.000   z-0.159   x8.839
    a574.000   z-0.159   x8.884
    a575.000   z-0.160   x8.928
    a576.000   z-0.160   x8.973
    a577.000   z-0.160   x9.018
    a578.000   z-0.161   x9.062
    a579.000   z-0.161   x9.107
    a580.000   z-0.161   x9.151
    a581.000   z-0.161   x9.196
    a582.000   z-0.162   x9.241
    a583.000   z-0.162   x9.285
    a584.000   z-0.162   x9.330
    a585.000   z-0.162   x9.375
    a586.000   z-0.163   x9.419
    a587.000   z-0.163   x9.464
    a588.000   z-0.163   x9.509
    a589.000   z-0.164   x9.553
    a590.000   z-0.164   x9.598
    a591.000   z-0.164   x9.643
    a592.000   z-0.164   x9.687
    a593.000   z-0.165   x9.732
    a594.000   z-0.165   x9.777
    a595.000   z-0.165   x9.821
    a596.000   z-0.166   x9.866
    a597.000   z-0.166   x9.911
    a598.000   z-0.166   x9.955
    a599.000   z-0.166   x10.000
    a600.000   z-0.167   x9.955
    a601.000   z-0.167   x9.911
    a602.000   z-0.167   x9.866
    a603.000   z-0.167   x9.821
    a604.000   z-0.168   x9.777
    a605.000   z-0.168   x9.732
    a606.000   z-0.168   x9.687
    a607.000   z-0.169   x9.643
    a608.000   z-0.169   x9.598
    a609.000   z-0.169   x9.553
    a610.000   z-0.169   x9.509
    a611.000   z-0.170   x9.464
    a612.000   z-0.170   x9.419
    a613.000   z-0.170   x9.375
    a614.000   z-0.171   x9.330
    a615.000   z-0.171   x9.285
    a616.000   z-0.171   x9.241
    a617.000   z-0.171   x9.196
    a618.000   z-0.172   x9.151
    a619.000   z-0.172   x9.107
    a620.000   z-0.172   x9.062
    a621.000   z-0.172   x9.018
    a622.000   z-0.173   x8.973
    a623.000   z-0.173   x8.928
    a624.000   z-0.173   x8.884
    a625.000   z-0.174   x8.839
    a626.000   z-0.174   x8.794
    a627.000   z-0.174   x8.750
    a628.000   z-0.174   x8.705
    a629.000   z-0.175   x8.660
    a630.000   z-0.175   x8.705
    a631.000   z-0.175   x8.750
    a632.000   z-0.176   x8.794
    a633.000   z-0.176   x8.839
    a634.000   z-0.176   x8.884
    a635.000   z-0.176   x8.928
    a636.000   z-0.177   x8.973
    a637.000   z-0.177   x9.018
    a638.000   z-0.177   x9.062
    a639.000   z-0.177   x9.107
    a640.000   z-0.178   x9.151
    a641.000   z-0.178   x9.196
    a642.000   z-0.178   x9.241
    a643.000   z-0.179   x9.285
    a644.000   z-0.179   x9.330
    a645.000   z-0.179   x9.375
    a646.000   z-0.179   x9.419
    a647.000   z-0.180   x9.464
    a648.000   z-0.180   x9.509
    a649.000   z-0.180   x9.553
    a650.000   z-0.181   x9.598
    a651.000   z-0.181   x9.643
    a652.000   z-0.181   x9.687
    a653.000   z-0.181   x9.732
    a654.000   z-0.182   x9.777
    a655.000   z-0.182   x9.821
    a656.000   z-0.182   x9.866
    a657.000   z-0.182   x9.911
    a658.000   z-0.183   x9.955
    a659.000   z-0.183   x10.000
    a660.000   z-0.183   x9.955
    a661.000   z-0.184   x9.911
    a662.000   z-0.184   x9.866
    a663.000   z-0.184   x9.821
    a664.000   z-0.184   x9.777
    a665.000   z-0.185   x9.732
    a666.000   z-0.185   x9.687
    a667.000   z-0.185   x9.643
    a668.000   z-0.186   x9.598
    a669.000   z-0.186   x9.553
    a670.000   z-0.186   x9.509
    a671.000   z-0.186   x9.464
    a672.000   z-0.187   x9.419
    a673.000   z-0.187   x9.375
    a674.000   z-0.187   x9.330
    a675.000   z-0.187   x9.285
    a676.000   z-0.188   x9.241
    a677.000   z-0.188   x9.196
    a678.000   z-0.188   x9.151
    a679.000   z-0.189   x9.107
    a680.000   z-0.189   x9.062
    a681.000   z-0.189   x9.018
    a682.000   z-0.189   x8.973
    a683.000   z-0.190   x8.928
    a684.000   z-0.190   x8.884
    a685.000   z-0.190   x8.839
    a686.000   z-0.191   x8.794
    a687.000   z-0.191   x8.750
    a688.000   z-0.191   x8.705
    a689.000   z-0.191   x8.660
    a690.000   z-0.192   x8.705
    a691.000   z-0.192   x8.750
    a692.000   z-0.192   x8.794
    a693.000   z-0.192   x8.839
    a694.000   z-0.193   x8.884
    a695.000   z-0.193   x8.928
    a696.000   z-0.193   x8.973
    a697.000   z-0.194   x9.018
    a698.000   z-0.194   x9.062
    a699.000   z-0.194   x9.107
    a700.000   z-0.194   x9.151
    a701.000   z-0.195   x9.196
    a702.000   z-0.195   x9.241
    a703.000   z-0.195   x9.285
    a704.000   z-0.196   x9.330
    a705.000   z-0.196   x9.375
    a706.000   z-0.196   x9.419
    a707.000   z-0.196   x9.464
    a708.000   z-0.197   x9.509
    a709.000   z-0.197   x9.553
    a710.000   z-0.197   x9.598
    a711.000   z-0.197   x9.643
    a712.000   z-0.198   x9.687
    a713.000   z-0.198   x9.732
    a714.000   z-0.198   x9.777
    a715.000   z-0.199   x9.821
    a716.000   z-0.199   x9.866
    a717.000   z-0.199   x9.911
    a718.000   z-0.199   x9.955
    a719.000   z-0.200   x10.000
    a720.000   z-0.200   x9.955
    a721.000   z-0.200   x9.911
    a722.000   z-0.201   x9.866
    a723.000   z-0.201   x9.821
    a724.000   z-0.201   x9.777
    a725.000   z-0.201   x9.732
    a726.000   z-0.202   x9.687
    a727.000   z-0.202   x9.643
    a728.000   z-0.202   x9.598
    a729.000   z-0.202   x9.553
    a730.000   z-0.203   x9.509
    a731.000   z-0.203   x9.464
    a732.000   z-0.203   x9.419
    a733.000   z-0.204   x9.375
    a734.000   z-0.204   x9.330
    a735.000   z-0.204   x9.285
    a736.000   z-0.204   x9.241
    a737.000   z-0.205   x9.196
    a738.000   z-0.205   x9.151
    a739.000   z-0.205   x9.107
    a740.000   z-0.206   x9.062
    a741.000   z-0.206   x9.018
    a742.000   z-0.206   x8.973
    a743.000   z-0.206   x8.928
    a744.000   z-0.207   x8.884
    a745.000   z-0.207   x8.839
    a746.000   z-0.207   x8.794
    a747.000   z-0.207   x8.750
    a748.000   z-0.208   x8.705
    a749.000   z-0.208   x8.660
    a750.000   z-0.208   x8.705
    a751.000   z-0.209   x8.750
    a752.000   z-0.209   x8.794
    a753.000   z-0.209   x8.839
    a754.000   z-0.209   x8.884
    a755.000   z-0.210   x8.928
    a756.000   z-0.210   x8.973
    a757.000   z-0.210   x9.018
    a758.000   z-0.211   x9.062
    a759.000   z-0.211   x9.107
    a760.000   z-0.211   x9.151
    a761.000   z-0.211   x9.196
    a762.000   z-0.212   x9.241
    a763.000   z-0.212   x9.285
    a764.000   z-0.212   x9.330
    a765.000   z-0.212   x9.375
    a766.000   z-0.213   x9.419
    a767.000   z-0.213   x9.464
    a768.000   z-0.213   x9.509
    a769.000   z-0.214   x9.553
    a770.000   z-0.214   x9.598
    a771.000   z-0.214   x9.643
    a772.000   z-0.214   x9.687
    a773.000   z-0.215   x9.732
    a774.000   z-0.215   x9.777
    a775.000   z-0.215   x9.821
    a776.000   z-0.216   x9.866
    a777.000   z-0.216   x9.911
    a778.000   z-0.216   x9.955
    a779.000   z-0.216   x10.000
    a780.000   z-0.217   x9.955
    a781.000   z-0.217   x9.911
    a782.000   z-0.217   x9.866
    a783.000   z-0.217   x9.821
    a784.000   z-0.218   x9.777
    a785.000   z-0.218   x9.732
    a786.000   z-0.218   x9.687
    a787.000   z-0.219   x9.643
    a788.000   z-0.219   x9.598
    a789.000   z-0.219   x9.553
    a790.000   z-0.219   x9.509
    a791.000   z-0.220   x9.464
    a792.000   z-0.220   x9.419
    a793.000   z-0.220   x9.375
    a794.000   z-0.221   x9.330
    a795.000   z-0.221   x9.285
    a796.000   z-0.221   x9.241
    a797.000   z-0.221   x9.196
    a798.000   z-0.222   x9.151
    a799.000   z-0.222   x9.107
    a800.000   z-0.222   x9.062
    a801.000   z-0.222   x9.018
    a802.000   z-0.223   x8.973
    a803.000   z-0.223   x8.928
    a804.000   z-0.223   x8.884
    a805.000   z-0.224   x8.839
    a806.000   z-0.224   x8.794
    a807.000   z-0.224   x8.750
    a808.000   z-0.224   x8.705
    a809.000   z-0.225   x8.660
    a810.000   z-0.225   x8.705
    a811.000   z-0.225   x8.750
    a812.000   z-0.226   x8.794
    a813.000   z-0.226   x8.839
    a814.000   z-0.226   x8.884
    a815.000   z-0.226   x8.928
    a816.000   z-0.227   x8.973
    a817.000   z-0.227   x9.018
    a818.000   z-0.227   x9.062
    a819.000   z-0.227   x9.107
    a820.000   z-0.228   x9.151
    a821.000   z-0.228   x9.196
    a822.000   z-0.228   x9.241
    a823.000   z-0.229   x9.285
    a824.000   z-0.229   x9.330
    a825.000   z-0.229   x9.375
    a826.000   z-0.229   x9.419
    a827.000   z-0.230   x9.464
    a828.000   z-0.230   x9.509
    a829.000   z-0.230   x9.553
    a830.000   z-0.231   x9.598
    a831.000   z-0.231   x9.643
    a832.000   z-0.231   x9.687
    a833.000   z-0.231   x9.732
    a834.000   z-0.232   x9.777
    a835.000   z-0.232   x9.821
    a836.000   z-0.232   x9.866
    a837.000   z-0.232   x9.911
    a838.000   z-0.233   x9.955
    a839.000   z-0.233   x10.000
    a840.000   z-0.233   x9.955
    a841.000   z-0.234   x9.911
    a842.000   z-0.234   x9.866
    a843.000   z-0.234   x9.821
    a844.000   z-0.234   x9.777
    a845.000   z-0.235   x9.732
    a846.000   z-0.235   x9.687
    a847.000   z-0.235   x9.643
    a848.000   z-0.236   x9.598
    a849.000   z-0.236   x9.553
    a850.000   z-0.236   x9.509
    a851.000   z-0.236   x9.464
    a852.000   z-0.237   x9.419
    a853.000   z-0.237   x9.375
    a854.000   z-0.237   x9.330
    a855.000   z-0.237   x9.285
    a856.000   z-0.238   x9.241
    a857.000   z-0.238   x9.196
    a858.000   z-0.238   x9.151
    a859.000   z-0.239   x9.107
    a860.000   z-0.239   x9.062
    a861.000   z-0.239   x9.018
    a862.000   z-0.239   x8.973
    a863.000   z-0.240   x8.928
    a864.000   z-0.240   x8.884
    a865.000   z-0.240   x8.839
    a866.000   z-0.241   x8.794
    a867.000   z-0.241   x8.750
    a868.000   z-0.241   x8.705
    a869.000   z-0.241   x8.660
    a870.000   z-0.242   x8.705
    a871.000   z-0.242   x8.750
    a872.000   z-0.242   x8.794
    a873.000   z-0.242   x8.839
    a874.000   z-0.243   x8.884
    a875.000   z-0.243   x8.928
    a876.000   z-0.243   x8.973
    a877.000   z-0.244   x9.018
    a878.000   z-0.244   x9.062
    a879.000   z-0.244   x9.107
    a880.000   z-0.244   x9.151
    a881.000   z-0.245   x9.196
    a882.000   z-0.245   x9.241
    a883.000   z-0.245   x9.285
    a884.000   z-0.246   x9.330
    a885.000   z-0.246   x9.375
    a886.000   z-0.246   x9.419
    a887.000   z-0.246   x9.464
    a888.000   z-0.247   x9.509
    a889.000   z-0.247   x9.553
    a890.000   z-0.247   x9.598
    a891.000   z-0.247   x9.643
    a892.000   z-0.248   x9.687
    a893.000   z-0.248   x9.732
    a894.000   z-0.248   x9.777
    a895.000   z-0.249   x9.821
    a896.000   z-0.249   x9.866
    a897.000   z-0.249   x9.911
    a898.000   z-0.249   x9.955
    a899.000   z-0.250   x10.000
    a900.000   z-0.250   x9.955
    a901.000   z-0.250   x9.911
    a902.000   z-0.251   x9.866
    a903.000   z-0.251   x9.821
    a904.000   z-0.251   x9.777
    a905.000   z-0.251   x9.732
    a906.000   z-0.252   x9.687
    a907.000   z-0.252   x9.643
    a908.000   z-0.252   x9.598
    a909.000   z-0.252   x9.553
    a910.000   z-0.253   x9.509
    a911.000   z-0.253   x9.464
    a912.000   z-0.253   x9.419
    a913.000   z-0.254   x9.375
    a914.000   z-0.254   x9.330
    a915.000   z-0.254   x9.285
    a916.000   z-0.254   x9.241
    a917.000   z-0.255   x9.196
    a918.000   z-0.255   x9.151
    a919.000   z-0.255   x9.107
    a920.000   z-0.256   x9.062
    a921.000   z-0.256   x9.018
    a922.000   z-0.256   x8.973
    a923.000   z-0.256   x8.928
    a924.000   z-0.257   x8.884
    a925.000   z-0.257   x8.839
    a926.000   z-0.257   x8.794
    a927.000   z-0.257   x8.750
    a928.000   z-0.258   x8.705
    a929.000   z-0.258   x8.660
    a930.000   z-0.258   x8.705
    a931.000   z-0.259   x8.750
    a932.000   z-0.259   x8.794
    a933.000   z-0.259   x8.839
    a934.000   z-0.259   x8.884
    a935.000   z-0.260   x8.928
    a936.000   z-0.260   x8.973
    a937.000   z-0.260   x9.018
    a938.000   z-0.261   x9.062
    a939.000   z-0.261   x9.107
    a940.000   z-0.261   x9.151
    a941.000   z-0.261   x9.196
    a942.000   z-0.262   x9.241
    a943.000   z-0.262   x9.285
    a944.000   z-0.262   x9.330
    a945.000   z-0.262   x9.375
    a946.000   z-0.263   x9.419
    a947.000   z-0.263   x9.464
    a948.000   z-0.263   x9.509
    a949.000   z-0.264   x9.553
    a950.000   z-0.264   x9.598
    a951.000   z-0.264   x9.643
    a952.000   z-0.264   x9.687
    a953.000   z-0.265   x9.732
    a954.000   z-0.265   x9.777
    a955.000   z-0.265   x9.821
    a956.000   z-0.266   x9.866
    a957.000   z-0.266   x9.911
    a958.000   z-0.266   x9.955
    a959.000   z-0.266   x10.000
    a960.000   z-0.267   x9.955
    a961.000   z-0.267   x9.911
    a962.000   z-0.267   x9.866
    a963.000   z-0.267   x9.821
    a964.000   z-0.268   x9.777
    a965.000   z-0.268   x9.732
    a966.000   z-0.268   x9.687
    a967.000   z-0.269   x9.643
    a968.000   z-0.269   x9.598
    a969.000   z-0.269   x9.553
    a970.000   z-0.269   x9.509
    a971.000   z-0.270   x9.464
    a972.000   z-0.270   x9.419
    a973.000   z-0.270   x9.375
    a974.000   z-0.271   x9.330
    a975.000   z-0.271   x9.285
    a976.000   z-0.271   x9.241
    a977.000   z-0.271   x9.196
    a978.000   z-0.272   x9.151
    a979.000   z-0.272   x9.107
    a980.000   z-0.272   x9.062
    a981.000   z-0.272   x9.018
    a982.000   z-0.273   x8.973
    a983.000   z-0.273   x8.928
    a984.000   z-0.273   x8.884
    a985.000   z-0.274   x8.839
    a986.000   z-0.274   x8.794
    a987.000   z-0.274   x8.750
    a988.000   z-0.274   x8.705
    a989.000   z-0.275   x8.660
    a990.000   z-0.275   x8.705
    a991.000   z-0.275   x8.750
    a992.000   z-0.276   x8.794
    a993.000   z-0.276   x8.839
    a994.000   z-0.276   x8.884
    a995.000   z-0.276   x8.928
    a996.000   z-0.277   x8.973
    a997.000   z-0.277   x9.018
    a998.000   z-0.277   x9.062
    a999.000   z-0.277   x9.107
    a1000.000   z-0.278   x9.151
    a1001.000   z-0.278   x9.196
    a1002.000   z-0.278   x9.241
    a1003.000   z-0.279   x9.285
    a1004.000   z-0.279   x9.330
    a1005.000   z-0.279   x9.375
    a1006.000   z-0.279   x9.419
    a1007.000   z-0.280   x9.464
    a1008.000   z-0.280   x9.509
    a1009.000   z-0.280   x9.553
    a1010.000   z-0.281   x9.598
    a1011.000   z-0.281   x9.643
    a1012.000   z-0.281   x9.687
    a1013.000   z-0.281   x9.732
    a1014.000   z-0.282   x9.777
    a1015.000   z-0.282   x9.821
    a1016.000   z-0.282   x9.866
    a1017.000   z-0.282   x9.911
    a1018.000   z-0.283   x9.955
    a1019.000   z-0.283   x10.000
    a1020.000   z-0.283   x9.955
    a1021.000   z-0.284   x9.911
    a1022.000   z-0.284   x9.866
    a1023.000   z-0.284   x9.821
    a1024.000   z-0.284   x9.777
    a1025.000   z-0.285   x9.732
    a1026.000   z-0.285   x9.687
    a1027.000   z-0.285   x9.643
    a1028.000   z-0.286   x9.598
    a1029.000   z-0.286   x9.553
    a1030.000   z-0.286   x9.509
    a1031.000   z-0.286   x9.464
    a1032.000   z-0.287   x9.419
    a1033.000   z-0.287   x9.375
    a1034.000   z-0.287   x9.330
    a1035.000   z-0.287   x9.285
    a1036.000   z-0.288   x9.241
    a1037.000   z-0.288   x9.196
    a1038.000   z-0.288   x9.151
    a1039.000   z-0.289   x9.107
    a1040.000   z-0.289   x9.062
    a1041.000   z-0.289   x9.018
    a1042.000   z-0.289   x8.973
    a1043.000   z-0.290   x8.928
    a1044.000   z-0.290   x8.884
    a1045.000   z-0.290   x8.839
    a1046.000   z-0.291   x8.794
    a1047.000   z-0.291   x8.750
    a1048.000   z-0.291   x8.705
    a1049.000   z-0.291   x8.660
    a1050.000   z-0.292   x8.705
    a1051.000   z-0.292   x8.750
    a1052.000   z-0.292   x8.794
    a1053.000   z-0.292   x8.839
    a1054.000   z-0.293   x8.884
    a1055.000   z-0.293   x8.928
    a1056.000   z-0.293   x8.973
    a1057.000   z-0.294   x9.018
    a1058.000   z-0.294   x9.062
    a1059.000   z-0.294   x9.107
    a1060.000   z-0.294   x9.151
    a1061.000   z-0.295   x9.196
    a1062.000   z-0.295   x9.241
    a1063.000   z-0.295   x9.285
    a1064.000   z-0.296   x9.330
    a1065.000   z-0.296   x9.375
    a1066.000   z-0.296   x9.419
    a1067.000   z-0.296   x9.464
    a1068.000   z-0.297   x9.509
    a1069.000   z-0.297   x9.553
    a1070.000   z-0.297   x9.598
    a1071.000   z-0.297   x9.643
    a1072.000   z-0.298   x9.687
    a1073.000   z-0.298   x9.732
    a1074.000   z-0.298   x9.777
    a1075.000   z-0.299   x9.821
    a1076.000   z-0.299   x9.866
    a1077.000   z-0.299   x9.911
    a1078.000   z-0.299   x9.955
    a1079.000   z-0.300   x10.000
    a1080.000   z-0.300   x9.955
    a1081.000   z-0.300   x9.911
    a1082.000   z-0.301   x9.866
    a1083.000   z-0.301   x9.821
    a1084.000   z-0.301   x9.777
    a1085.000   z-0.301   x9.732
    a1086.000   z-0.302   x9.687
    a1087.000   z-0.302   x9.643
    a1088.000   z-0.302   x9.598
    a1089.000   z-0.302   x9.553
    a1090.000   z-0.303   x9.509
    a1091.000   z-0.303   x9.464
    a1092.000   z-0.303   x9.419
    a1093.000   z-0.304   x9.375
    a1094.000   z-0.304   x9.330
    a1095.000   z-0.304   x9.285
    a1096.000   z-0.304   x9.241
    a1097.000   z-0.305   x9.196
    a1098.000   z-0.305   x9.151
    a1099.000   z-0.305   x9.107
    a1100.000   z-0.306   x9.062
    a1101.000   z-0.306   x9.018
    a1102.000   z-0.306   x8.973
    a1103.000   z-0.306   x8.928
    a1104.000   z-0.307   x8.884
    a1105.000   z-0.307   x8.839
    a1106.000   z-0.307   x8.794
    a1107.000   z-0.308   x8.750
    a1108.000   z-0.308   x8.705
    a1109.000   z-0.308   x8.660
    a1110.000   z-0.308   x8.705
    a1111.000   z-0.309   x8.750
    a1112.000   z-0.309   x8.794
    a1113.000   z-0.309   x8.839
    a1114.000   z-0.309   x8.884
    a1115.000   z-0.310   x8.928
    a1116.000   z-0.310   x8.973
    a1117.000   z-0.310   x9.018
    a1118.000   z-0.311   x9.062
    a1119.000   z-0.311   x9.107
    a1120.000   z-0.311   x9.151
    a1121.000   z-0.311   x9.196
    a1122.000   z-0.312   x9.241
    a1123.000   z-0.312   x9.285
    a1124.000   z-0.312   x9.330
    a1125.000   z-0.313   x9.375
    a1126.000   z-0.313   x9.419
    a1127.000   z-0.313   x9.464
    a1128.000   z-0.313   x9.509
    a1129.000   z-0.314   x9.553
    a1130.000   z-0.314   x9.598
    a1131.000   z-0.314   x9.643
    a1132.000   z-0.314   x9.687
    a1133.000   z-0.315   x9.732
    a1134.000   z-0.315   x9.777
    a1135.000   z-0.315   x9.821
    a1136.000   z-0.316   x9.866
    a1137.000   z-0.316   x9.911
    a1138.000   z-0.316   x9.955
    a1139.000   z-0.316   x10.000
    a1140.000   z-0.317   x9.955
    a1141.000   z-0.317   x9.911
    a1142.000   z-0.317   x9.866
    a1143.000   z-0.318   x9.821
    a1144.000   z-0.318   x9.777
    a1145.000   z-0.318   x9.732
    a1146.000   z-0.318   x9.687
    a1147.000   z-0.319   x9.643
    a1148.000   z-0.319   x9.598
    a1149.000   z-0.319   x9.553
    a1150.000   z-0.319   x9.509
    a1151.000   z-0.320   x9.464
    a1152.000   z-0.320   x9.419
    a1153.000   z-0.320   x9.375
    a1154.000   z-0.321   x9.330
    a1155.000   z-0.321   x9.285
    a1156.000   z-0.321   x9.241
    a1157.000   z-0.321   x9.196
    a1158.000   z-0.322   x9.151
    a1159.000   z-0.322   x9.107
    a1160.000   z-0.322   x9.062
    a1161.000   z-0.323   x9.018
    a1162.000   z-0.323   x8.973
    a1163.000   z-0.323   x8.928
    a1164.000   z-0.323   x8.884
    a1165.000   z-0.324   x8.839
    a1166.000   z-0.324   x8.794
    a1167.000   z-0.324   x8.750
    a1168.000   z-0.324   x8.705
    a1169.000   z-0.325   x8.660
    a1170.000   z-0.325   x8.705
    a1171.000   z-0.325   x8.750
    a1172.000   z-0.326   x8.794
    a1173.000   z-0.326   x8.839
    a1174.000   z-0.326   x8.884
    a1175.000   z-0.326   x8.928
    a1176.000   z-0.327   x8.973
    a1177.000   z-0.327   x9.018
    a1178.000   z-0.327   x9.062
    a1179.000   z-0.328   x9.107
    a1180.000   z-0.328   x9.151
    a1181.000   z-0.328   x9.196
    a1182.000   z-0.328   x9.241
    a1183.000   z-0.329   x9.285
    a1184.000   z-0.329   x9.330
    a1185.000   z-0.329   x9.375
    a1186.000   z-0.329   x9.419
    a1187.000   z-0.330   x9.464
    a1188.000   z-0.330   x9.509
    a1189.000   z-0.330   x9.553
    a1190.000   z-0.331   x9.598
    a1191.000   z-0.331   x9.643
    a1192.000   z-0.331   x9.687
    a1193.000   z-0.331   x9.732
    a1194.000   z-0.332   x9.777
    a1195.000   z-0.332   x9.821
    a1196.000   z-0.332   x9.866
    a1197.000   z-0.333   x9.911
    a1198.000   z-0.333   x9.955
    a1199.000   z-0.333   x10.000
    a1200.000   z-0.333   x9.955
    a1201.000   z-0.334   x9.911
    a1202.000   z-0.334   x9.866
    a1203.000   z-0.334   x9.821
    a1204.000   z-0.334   x9.777
    a1205.000   z-0.335   x9.732
    a1206.000   z-0.335   x9.687
    a1207.000   z-0.335   x9.643
    a1208.000   z-0.336   x9.598
    a1209.000   z-0.336   x9.553
    a1210.000   z-0.336   x9.509
    a1211.000   z-0.336   x9.464
    a1212.000   z-0.337   x9.419
    a1213.000   z-0.337   x9.375
    a1214.000   z-0.337   x9.330
    a1215.000   z-0.338   x9.285
    a1216.000   z-0.338   x9.241
    a1217.000   z-0.338   x9.196
    a1218.000   z-0.338   x9.151
    a1219.000   z-0.339   x9.107
    a1220.000   z-0.339   x9.062
    a1221.000   z-0.339   x9.018
    a1222.000   z-0.339   x8.973
    a1223.000   z-0.340   x8.928
    a1224.000   z-0.340   x8.884
    a1225.000   z-0.340   x8.839
    a1226.000   z-0.341   x8.794
    a1227.000   z-0.341   x8.750
    a1228.000   z-0.341   x8.705
    a1229.000   z-0.341   x8.660
    a1230.000   z-0.342   x8.705
    a1231.000   z-0.342   x8.750
    a1232.000   z-0.342   x8.794
    a1233.000   z-0.343   x8.839
    a1234.000   z-0.343   x8.884
    a1235.000   z-0.343   x8.928
    a1236.000   z-0.343   x8.973
    a1237.000   z-0.344   x9.018
    a1238.000   z-0.344   x9.062
    a1239.000   z-0.344   x9.107
    a1240.000   z-0.344   x9.151
    a1241.000   z-0.345   x9.196
    a1242.000   z-0.345   x9.241
    a1243.000   z-0.345   x9.285
    a1244.000   z-0.346   x9.330
    a1245.000   z-0.346   x9.375
    a1246.000   z-0.346   x9.419
    a1247.000   z-0.346   x9.464
    a1248.000   z-0.347   x9.509
    a1249.000   z-0.347   x9.553
    a1250.000   z-0.347   x9.598
    a1251.000   z-0.348   x9.643
    a1252.000   z-0.348   x9.687
    a1253.000   z-0.348   x9.732
    a1254.000   z-0.348   x9.777
    a1255.000   z-0.349   x9.821
    a1256.000   z-0.349   x9.866
    a1257.000   z-0.349   x9.911
    a1258.000   z-0.349   x9.955
    a1259.000   z-0.350   x10.000
    a1260.000   z-0.350   x9.955
    a1261.000   z-0.350   x9.911
    a1262.000   z-0.351   x9.866
    a1263.000   z-0.351   x9.821
    a1264.000   z-0.351   x9.777
    a1265.000   z-0.351   x9.732
    a1266.000   z-0.352   x9.687
    a1267.000   z-0.352   x9.643
    a1268.000   z-0.352   x9.598
    a1269.000   z-0.353   x9.553
    a1270.000   z-0.353   x9.509
    a1271.000   z-0.353   x9.464
    a1272.000   z-0.353   x9.419
    a1273.000   z-0.354   x9.375
    a1274.000   z-0.354   x9.330
    a1275.000   z-0.354   x9.285
    a1276.000   z-0.354   x9.241
    a1277.000   z-0.355   x9.196
    a1278.000   z-0.355   x9.151
    a1279.000   z-0.355   x9.107
    a1280.000   z-0.356   x9.062
    a1281.000   z-0.356   x9.018
    a1282.000   z-0.356   x8.973
    a1283.000   z-0.356   x8.928
    a1284.000   z-0.357   x8.884
    a1285.000   z-0.357   x8.839
    a1286.000   z-0.357   x8.794
    a1287.000   z-0.358   x8.750
    a1288.000   z-0.358   x8.705
    a1289.000   z-0.358   x8.660
    a1290.000   z-0.358   x8.705
    a1291.000   z-0.359   x8.750
    a1292.000   z-0.359   x8.794
    a1293.000   z-0.359   x8.839
    a1294.000   z-0.359   x8.884
    a1295.000   z-0.360   x8.928
    a1296.000   z-0.360   x8.973
    a1297.000   z-0.360   x9.018
    a1298.000   z-0.361   x9.062
    a1299.000   z-0.361   x9.107
    a1300.000   z-0.361   x9.151
    a1301.000   z-0.361   x9.196
    a1302.000   z-0.362   x9.241
    a1303.000   z-0.362   x9.285
    a1304.000   z-0.362   x9.330
    a1305.000   z-0.363   x9.375
    a1306.000   z-0.363   x9.419
    a1307.000   z-0.363   x9.464
    a1308.000   z-0.363   x9.509
    a1309.000   z-0.364   x9.553
    a1310.000   z-0.364   x9.598
    a1311.000   z-0.364   x9.643
    a1312.000   z-0.364   x9.687
    a1313.000   z-0.365   x9.732
    a1314.000   z-0.365   x9.777
    a1315.000   z-0.365   x9.821
    a1316.000   z-0.366   x9.866
    a1317.000   z-0.366   x9.911
    a1318.000   z-0.366   x9.955
    a1319.000   z-0.366   x10.000
    a1320.000   z-0.367   x9.955
    a1321.000   z-0.367   x9.911
    a1322.000   z-0.367   x9.866
    a1323.000   z-0.368   x9.821
    a1324.000   z-0.368   x9.777
    a1325.000   z-0.368   x9.732
    a1326.000   z-0.368   x9.687
    a1327.000   z-0.369   x9.643
    a1328.000   z-0.369   x9.598
    a1329.000   z-0.369   x9.553
    a1330.000   z-0.369   x9.509
    a1331.000   z-0.370   x9.464
    a1332.000   z-0.370   x9.419
    a1333.000   z-0.370   x9.375
    a1334.000   z-0.371   x9.330
    a1335.000   z-0.371   x9.285
    a1336.000   z-0.371   x9.241
    a1337.000   z-0.371   x9.196
    a1338.000   z-0.372   x9.151
    a1339.000   z-0.372   x9.107
    a1340.000   z-0.372   x9.062
    a1341.000   z-0.373   x9.018
    a1342.000   z-0.373   x8.973
    a1343.000   z-0.373   x8.928
    a1344.000   z-0.373   x8.884
    a1345.000   z-0.374   x8.839
    a1346.000   z-0.374   x8.794
    a1347.000   z-0.374   x8.750
    a1348.000   z-0.374   x8.705
    a1349.000   z-0.375   x8.660
    a1350.000   z-0.375   x8.705
    a1351.000   z-0.375   x8.750
    a1352.000   z-0.376   x8.794
    a1353.000   z-0.376   x8.839
    a1354.000   z-0.376   x8.884
    a1355.000   z-0.376   x8.928
    a1356.000   z-0.377   x8.973
    a1357.000   z-0.377   x9.018
    a1358.000   z-0.377   x9.062
    a1359.000   z-0.378   x9.107
    a1360.000   z-0.378   x9.151
    a1361.000   z-0.378   x9.196
    a1362.000   z-0.378   x9.241
    a1363.000   z-0.379   x9.285
    a1364.000   z-0.379   x9.330
    a1365.000   z-0.379   x9.375
    a1366.000   z-0.379   x9.419
    a1367.000   z-0.380   x9.464
    a1368.000   z-0.380   x9.509
    a1369.000   z-0.380   x9.553
    a1370.000   z-0.381   x9.598
    a1371.000   z-0.381   x9.643
    a1372.000   z-0.381   x9.687
    a1373.000   z-0.381   x9.732
    a1374.000   z-0.382   x9.777
    a1375.000   z-0.382   x9.821
    a1376.000   z-0.382   x9.866
    a1377.000   z-0.383   x9.911
    a1378.000   z-0.383   x9.955
    a1379.000   z-0.383   x10.000
    a1380.000   z-0.383   x9.955
    a1381.000   z-0.384   x9.911
    a1382.000   z-0.384   x9.866
    a1383.000   z-0.384   x9.821
    a1384.000   z-0.384   x9.777
    a1385.000   z-0.385   x9.732
    a1386.000   z-0.385   x9.687
    a1387.000   z-0.385   x9.643
    a1388.000   z-0.386   x9.598
    a1389.000   z-0.386   x9.553
    a1390.000   z-0.386   x9.509
    a1391.000   z-0.386   x9.464
    a1392.000   z-0.387   x9.419
    a1393.000   z-0.387   x9.375
    a1394.000   z-0.387   x9.330
    a1395.000   z-0.388   x9.285
    a1396.000   z-0.388   x9.241
    a1397.000   z-0.388   x9.196
    a1398.000   z-0.388   x9.151
    a1399.000   z-0.389   x9.107
    a1400.000   z-0.389   x9.062
    a1401.000   z-0.389   x9.018
    a1402.000   z-0.389   x8.973
    a1403.000   z-0.390   x8.928
    a1404.000   z-0.390   x8.884
    a1405.000   z-0.390   x8.839
    a1406.000   z-0.391   x8.794
    a1407.000   z-0.391   x8.750
    a1408.000   z-0.391   x8.705
    a1409.000   z-0.391   x8.660
    a1410.000   z-0.392   x8.705
    a1411.000   z-0.392   x8.750
    a1412.000   z-0.392   x8.794
    a1413.000   z-0.393   x8.839
    a1414.000   z-0.393   x8.884
    a1415.000   z-0.393   x8.928
    a1416.000   z-0.393   x8.973
    a1417.000   z-0.394   x9.018
    a1418.000   z-0.394   x9.062
    a1419.000   z-0.394   x9.107
    a1420.000   z-0.394   x9.151
    a1421.000   z-0.395   x9.196
    a1422.000   z-0.395   x9.241
    a1423.000   z-0.395   x9.285
    a1424.000   z-0.396   x9.330
    a1425.000   z-0.396   x9.375
    a1426.000   z-0.396   x9.419
    a1427.000   z-0.396   x9.464
    a1428.000   z-0.397   x9.509
    a1429.000   z-0.397   x9.553
    a1430.000   z-0.397   x9.598
    a1431.000   z-0.398   x9.643
    a1432.000   z-0.398   x9.687
    a1433.000   z-0.398   x9.732
    a1434.000   z-0.398   x9.777
    a1435.000   z-0.399   x9.821
    a1436.000   z-0.399   x9.866
    a1437.000   z-0.399   x9.911
    a1438.000   z-0.399   x9.955
    a1439.000   z-0.400   x10.000
    a1440.000   z-0.400   x9.955
    a1441.000   z-0.400   x9.911
    a1442.000   z-0.401   x9.866
    a1443.000   z-0.401   x9.821
    a1444.000   z-0.401   x9.777
    a1445.000   z-0.401   x9.732
    a1446.000   z-0.402   x9.687
    a1447.000   z-0.402   x9.643
    a1448.000   z-0.402   x9.598
    a1449.000   z-0.403   x9.553
    a1450.000   z-0.403   x9.509
    a1451.000   z-0.403   x9.464
    a1452.000   z-0.403   x9.419
    a1453.000   z-0.404   x9.375
    a1454.000   z-0.404   x9.330
    a1455.000   z-0.404   x9.285
    a1456.000   z-0.404   x9.241
    a1457.000   z-0.405   x9.196
    a1458.000   z-0.405   x9.151
    a1459.000   z-0.405   x9.107
    a1460.000   z-0.406   x9.062
    a1461.000   z-0.406   x9.018
    a1462.000   z-0.406   x8.973
    a1463.000   z-0.406   x8.928
    a1464.000   z-0.407   x8.884
    a1465.000   z-0.407   x8.839
    a1466.000   z-0.407   x8.794
    a1467.000   z-0.408   x8.750
    a1468.000   z-0.408   x8.705
    a1469.000   z-0.408   x8.660
    a1470.000   z-0.408   x8.705
    a1471.000   z-0.409   x8.750
    a1472.000   z-0.409   x8.794
    a1473.000   z-0.409   x8.839
    a1474.000   z-0.409   x8.884
    a1475.000   z-0.410   x8.928
    a1476.000   z-0.410   x8.973
    a1477.000   z-0.410   x9.018
    a1478.000   z-0.411   x9.062
    a1479.000   z-0.411   x9.107
    a1480.000   z-0.411   x9.151
    a1481.000   z-0.411   x9.196
    a1482.000   z-0.412   x9.241
    a1483.000   z-0.412   x9.285
    a1484.000   z-0.412   x9.330
    a1485.000   z-0.413   x9.375
    a1486.000   z-0.413   x9.419
    a1487.000   z-0.413   x9.464
    a1488.000   z-0.413   x9.509
    a1489.000   z-0.414   x9.553
    a1490.000   z-0.414   x9.598
    a1491.000   z-0.414   x9.643
    a1492.000   z-0.414   x9.687
    a1493.000   z-0.415   x9.732
    a1494.000   z-0.415   x9.777
    a1495.000   z-0.415   x9.821
    a1496.000   z-0.416   x9.866
    a1497.000   z-0.416   x9.911
    a1498.000   z-0.416   x9.955
    a1499.000   z-0.416   x10.000
    a1500.000   z-0.417   x9.955
    a1501.000   z-0.417   x9.911
    a1502.000   z-0.417   x9.866
    a1503.000   z-0.418   x9.821
    a1504.000   z-0.418   x9.777
    a1505.000   z-0.418   x9.732
    a1506.000   z-0.418   x9.687
    a1507.000   z-0.419   x9.643
    a1508.000   z-0.419   x9.598
    a1509.000   z-0.419   x9.553
    a1510.000   z-0.419   x9.509
    a1511.000   z-0.420   x9.464
    a1512.000   z-0.420   x9.419
    a1513.000   z-0.420   x9.375
    a1514.000   z-0.421   x9.330
    a1515.000   z-0.421   x9.285
    a1516.000   z-0.421   x9.241
    a1517.000   z-0.421   x9.196
    a1518.000   z-0.422   x9.151
    a1519.000   z-0.422   x9.107
    a1520.000   z-0.422   x9.062
    a1521.000   z-0.423   x9.018
    a1522.000   z-0.423   x8.973
    a1523.000   z-0.423   x8.928
    a1524.000   z-0.423   x8.884
    a1525.000   z-0.424   x8.839
    a1526.000   z-0.424   x8.794
    a1527.000   z-0.424   x8.750
    a1528.000   z-0.424   x8.705
    a1529.000   z-0.425   x8.660
    a1530.000   z-0.425   x8.705
    a1531.000   z-0.425   x8.750
    a1532.000   z-0.426   x8.794
    a1533.000   z-0.426   x8.839
    a1534.000   z-0.426   x8.884
    a1535.000   z-0.426   x8.928
    a1536.000   z-0.427   x8.973
    a1537.000   z-0.427   x9.018
    a1538.000   z-0.427   x9.062
    a1539.000   z-0.428   x9.107
    a1540.000   z-0.428   x9.151
    a1541.000   z-0.428   x9.196
    a1542.000   z-0.428   x9.241
    a1543.000   z-0.429   x9.285
    a1544.000   z-0.429   x9.330
    a1545.000   z-0.429   x9.375
    a1546.000   z-0.429   x9.419
    a1547.000   z-0.430   x9.464
    a1548.000   z-0.430   x9.509
    a1549.000   z-0.430   x9.553
    a1550.000   z-0.431   x9.598
    a1551.000   z-0.431   x9.643
    a1552.000   z-0.431   x9.687
    a1553.000   z-0.431   x9.732
    a1554.000   z-0.432   x9.777
    a1555.000   z-0.432   x9.821
    a1556.000   z-0.432   x9.866
    a1557.000   z-0.433   x9.911
    a1558.000   z-0.433   x9.955
    a1559.000   z-0.433   x10.000
    a1560.000   z-0.433   x9.955
    a1561.000   z-0.434   x9.911
    a1562.000   z-0.434   x9.866
    a1563.000   z-0.434   x9.821
    a1564.000   z-0.434   x9.777
    a1565.000   z-0.435   x9.732
    a1566.000   z-0.435   x9.687
    a1567.000   z-0.435   x9.643
    a1568.000   z-0.436   x9.598
    a1569.000   z-0.436   x9.553
    a1570.000   z-0.436   x9.509
    a1571.000   z-0.436   x9.464
    a1572.000   z-0.437   x9.419
    a1573.000   z-0.437   x9.375
    a1574.000   z-0.437   x9.330
    a1575.000   z-0.438   x9.285
    a1576.000   z-0.438   x9.241
    a1577.000   z-0.438   x9.196
    a1578.000   z-0.438   x9.151
    a1579.000   z-0.439   x9.107
    a1580.000   z-0.439   x9.062
    a1581.000   z-0.439   x9.018
    a1582.000   z-0.439   x8.973
    a1583.000   z-0.440   x8.928
    a1584.000   z-0.440   x8.884
    a1585.000   z-0.440   x8.839
    a1586.000   z-0.441   x8.794
    a1587.000   z-0.441   x8.750
    a1588.000   z-0.441   x8.705
    a1589.000   z-0.441   x8.660
    a1590.000   z-0.442   x8.705
    a1591.000   z-0.442   x8.750
    a1592.000   z-0.442   x8.794
    a1593.000   z-0.443   x8.839
    a1594.000   z-0.443   x8.884
    a1595.000   z-0.443   x8.928
    a1596.000   z-0.443   x8.973
    a1597.000   z-0.444   x9.018
    a1598.000   z-0.444   x9.062
    a1599.000   z-0.444   x9.107
    a1600.000   z-0.444   x9.151
    a1601.000   z-0.445   x9.196
    a1602.000   z-0.445   x9.241
    a1603.000   z-0.445   x9.285
    a1604.000   z-0.446   x9.330
    a1605.000   z-0.446   x9.375
    a1606.000   z-0.446   x9.419
    a1607.000   z-0.446   x9.464
    a1608.000   z-0.447   x9.509
    a1609.000   z-0.447   x9.553
    a1610.000   z-0.447   x9.598
    a1611.000   z-0.448   x9.643
    a1612.000   z-0.448   x9.687
    a1613.000   z-0.448   x9.732
    a1614.000   z-0.448   x9.777
    a1615.000   z-0.449   x9.821
    a1616.000   z-0.449   x9.866
    a1617.000   z-0.449   x9.911
    a1618.000   z-0.449   x9.955
    a1619.000   z-0.450   x10.000
    a1620.000   z-0.450   x9.955
    a1621.000   z-0.450   x9.911
    a1622.000   z-0.451   x9.866
    a1623.000   z-0.451   x9.821
    a1624.000   z-0.451   x9.777
    a1625.000   z-0.451   x9.732
    a1626.000   z-0.452   x9.687
    a1627.000   z-0.452   x9.643
    a1628.000   z-0.452   x9.598
    a1629.000   z-0.453   x9.553
    a1630.000   z-0.453   x9.509
    a1631.000   z-0.453   x9.464
    a1632.000   z-0.453   x9.419
    a1633.000   z-0.454   x9.375
    a1634.000   z-0.454   x9.330
    a1635.000   z-0.454   x9.285
    a1636.000   z-0.454   x9.241
    a1637.000   z-0.455   x9.196
    a1638.000   z-0.455   x9.151
    a1639.000   z-0.455   x9.107
    a1640.000   z-0.456   x9.062
    a1641.000   z-0.456   x9.018
    a1642.000   z-0.456   x8.973
    a1643.000   z-0.456   x8.928
    a1644.000   z-0.457   x8.884
    a1645.000   z-0.457   x8.839
    a1646.000   z-0.457   x8.794
    a1647.000   z-0.458   x8.750
    a1648.000   z-0.458   x8.705
    a1649.000   z-0.458   x8.660
    a1650.000   z-0.458   x8.705
    a1651.000   z-0.459   x8.750
    a1652.000   z-0.459   x8.794
    a1653.000   z-0.459   x8.839
    a1654.000   z-0.459   x8.884
    a1655.000   z-0.460   x8.928
    a1656.000   z-0.460   x8.973
    a1657.000   z-0.460   x9.018
    a1658.000   z-0.461   x9.062
    a1659.000   z-0.461   x9.107
    a1660.000   z-0.461   x9.151
    a1661.000   z-0.461   x9.196
    a1662.000   z-0.462   x9.241
    a1663.000   z-0.462   x9.285
    a1664.000   z-0.462   x9.330
    a1665.000   z-0.463   x9.375
    a1666.000   z-0.463   x9.419
    a1667.000   z-0.463   x9.464
    a1668.000   z-0.463   x9.509
    a1669.000   z-0.464   x9.553
    a1670.000   z-0.464   x9.598
    a1671.000   z-0.464   x9.643
    a1672.000   z-0.464   x9.687
    a1673.000   z-0.465   x9.732
    a1674.000   z-0.465   x9.777
    a1675.000   z-0.465   x9.821
    a1676.000   z-0.466   x9.866
    a1677.000   z-0.466   x9.911
    a1678.000   z-0.466   x9.955
    a1679.000   z-0.466   x10.000
    a1680.000   z-0.467   x9.955
    a1681.000   z-0.467   x9.911
    a1682.000   z-0.467   x9.866
    a1683.000   z-0.468   x9.821
    a1684.000   z-0.468   x9.777
    a1685.000   z-0.468   x9.732
    a1686.000   z-0.468   x9.687
    a1687.000   z-0.469   x9.643
    a1688.000   z-0.469   x9.598
    a1689.000   z-0.469   x9.553
    a1690.000   z-0.469   x9.509
    a1691.000   z-0.470   x9.464
    a1692.000   z-0.470   x9.419
    a1693.000   z-0.470   x9.375
    a1694.000   z-0.471   x9.330
    a1695.000   z-0.471   x9.285
    a1696.000   z-0.471   x9.241
    a1697.000   z-0.471   x9.196
    a1698.000   z-0.472   x9.151
    a1699.000   z-0.472   x9.107
    a1700.000   z-0.472   x9.062
    a1701.000   z-0.473   x9.018
    a1702.000   z-0.473   x8.973
    a1703.000   z-0.473   x8.928
    a1704.000   z-0.473   x8.884
    a1705.000   z-0.474   x8.839
    a1706.000   z-0.474   x8.794
    a1707.000   z-0.474   x8.750
    a1708.000   z-0.474   x8.705
    a1709.000   z-0.475   x8.660
    a1710.000   z-0.475   x8.705
    a1711.000   z-0.475   x8.750
    a1712.000   z-0.476   x8.794
    a1713.000   z-0.476   x8.839
    a1714.000   z-0.476   x8.884
    a1715.000   z-0.476   x8.928
    a1716.000   z-0.477   x8.973
    a1717.000   z-0.477   x9.018
    a1718.000   z-0.477   x9.062
    a1719.000   z-0.478   x9.107
    a1720.000   z-0.478   x9.151
    a1721.000   z-0.478   x9.196
    a1722.000   z-0.478   x9.241
    a1723.000   z-0.479   x9.285
    a1724.000   z-0.479   x9.330
    a1725.000   z-0.479   x9.375
    a1726.000   z-0.479   x9.419
    a1727.000   z-0.480   x9.464
    a1728.000   z-0.480   x9.509
    a1729.000   z-0.480   x9.553
    a1730.000   z-0.481   x9.598
    a1731.000   z-0.481   x9.643
    a1732.000   z-0.481   x9.687
    a1733.000   z-0.481   x9.732
    a1734.000   z-0.482   x9.777
    a1735.000   z-0.482   x9.821
    a1736.000   z-0.482   x9.866
    a1737.000   z-0.483   x9.911
    a1738.000   z-0.483   x9.955
    a1739.000   z-0.483   x10.000
    a1740.000   z-0.483   x9.955
    a1741.000   z-0.484   x9.911
    a1742.000   z-0.484   x9.866
    a1743.000   z-0.484   x9.821
    a1744.000   z-0.484   x9.777
    a1745.000   z-0.485   x9.732
    a1746.000   z-0.485   x9.687
    a1747.000   z-0.485   x9.643
    a1748.000   z-0.486   x9.598
    a1749.000   z-0.486   x9.553
    a1750.000   z-0.486   x9.509
    a1751.000   z-0.486   x9.464
    a1752.000   z-0.487   x9.419
    a1753.000   z-0.487   x9.375
    a1754.000   z-0.487   x9.330
    a1755.000   z-0.488   x9.285
    a1756.000   z-0.488   x9.241
    a1757.000   z-0.488   x9.196
    a1758.000   z-0.488   x9.151
    a1759.000   z-0.489   x9.107
    a1760.000   z-0.489   x9.062
    a1761.000   z-0.489   x9.018
    a1762.000   z-0.489   x8.973
    a1763.000   z-0.490   x8.928
    a1764.000   z-0.490   x8.884
    a1765.000   z-0.490   x8.839
    a1766.000   z-0.491   x8.794
    a1767.000   z-0.491   x8.750
    a1768.000   z-0.491   x8.705
    a1769.000   z-0.491   x8.660
    a1770.000   z-0.492   x8.705
    a1771.000   z-0.492   x8.750
    a1772.000   z-0.492   x8.794
    a1773.000   z-0.493   x8.839
    a1774.000   z-0.493   x8.884
    a1775.000   z-0.493   x8.928
    a1776.000   z-0.493   x8.973
    a1777.000   z-0.494   x9.018
    a1778.000   z-0.494   x9.062
    a1779.000   z-0.494   x9.107
    a1780.000   z-0.494   x9.151
    a1781.000   z-0.495   x9.196
    a1782.000   z-0.495   x9.241
    a1783.000   z-0.495   x9.285
    a1784.000   z-0.496   x9.330
    a1785.000   z-0.496   x9.375
    a1786.000   z-0.496   x9.419
    a1787.000   z-0.496   x9.464
    a1788.000   z-0.497   x9.509
    a1789.000   z-0.497   x9.553
    a1790.000   z-0.497   x9.598
    a1791.000   z-0.498   x9.643
    a1792.000   z-0.498   x9.687
    a1793.000   z-0.498   x9.732
    a1794.000   z-0.498   x9.777
    a1795.000   z-0.499   x9.821
    a1796.000   z-0.499   x9.866
    a1797.000   z-0.499   x9.911
    a1798.000   z-0.499   x9.955
    a1799.000   z-0.500   x10.000
    a1800.000   z-0.500   x9.955
    a1801.000   z-0.500   x9.911
    a1802.000   z-0.501   x9.866
    a1803.000   z-0.501   x9.821
    a1804.000   z-0.501   x9.777
    a1805.000   z-0.501   x9.732
    a1806.000   z-0.502   x9.687
    a1807.000   z-0.502   x9.643
    a1808.000   z-0.502   x9.598
    a1809.000   z-0.503   x9.553
    a1810.000   z-0.503   x9.509
    a1811.000   z-0.503   x9.464
    a1812.000   z-0.503   x9.419
    a1813.000   z-0.504   x9.375
    a1814.000   z-0.504   x9.330
    a1815.000   z-0.504   x9.285
    a1816.000   z-0.504   x9.241
    a1817.000   z-0.505   x9.196
    a1818.000   z-0.505   x9.151
    a1819.000   z-0.505   x9.107
    a1820.000   z-0.506   x9.062
    a1821.000   z-0.506   x9.018
    a1822.000   z-0.506   x8.973
    a1823.000   z-0.506   x8.928
    a1824.000   z-0.507   x8.884
    a1825.000   z-0.507   x8.839
    a1826.000   z-0.507   x8.794
    a1827.000   z-0.508   x8.750
    a1828.000   z-0.508   x8.705
    a1829.000   z-0.508   x8.660
    a1830.000   z-0.508   x8.705
    a1831.000   z-0.509   x8.750
    a1832.000   z-0.509   x8.794
    a1833.000   z-0.509   x8.839
    a1834.000   z-0.509   x8.884
    a1835.000   z-0.510   x8.928
    a1836.000   z-0.510   x8.973
    a1837.000   z-0.510   x9.018
    a1838.000   z-0.511   x9.062
    a1839.000   z-0.511   x9.107
    a1840.000   z-0.511   x9.151
    a1841.000   z-0.511   x9.196
    a1842.000   z-0.512   x9.241
    a1843.000   z-0.512   x9.285
    a1844.000   z-0.512   x9.330
    a1845.000   z-0.513   x9.375
    a1846.000   z-0.513   x9.419
    a1847.000   z-0.513   x9.464
    a1848.000   z-0.513   x9.509
    a1849.000   z-0.514   x9.553
    a1850.000   z-0.514   x9.598
    a1851.000   z-0.514   x9.643
    a1852.000   z-0.514   x9.687
    a1853.000   z-0.515   x9.732
    a1854.000   z-0.515   x9.777
    a1855.000   z-0.515   x9.821
    a1856.000   z-0.516   x9.866
    a1857.000   z-0.516   x9.911
    a1858.000   z-0.516   x9.955
    a1859.000   z-0.516   x10.000
    a1860.000   z-0.517   x9.955
    a1861.000   z-0.517   x9.911
    a1862.000   z-0.517   x9.866
    a1863.000   z-0.518   x9.821
    a1864.000   z-0.518   x9.777
    a1865.000   z-0.518   x9.732
    a1866.000   z-0.518   x9.687
    a1867.000   z-0.519   x9.643
    a1868.000   z-0.519   x9.598
    a1869.000   z-0.519   x9.553
    a1870.000   z-0.519   x9.509
    a1871.000   z-0.520   x9.464
    a1872.000   z-0.520   x9.419
    a1873.000   z-0.520   x9.375
    a1874.000   z-0.521   x9.330
    a1875.000   z-0.521   x9.285
    a1876.000   z-0.521   x9.241
    a1877.000   z-0.521   x9.196
    a1878.000   z-0.522   x9.151
    a1879.000   z-0.522   x9.107
    a1880.000   z-0.522   x9.062
    a1881.000   z-0.523   x9.018
    a1882.000   z-0.523   x8.973
    a1883.000   z-0.523   x8.928
    a1884.000   z-0.523   x8.884
    a1885.000   z-0.524   x8.839
    a1886.000   z-0.524   x8.794
    a1887.000   z-0.524   x8.750
    a1888.000   z-0.524   x8.705
    a1889.000   z-0.525   x8.660
    a1890.000   z-0.525   x8.705
    a1891.000   z-0.525   x8.750
    a1892.000   z-0.526   x8.794
    a1893.000   z-0.526   x8.839
    a1894.000   z-0.526   x8.884
    a1895.000   z-0.526   x8.928
    a1896.000   z-0.527   x8.973
    a1897.000   z-0.527   x9.018
    a1898.000   z-0.527   x9.062
    a1899.000   z-0.528   x9.107
    a1900.000   z-0.528   x9.151
    a1901.000   z-0.528   x9.196
    a1902.000   z-0.528   x9.241
    a1903.000   z-0.529   x9.285
    a1904.000   z-0.529   x9.330
    a1905.000   z-0.529   x9.375
    a1906.000   z-0.529   x9.419
    a1907.000   z-0.530   x9.464
    a1908.000   z-0.530   x9.509
    a1909.000   z-0.530   x9.553
    a1910.000   z-0.531   x9.598
    a1911.000   z-0.531   x9.643
    a1912.000   z-0.531   x9.687
    a1913.000   z-0.531   x9.732
    a1914.000   z-0.532   x9.777
    a1915.000   z-0.532   x9.821
    a1916.000   z-0.532   x9.866
    a1917.000   z-0.533   x9.911
    a1918.000   z-0.533   x9.955
    a1919.000   z-0.533   x10.000
    a1920.000   z-0.533   x9.955
    a1921.000   z-0.534   x9.911
    a1922.000   z-0.534   x9.866
    a1923.000   z-0.534   x9.821
    a1924.000   z-0.534   x9.777
    a1925.000   z-0.535   x9.732
    a1926.000   z-0.535   x9.687
    a1927.000   z-0.535   x9.643
    a1928.000   z-0.536   x9.598
    a1929.000   z-0.536   x9.553
    a1930.000   z-0.536   x9.509
    a1931.000   z-0.536   x9.464
    a1932.000   z-0.537   x9.419
    a1933.000   z-0.537   x9.375
    a1934.000   z-0.537   x9.330
    a1935.000   z-0.538   x9.285
    a1936.000   z-0.538   x9.241
    a1937.000   z-0.538   x9.196
    a1938.000   z-0.538   x9.151
    a1939.000   z-0.539   x9.107
    a1940.000   z-0.539   x9.062
    a1941.000   z-0.539   x9.018
    a1942.000   z-0.539   x8.973
    a1943.000   z-0.540   x8.928
    a1944.000   z-0.540   x8.884
    a1945.000   z-0.540   x8.839
    a1946.000   z-0.541   x8.794
    a1947.000   z-0.541   x8.750
    a1948.000   z-0.541   x8.705
    a1949.000   z-0.541   x8.660
    a1950.000   z-0.542   x8.705
    a1951.000   z-0.542   x8.750
    a1952.000   z-0.542   x8.794
    a1953.000   z-0.543   x8.839
    a1954.000   z-0.543   x8.884
    a1955.000   z-0.543   x8.928
    a1956.000   z-0.543   x8.973
    a1957.000   z-0.544   x9.018
    a1958.000   z-0.544   x9.062
    a1959.000   z-0.544   x9.107
    a1960.000   z-0.544   x9.151
    a1961.000   z-0.545   x9.196
    a1962.000   z-0.545   x9.241
    a1963.000   z-0.545   x9.285
    a1964.000   z-0.546   x9.330
    a1965.000   z-0.546   x9.375
    a1966.000   z-0.546   x9.419
    a1967.000   z-0.546   x9.464
    a1968.000   z-0.547   x9.509
    a1969.000   z-0.547   x9.553
    a1970.000   z-0.547   x9.598
    a1971.000   z-0.548   x9.643
    a1972.000   z-0.548   x9.687
    a1973.000   z-0.548   x9.732
    a1974.000   z-0.548   x9.777
    a1975.000   z-0.549   x9.821
    a1976.000   z-0.549   x9.866
    a1977.000   z-0.549   x9.911
    a1978.000   z-0.549   x9.955
    a1979.000   z-0.550   x10.000
    a1980.000   z-0.550   x9.955
    a1981.000   z-0.550   x9.911
    a1982.000   z-0.551   x9.866
    a1983.000   z-0.551   x9.821
    a1984.000   z-0.551   x9.777
    a1985.000   z-0.551   x9.732
    a1986.000   z-0.552   x9.687
    a1987.000   z-0.552   x9.643
    a1988.000   z-0.552   x9.598
    a1989.000   z-0.553   x9.553
    a1990.000   z-0.553   x9.509
    a1991.000   z-0.553   x9.464
    a1992.000   z-0.553   x9.419
    a1993.000   z-0.554   x9.375
    a1994.000   z-0.554   x9.330
    a1995.000   z-0.554   x9.285
    a1996.000   z-0.554   x9.241
    a1997.000   z-0.555   x9.196
    a1998.000   z-0.555   x9.151
    a1999.000   z-0.555   x9.107
    a2000.000   z-0.556   x9.062
    a2001.000   z-0.556   x9.018
    a2002.000   z-0.556   x8.973
    a2003.000   z-0.556   x8.928
    a2004.000   z-0.557   x8.884
    a2005.000   z-0.557   x8.839
    a2006.000   z-0.557   x8.794
    a2007.000   z-0.558   x8.750
    a2008.000   z-0.558   x8.705
    a2009.000   z-0.558   x8.660
    a2010.000   z-0.558   x8.705
    a2011.000   z-0.559   x8.750
    a2012.000   z-0.559   x8.794
    a2013.000   z-0.559   x8.839
    a2014.000   z-0.559   x8.884
    a2015.000   z-0.560   x8.928
    a2016.000   z-0.560   x8.973
    a2017.000   z-0.560   x9.018
    a2018.000   z-0.561   x9.062
    a2019.000   z-0.561   x9.107
    a2020.000   z-0.561   x9.151
    a2021.000   z-0.561   x9.196
    a2022.000   z-0.562   x9.241
    a2023.000   z-0.562   x9.285
    a2024.000   z-0.562   x9.330
    a2025.000   z-0.563   x9.375
    a2026.000   z-0.563   x9.419
    a2027.000   z-0.563   x9.464
    a2028.000   z-0.563   x9.509
    a2029.000   z-0.564   x9.553
    a2030.000   z-0.564   x9.598
    a2031.000   z-0.564   x9.643
    a2032.000   z-0.564   x9.687
    a2033.000   z-0.565   x9.732
    a2034.000   z-0.565   x9.777
    a2035.000   z-0.565   x9.821
    a2036.000   z-0.566   x9.866
    a2037.000   z-0.566   x9.911
    a2038.000   z-0.566   x9.955
    a2039.000   z-0.566   x10.000
    a2040.000   z-0.567   x9.955
    a2041.000   z-0.567   x9.911
    a2042.000   z-0.567   x9.866
    a2043.000   z-0.568   x9.821
    a2044.000   z-0.568   x9.777
    a2045.000   z-0.568   x9.732
    a2046.000   z-0.568   x9.687
    a2047.000   z-0.569   x9.643
    a2048.000   z-0.569   x9.598
    a2049.000   z-0.569   x9.553
    a2050.000   z-0.569   x9.509
    a2051.000   z-0.570   x9.464
    a2052.000   z-0.570   x9.419
    a2053.000   z-0.570   x9.375
    a2054.000   z-0.571   x9.330
    a2055.000   z-0.571   x9.285
    a2056.000   z-0.571   x9.241
    a2057.000   z-0.571   x9.196
    a2058.000   z-0.572   x9.151
    a2059.000   z-0.572   x9.107
    a2060.000   z-0.572   x9.062
    a2061.000   z-0.573   x9.018
    a2062.000   z-0.573   x8.973
    a2063.000   z-0.573   x8.928
    a2064.000   z-0.573   x8.884
    a2065.000   z-0.574   x8.839
    a2066.000   z-0.574   x8.794
    a2067.000   z-0.574   x8.750
    a2068.000   z-0.574   x8.705
    a2069.000   z-0.575   x8.660
    a2070.000   z-0.575   x8.705
    a2071.000   z-0.575   x8.750
    a2072.000   z-0.576   x8.794
    a2073.000   z-0.576   x8.839
    a2074.000   z-0.576   x8.884
    a2075.000   z-0.576   x8.928
    a2076.000   z-0.577   x8.973
    a2077.000   z-0.577   x9.018
    a2078.000   z-0.577   x9.062
    a2079.000   z-0.578   x9.107
    a2080.000   z-0.578   x9.151
    a2081.000   z-0.578   x9.196
    a2082.000   z-0.578   x9.241
    a2083.000   z-0.579   x9.285
    a2084.000   z-0.579   x9.330
    a2085.000   z-0.579   x9.375
    a2086.000   z-0.579   x9.419
    a2087.000   z-0.580   x9.464
    a2088.000   z-0.580   x9.509
    a2089.000   z-0.580   x9.553
    a2090.000   z-0.581   x9.598
    a2091.000   z-0.581   x9.643
    a2092.000   z-0.581   x9.687
    a2093.000   z-0.581   x9.732
    a2094.000   z-0.582   x9.777
    a2095.000   z-0.582   x9.821
    a2096.000   z-0.582   x9.866
    a2097.000   z-0.583   x9.911
    a2098.000   z-0.583   x9.955
    a2099.000   z-0.583   x10.000
    a2100.000   z-0.583   x9.955
    a2101.000   z-0.584   x9.911
    a2102.000   z-0.584   x9.866
    a2103.000   z-0.584   x9.821
    a2104.000   z-0.584   x9.777
    a2105.000   z-0.585   x9.732
    a2106.000   z-0.585   x9.687
    a2107.000   z-0.585   x9.643
    a2108.000   z-0.586   x9.598
    a2109.000   z-0.586   x9.553
    a2110.000   z-0.586   x9.509
    a2111.000   z-0.586   x9.464
    a2112.000   z-0.587   x9.419
    a2113.000   z-0.587   x9.375
    a2114.000   z-0.587   x9.330
    a2115.000   z-0.588   x9.285
    a2116.000   z-0.588   x9.241
    a2117.000   z-0.588   x9.196
    a2118.000   z-0.588   x9.151
    a2119.000   z-0.589   x9.107
    a2120.000   z-0.589   x9.062
    a2121.000   z-0.589   x9.018
    a2122.000   z-0.589   x8.973
    a2123.000   z-0.590   x8.928
    a2124.000   z-0.590   x8.884
    a2125.000   z-0.590   x8.839
    a2126.000   z-0.591   x8.794
    a2127.000   z-0.591   x8.750
    a2128.000   z-0.591   x8.705
    a2129.000   z-0.591   x8.660
    a2130.000   z-0.592   x8.705
    a2131.000   z-0.592   x8.750
    a2132.000   z-0.592   x8.794
    a2133.000   z-0.592   x8.839
    a2134.000   z-0.593   x8.884
    a2135.000   z-0.593   x8.928
    a2136.000   z-0.593   x8.973
    a2137.000   z-0.594   x9.018
    a2138.000   z-0.594   x9.062
    a2139.000   z-0.594   x9.107
    a2140.000   z-0.594   x9.151
    a2141.000   z-0.595   x9.196
    a2142.000   z-0.595   x9.241
    a2143.000   z-0.595   x9.285
    a2144.000   z-0.596   x9.330
    a2145.000   z-0.596   x9.375
    a2146.000   z-0.596   x9.419
    a2147.000   z-0.596   x9.464
    a2148.000   z-0.597   x9.509
    a2149.000   z-0.597   x9.553
    a2150.000   z-0.597   x9.598
    a2151.000   z-0.597   x9.643
    a2152.000   z-0.598   x9.687
    a2153.000   z-0.598   x9.732
    a2154.000   z-0.598   x9.777
    a2155.000   z-0.599   x9.821
    a2156.000   z-0.599   x9.866
    a2157.000   z-0.599   x9.911
    a2158.000   z-0.599   x9.955
    a2159.000   z-0.600   x10.000
    a2160.000   z-0.600   x9.955
    a2161.000   z-0.600   x9.911
    a2162.000   z-0.601   x9.866
    a2163.000   z-0.601   x9.821
    a2164.000   z-0.601   x9.777
    a2165.000   z-0.601   x9.732
    a2166.000   z-0.602   x9.687
    a2167.000   z-0.602   x9.643
    a2168.000   z-0.602   x9.598
    a2169.000   z-0.602   x9.553
    a2170.000   z-0.603   x9.509
    a2171.000   z-0.603   x9.464
    a2172.000   z-0.603   x9.419
    a2173.000   z-0.604   x9.375
    a2174.000   z-0.604   x9.330
    a2175.000   z-0.604   x9.285
    a2176.000   z-0.604   x9.241
    a2177.000   z-0.605   x9.196
    a2178.000   z-0.605   x9.151
    a2179.000   z-0.605   x9.107
    a2180.000   z-0.606   x9.062
    a2181.000   z-0.606   x9.018
    a2182.000   z-0.606   x8.973
    a2183.000   z-0.606   x8.928
    a2184.000   z-0.607   x8.884
    a2185.000   z-0.607   x8.839
    a2186.000   z-0.607   x8.794
    a2187.000   z-0.607   x8.750
    a2188.000   z-0.608   x8.705
    a2189.000   z-0.608   x8.660
    a2190.000   z-0.608   x8.705
    a2191.000   z-0.609   x8.750
    a2192.000   z-0.609   x8.794
    a2193.000   z-0.609   x8.839
    a2194.000   z-0.609   x8.884
    a2195.000   z-0.610   x8.928
    a2196.000   z-0.610   x8.973
    a2197.000   z-0.610   x9.018
    a2198.000   z-0.611   x9.062
    a2199.000   z-0.611   x9.107
    a2200.000   z-0.611   x9.151
    a2201.000   z-0.611   x9.196
    a2202.000   z-0.612   x9.241
    a2203.000   z-0.612   x9.285
    a2204.000   z-0.612   x9.330
    a2205.000   z-0.612   x9.375
    a2206.000   z-0.613   x9.419
    a2207.000   z-0.613   x9.464
    a2208.000   z-0.613   x9.509
    a2209.000   z-0.614   x9.553
    a2210.000   z-0.614   x9.598
    a2211.000   z-0.614   x9.643
    a2212.000   z-0.614   x9.687
    a2213.000   z-0.615   x9.732
    a2214.000   z-0.615   x9.777
    a2215.000   z-0.615   x9.821
    a2216.000   z-0.616   x9.866
    a2217.000   z-0.616   x9.911
    a2218.000   z-0.616   x9.955
    a2219.000   z-0.616   x10.000
    a2220.000   z-0.617   x9.955
    a2221.000   z-0.617   x9.911
    a2222.000   z-0.617   x9.866
    a2223.000   z-0.617   x9.821
    a2224.000   z-0.618   x9.777
    a2225.000   z-0.618   x9.732
    a2226.000   z-0.618   x9.687
    a2227.000   z-0.619   x9.643
    a2228.000   z-0.619   x9.598
    a2229.000   z-0.619   x9.553
    a2230.000   z-0.619   x9.509
    a2231.000   z-0.620   x9.464
    a2232.000   z-0.620   x9.419
    a2233.000   z-0.620   x9.375
    a2234.000   z-0.621   x9.330
    a2235.000   z-0.621   x9.285
    a2236.000   z-0.621   x9.241
    a2237.000   z-0.621   x9.196
    a2238.000   z-0.622   x9.151
    a2239.000   z-0.622   x9.107
    a2240.000   z-0.622   x9.062
    a2241.000   z-0.622   x9.018
    a2242.000   z-0.623   x8.973
    a2243.000   z-0.623   x8.928
    a2244.000   z-0.623   x8.884
    a2245.000   z-0.624   x8.839
    a2246.000   z-0.624   x8.794
    a2247.000   z-0.624   x8.750
    a2248.000   z-0.624   x8.705
    a2249.000   z-0.625   x8.660
    a2250.000   z-0.625   x8.705
    a2251.000   z-0.625   x8.750
    a2252.000   z-0.626   x8.794
    a2253.000   z-0.626   x8.839
    a2254.000   z-0.626   x8.884
    a2255.000   z-0.626   x8.928
    a2256.000   z-0.627   x8.973
    a2257.000   z-0.627   x9.018
    a2258.000   z-0.627   x9.062
    a2259.000   z-0.627   x9.107
    a2260.000   z-0.628   x9.151
    a2261.000   z-0.628   x9.196
    a2262.000   z-0.628   x9.241
    a2263.000   z-0.629   x9.285
    a2264.000   z-0.629   x9.330
    a2265.000   z-0.629   x9.375
    a2266.000   z-0.629   x9.419
    a2267.000   z-0.630   x9.464
    a2268.000   z-0.630   x9.509
    a2269.000   z-0.630   x9.553
    a2270.000   z-0.631   x9.598
    a2271.000   z-0.631   x9.643
    a2272.000   z-0.631   x9.687
    a2273.000   z-0.631   x9.732
    a2274.000   z-0.632   x9.777
    a2275.000   z-0.632   x9.821
    a2276.000   z-0.632   x9.866
    a2277.000   z-0.632   x9.911
    a2278.000   z-0.633   x9.955
    a2279.000   z-0.633   x10.000
    a2280.000   z-0.633   x9.955
    a2281.000   z-0.634   x9.911
    a2282.000   z-0.634   x9.866
    a2283.000   z-0.634   x9.821
    a2284.000   z-0.634   x9.777
    a2285.000   z-0.635   x9.732
    a2286.000   z-0.635   x9.687
    a2287.000   z-0.635   x9.643
    a2288.000   z-0.636   x9.598
    a2289.000   z-0.636   x9.553
    a2290.000   z-0.636   x9.509
    a2291.000   z-0.636   x9.464
    a2292.000   z-0.637   x9.419
    a2293.000   z-0.637   x9.375
    a2294.000   z-0.637   x9.330
    a2295.000   z-0.637   x9.285
    a2296.000   z-0.638   x9.241
    a2297.000   z-0.638   x9.196
    a2298.000   z-0.638   x9.151
    a2299.000   z-0.639   x9.107
    a2300.000   z-0.639   x9.062
    a2301.000   z-0.639   x9.018
    a2302.000   z-0.639   x8.973
    a2303.000   z-0.640   x8.928
    a2304.000   z-0.640   x8.884
    a2305.000   z-0.640   x8.839
    a2306.000   z-0.641   x8.794
    a2307.000   z-0.641   x8.750
    a2308.000   z-0.641   x8.705
    a2309.000   z-0.641   x8.660
    a2310.000   z-0.642   x8.705
    a2311.000   z-0.642   x8.750
    a2312.000   z-0.642   x8.794
    a2313.000   z-0.642   x8.839
    a2314.000   z-0.643   x8.884
    a2315.000   z-0.643   x8.928
    a2316.000   z-0.643   x8.973
    a2317.000   z-0.644   x9.018
    a2318.000   z-0.644   x9.062
    a2319.000   z-0.644   x9.107
    a2320.000   z-0.644   x9.151
    a2321.000   z-0.645   x9.196
    a2322.000   z-0.645   x9.241
    a2323.000   z-0.645   x9.285
    a2324.000   z-0.646   x9.330
    a2325.000   z-0.646   x9.375
    a2326.000   z-0.646   x9.419
    a2327.000   z-0.646   x9.464
    a2328.000   z-0.647   x9.509
    a2329.000   z-0.647   x9.553
    a2330.000   z-0.647   x9.598
    a2331.000   z-0.647   x9.643
    a2332.000   z-0.648   x9.687
    a2333.000   z-0.648   x9.732
    a2334.000   z-0.648   x9.777
    a2335.000   z-0.649   x9.821
    a2336.000   z-0.649   x9.866
    a2337.000   z-0.649   x9.911
    a2338.000   z-0.649   x9.955
    a2339.000   z-0.650   x10.000
    a2340.000   z-0.650   x9.955
    a2341.000   z-0.650   x9.911
    a2342.000   z-0.651   x9.866
    a2343.000   z-0.651   x9.821
    a2344.000   z-0.651   x9.777
    a2345.000   z-0.651   x9.732
    a2346.000   z-0.652   x9.687
    a2347.000   z-0.652   x9.643
    a2348.000   z-0.652   x9.598
    a2349.000   z-0.652   x9.553
    a2350.000   z-0.653   x9.509
    a2351.000   z-0.653   x9.464
    a2352.000   z-0.653   x9.419
    a2353.000   z-0.654   x9.375
    a2354.000   z-0.654   x9.330
    a2355.000   z-0.654   x9.285
    a2356.000   z-0.654   x9.241
    a2357.000   z-0.655   x9.196
    a2358.000   z-0.655   x9.151
    a2359.000   z-0.655   x9.107
    a2360.000   z-0.656   x9.062
    a2361.000   z-0.656   x9.018
    a2362.000   z-0.656   x8.973
    a2363.000   z-0.656   x8.928
    a2364.000   z-0.657   x8.884
    a2365.000   z-0.657   x8.839
    a2366.000   z-0.657   x8.794
    a2367.000   z-0.657   x8.750
    a2368.000   z-0.658   x8.705
    a2369.000   z-0.658   x8.660
    a2370.000   z-0.658   x8.705
    a2371.000   z-0.659   x8.750
    a2372.000   z-0.659   x8.794
    a2373.000   z-0.659   x8.839
    a2374.000   z-0.659   x8.884
    a2375.000   z-0.660   x8.928
    a2376.000   z-0.660   x8.973
    a2377.000   z-0.660   x9.018
    a2378.000   z-0.661   x9.062
    a2379.000   z-0.661   x9.107
    a2380.000   z-0.661   x9.151
    a2381.000   z-0.661   x9.196
    a2382.000   z-0.662   x9.241
    a2383.000   z-0.662   x9.285
    a2384.000   z-0.662   x9.330
    a2385.000   z-0.662   x9.375
    a2386.000   z-0.663   x9.419
    a2387.000   z-0.663   x9.464
    a2388.000   z-0.663   x9.509
    a2389.000   z-0.664   x9.553
    a2390.000   z-0.664   x9.598
    a2391.000   z-0.664   x9.643
    a2392.000   z-0.664   x9.687
    a2393.000   z-0.665   x9.732
    a2394.000   z-0.665   x9.777
    a2395.000   z-0.665   x9.821
    a2396.000   z-0.666   x9.866
    a2397.000   z-0.666   x9.911
    a2398.000   z-0.666   x9.955
    a2399.000   z-0.666   x10.000
    a2400.000   z-0.667   x9.955
    a2401.000   z-0.667   x9.911
    a2402.000   z-0.667   x9.866
    a2403.000   z-0.667   x9.821
    a2404.000   z-0.668   x9.777
    a2405.000   z-0.668   x9.732
    a2406.000   z-0.668   x9.687
    a2407.000   z-0.669   x9.643
    a2408.000   z-0.669   x9.598
    a2409.000   z-0.669   x9.553
    a2410.000   z-0.669   x9.509
    a2411.000   z-0.670   x9.464
    a2412.000   z-0.670   x9.419
    a2413.000   z-0.670   x9.375
    a2414.000   z-0.671   x9.330
    a2415.000   z-0.671   x9.285
    a2416.000   z-0.671   x9.241
    a2417.000   z-0.671   x9.196
    a2418.000   z-0.672   x9.151
    a2419.000   z-0.672   x9.107
    a2420.000   z-0.672   x9.062
    a2421.000   z-0.672   x9.018
    a2422.000   z-0.673   x8.973
    a2423.000   z-0.673   x8.928
    a2424.000   z-0.673   x8.884
    a2425.000   z-0.674   x8.839
    a2426.000   z-0.674   x8.794
    a2427.000   z-0.674   x8.750
    a2428.000   z-0.674   x8.705
    a2429.000   z-0.675   x8.660
    a2430.000   z-0.675   x8.705
    a2431.000   z-0.675   x8.750
    a2432.000   z-0.676   x8.794
    a2433.000   z-0.676   x8.839
    a2434.000   z-0.676   x8.884
    a2435.000   z-0.676   x8.928
    a2436.000   z-0.677   x8.973
    a2437.000   z-0.677   x9.018
    a2438.000   z-0.677   x9.062
    a2439.000   z-0.677   x9.107
    a2440.000   z-0.678   x9.151
    a2441.000   z-0.678   x9.196
    a2442.000   z-0.678   x9.241
    a2443.000   z-0.679   x9.285
    a2444.000   z-0.679   x9.330
    a2445.000   z-0.679   x9.375
    a2446.000   z-0.679   x9.419
    a2447.000   z-0.680   x9.464
    a2448.000   z-0.680   x9.509
    a2449.000   z-0.680   x9.553
    a2450.000   z-0.681   x9.598
    a2451.000   z-0.681   x9.643
    a2452.000   z-0.681   x9.687
    a2453.000   z-0.681   x9.732
    a2454.000   z-0.682   x9.777
    a2455.000   z-0.682   x9.821
    a2456.000   z-0.682   x9.866
    a2457.000   z-0.682   x9.911
    a2458.000   z-0.683   x9.955
    a2459.000   z-0.683   x10.000
    a2460.000   z-0.683   x9.955
    a2461.000   z-0.684   x9.911
    a2462.000   z-0.684   x9.866
    a2463.000   z-0.684   x9.821
    a2464.000   z-0.684   x9.777
    a2465.000   z-0.685   x9.732
    a2466.000   z-0.685   x9.687
    a2467.000   z-0.685   x9.643
    a2468.000   z-0.686   x9.598
    a2469.000   z-0.686   x9.553
    a2470.000   z-0.686   x9.509
    a2471.000   z-0.686   x9.464
    a2472.000   z-0.687   x9.419
    a2473.000   z-0.687   x9.375
    a2474.000   z-0.687   x9.330
    a2475.000   z-0.687   x9.285
    a2476.000   z-0.688   x9.241
    a2477.000   z-0.688   x9.196
    a2478.000   z-0.688   x9.151
    a2479.000   z-0.689   x9.107
    a2480.000   z-0.689   x9.062
    a2481.000   z-0.689   x9.018
    a2482.000   z-0.689   x8.973
    a2483.000   z-0.690   x8.928
    a2484.000   z-0.690   x8.884
    a2485.000   z-0.690   x8.839
    a2486.000   z-0.691   x8.794
    a2487.000   z-0.691   x8.750
    a2488.000   z-0.691   x8.705
    a2489.000   z-0.691   x8.660
    a2490.000   z-0.692   x8.705
    a2491.000   z-0.692   x8.750
    a2492.000   z-0.692   x8.794
    a2493.000   z-0.692   x8.839
    a2494.000   z-0.693   x8.884
    a2495.000   z-0.693   x8.928
    a2496.000   z-0.693   x8.973
    a2497.000   z-0.694   x9.018
    a2498.000   z-0.694   x9.062
    a2499.000   z-0.694   x9.107
    a2500.000   z-0.694   x9.151
    a2501.000   z-0.695   x9.196
    a2502.000   z-0.695   x9.241
    a2503.000   z-0.695   x9.285
    a2504.000   z-0.696   x9.330
    a2505.000   z-0.696   x9.375
    a2506.000   z-0.696   x9.419
    a2507.000   z-0.696   x9.464
    a2508.000   z-0.697   x9.509
    a2509.000   z-0.697   x9.553
    a2510.000   z-0.697   x9.598
    a2511.000   z-0.697   x9.643
    a2512.000   z-0.698   x9.687
    a2513.000   z-0.698   x9.732
    a2514.000   z-0.698   x9.777
    a2515.000   z-0.699   x9.821
    a2516.000   z-0.699   x9.866
    a2517.000   z-0.699   x9.911
    a2518.000   z-0.699   x9.955
    a2519.000   z-0.700   x10.000
    a2520.000   z-0.700   x9.955
    a2521.000   z-0.700   x9.911
    a2522.000   z-0.701   x9.866
    a2523.000   z-0.701   x9.821
    a2524.000   z-0.701   x9.777
    a2525.000   z-0.701   x9.732
    a2526.000   z-0.702   x9.687
    a2527.000   z-0.702   x9.643
    a2528.000   z-0.702   x9.598
    a2529.000   z-0.702   x9.553
    a2530.000   z-0.703   x9.509
    a2531.000   z-0.703   x9.464
    a2532.000   z-0.703   x9.419
    a2533.000   z-0.704   x9.375
    a2534.000   z-0.704   x9.330
    a2535.000   z-0.704   x9.285
    a2536.000   z-0.704   x9.241
    a2537.000   z-0.705   x9.196
    a2538.000   z-0.705   x9.151
    a2539.000   z-0.705   x9.107
    a2540.000   z-0.706   x9.062
    a2541.000   z-0.706   x9.018
    a2542.000   z-0.706   x8.973
    a2543.000   z-0.706   x8.928
    a2544.000   z-0.707   x8.884
    a2545.000   z-0.707   x8.839
    a2546.000   z-0.707   x8.794
    a2547.000   z-0.707   x8.750
    a2548.000   z-0.708   x8.705
    a2549.000   z-0.708   x8.660
    a2550.000   z-0.708   x8.705
    a2551.000   z-0.709   x8.750
    a2552.000   z-0.709   x8.794
    a2553.000   z-0.709   x8.839
    a2554.000   z-0.709   x8.884
    a2555.000   z-0.710   x8.928
    a2556.000   z-0.710   x8.973
    a2557.000   z-0.710   x9.018
    a2558.000   z-0.711   x9.062
    a2559.000   z-0.711   x9.107
    a2560.000   z-0.711   x9.151
    a2561.000   z-0.711   x9.196
    a2562.000   z-0.712   x9.241
    a2563.000   z-0.712   x9.285
    a2564.000   z-0.712   x9.330
    a2565.000   z-0.712   x9.375
    a2566.000   z-0.713   x9.419
    a2567.000   z-0.713   x9.464
    a2568.000   z-0.713   x9.509
    a2569.000   z-0.714   x9.553
    a2570.000   z-0.714   x9.598
    a2571.000   z-0.714   x9.643
    a2572.000   z-0.714   x9.687
    a2573.000   z-0.715   x9.732
    a2574.000   z-0.715   x9.777
    a2575.000   z-0.715   x9.821
    a2576.000   z-0.716   x9.866
    a2577.000   z-0.716   x9.911
    a2578.000   z-0.716   x9.955
    a2579.000   z-0.716   x10.000
    a2580.000   z-0.717   x9.955
    a2581.000   z-0.717   x9.911
    a2582.000   z-0.717   x9.866
    a2583.000   z-0.717   x9.821
    a2584.000   z-0.718   x9.777
    a2585.000   z-0.718   x9.732
    a2586.000   z-0.718   x9.687
    a2587.000   z-0.719   x9.643
    a2588.000   z-0.719   x9.598
    a2589.000   z-0.719   x9.553
    a2590.000   z-0.719   x9.509
    a2591.000   z-0.720   x9.464
    a2592.000   z-0.720   x9.419
    a2593.000   z-0.720   x9.375
    a2594.000   z-0.721   x9.330
    a2595.000   z-0.721   x9.285
    a2596.000   z-0.721   x9.241
    a2597.000   z-0.721   x9.196
    a2598.000   z-0.722   x9.151
    a2599.000   z-0.722   x9.107
    a2600.000   z-0.722   x9.062
    a2601.000   z-0.722   x9.018
    a2602.000   z-0.723   x8.973
    a2603.000   z-0.723   x8.928
    a2604.000   z-0.723   x8.884
    a2605.000   z-0.724   x8.839
    a2606.000   z-0.724   x8.794
    a2607.000   z-0.724   x8.750
    a2608.000   z-0.724   x8.705
    a2609.000   z-0.725   x8.660
    a2610.000   z-0.725   x8.705
    a2611.000   z-0.725   x8.750
    a2612.000   z-0.726   x8.794
    a2613.000   z-0.726   x8.839
    a2614.000   z-0.726   x8.884
    a2615.000   z-0.726   x8.928
    a2616.000   z-0.727   x8.973
    a2617.000   z-0.727   x9.018
    a2618.000   z-0.727   x9.062
    a2619.000   z-0.727   x9.107
    a2620.000   z-0.728   x9.151
    a2621.000   z-0.728   x9.196
    a2622.000   z-0.728   x9.241
    a2623.000   z-0.729   x9.285
    a2624.000   z-0.729   x9.330
    a2625.000   z-0.729   x9.375
    a2626.000   z-0.729   x9.419
    a2627.000   z-0.730   x9.464
    a2628.000   z-0.730   x9.509
    a2629.000   z-0.730   x9.553
    a2630.000   z-0.731   x9.598
    a2631.000   z-0.731   x9.643
    a2632.000   z-0.731   x9.687
    a2633.000   z-0.731   x9.732
    a2634.000   z-0.732   x9.777
    a2635.000   z-0.732   x9.821
    a2636.000   z-0.732   x9.866
    a2637.000   z-0.732   x9.911
    a2638.000   z-0.733   x9.955
    a2639.000   z-0.733   x10.000
    a2640.000   z-0.733   x9.955
    a2641.000   z-0.734   x9.911
    a2642.000   z-0.734   x9.866
    a2643.000   z-0.734   x9.821
    a2644.000   z-0.734   x9.777
    a2645.000   z-0.735   x9.732
    a2646.000   z-0.735   x9.687
    a2647.000   z-0.735   x9.643
    a2648.000   z-0.736   x9.598
    a2649.000   z-0.736   x9.553
    a2650.000   z-0.736   x9.509
    a2651.000   z-0.736   x9.464
    a2652.000   z-0.737   x9.419
    a2653.000   z-0.737   x9.375
    a2654.000   z-0.737   x9.330
    a2655.000   z-0.737   x9.285
    a2656.000   z-0.738   x9.241
    a2657.000   z-0.738   x9.196
    a2658.000   z-0.738   x9.151
    a2659.000   z-0.739   x9.107
    a2660.000   z-0.739   x9.062
    a2661.000   z-0.739   x9.018
    a2662.000   z-0.739   x8.973
    a2663.000   z-0.740   x8.928
    a2664.000   z-0.740   x8.884
    a2665.000   z-0.740   x8.839
    a2666.000   z-0.741   x8.794
    a2667.000   z-0.741   x8.750
    a2668.000   z-0.741   x8.705
    a2669.000   z-0.741   x8.660
    a2670.000   z-0.742   x8.705
    a2671.000   z-0.742   x8.750
    a2672.000   z-0.742   x8.794
    a2673.000   z-0.742   x8.839
    a2674.000   z-0.743   x8.884
    a2675.000   z-0.743   x8.928
    a2676.000   z-0.743   x8.973
    a2677.000   z-0.744   x9.018
    a2678.000   z-0.744   x9.062
    a2679.000   z-0.744   x9.107
    a2680.000   z-0.744   x9.151
    a2681.000   z-0.745   x9.196
    a2682.000   z-0.745   x9.241
    a2683.000   z-0.745   x9.285
    a2684.000   z-0.746   x9.330
    a2685.000   z-0.746   x9.375
    a2686.000   z-0.746   x9.419
    a2687.000   z-0.746   x9.464
    a2688.000   z-0.747   x9.509
    a2689.000   z-0.747   x9.553
    a2690.000   z-0.747   x9.598
    a2691.000   z-0.747   x9.643
    a2692.000   z-0.748   x9.687
    a2693.000   z-0.748   x9.732
    a2694.000   z-0.748   x9.777
    a2695.000   z-0.749   x9.821
    a2696.000   z-0.749   x9.866
    a2697.000   z-0.749   x9.911
    a2698.000   z-0.749   x9.955
    a2699.000   z-0.750   x10.000
    a2700.000   z-0.750   x9.955
    a2701.000   z-0.750   x9.911
    a2702.000   z-0.751   x9.866
    a2703.000   z-0.751   x9.821
    a2704.000   z-0.751   x9.777
    a2705.000   z-0.751   x9.732
    a2706.000   z-0.752   x9.687
    a2707.000   z-0.752   x9.643
    a2708.000   z-0.752   x9.598
    a2709.000   z-0.752   x9.553
    a2710.000   z-0.753   x9.509
    a2711.000   z-0.753   x9.464
    a2712.000   z-0.753   x9.419
    a2713.000   z-0.754   x9.375
    a2714.000   z-0.754   x9.330
    a2715.000   z-0.754   x9.285
    a2716.000   z-0.754   x9.241
    a2717.000   z-0.755   x9.196
    a2718.000   z-0.755   x9.151
    a2719.000   z-0.755   x9.107
    a2720.000   z-0.756   x9.062
    a2721.000   z-0.756   x9.018
    a2722.000   z-0.756   x8.973
    a2723.000   z-0.756   x8.928
    a2724.000   z-0.757   x8.884
    a2725.000   z-0.757   x8.839
    a2726.000   z-0.757   x8.794
    a2727.000   z-0.757   x8.750
    a2728.000   z-0.758   x8.705
    a2729.000   z-0.758   x8.660
    a2730.000   z-0.758   x8.705
    a2731.000   z-0.759   x8.750
    a2732.000   z-0.759   x8.794
    a2733.000   z-0.759   x8.839
    a2734.000   z-0.759   x8.884
    a2735.000   z-0.760   x8.928
    a2736.000   z-0.760   x8.973
    a2737.000   z-0.760   x9.018
    a2738.000   z-0.761   x9.062
    a2739.000   z-0.761   x9.107
    a2740.000   z-0.761   x9.151
    a2741.000   z-0.761   x9.196
    a2742.000   z-0.762   x9.241
    a2743.000   z-0.762   x9.285
    a2744.000   z-0.762   x9.330
    a2745.000   z-0.762   x9.375
    a2746.000   z-0.763   x9.419
    a2747.000   z-0.763   x9.464
    a2748.000   z-0.763   x9.509
    a2749.000   z-0.764   x9.553
    a2750.000   z-0.764   x9.598
    a2751.000   z-0.764   x9.643
    a2752.000   z-0.764   x9.687
    a2753.000   z-0.765   x9.732
    a2754.000   z-0.765   x9.777
    a2755.000   z-0.765   x9.821
    a2756.000   z-0.766   x9.866
    a2757.000   z-0.766   x9.911
    a2758.000   z-0.766   x9.955
    a2759.000   z-0.766   x10.000
    a2760.000   z-0.767   x9.955
    a2761.000   z-0.767   x9.911
    a2762.000   z-0.767   x9.866
    a2763.000   z-0.767   x9.821
    a2764.000   z-0.768   x9.777
    a2765.000   z-0.768   x9.732
    a2766.000   z-0.768   x9.687
    a2767.000   z-0.769   x9.643
    a2768.000   z-0.769   x9.598
    a2769.000   z-0.769   x9.553
    a2770.000   z-0.769   x9.509
    a2771.000   z-0.770   x9.464
    a2772.000   z-0.770   x9.419
    a2773.000   z-0.770   x9.375
    a2774.000   z-0.771   x9.330
    a2775.000   z-0.771   x9.285
    a2776.000   z-0.771   x9.241
    a2777.000   z-0.771   x9.196
    a2778.000   z-0.772   x9.151
    a2779.000   z-0.772   x9.107
    a2780.000   z-0.772   x9.062
    a2781.000   z-0.772   x9.018
    a2782.000   z-0.773   x8.973
    a2783.000   z-0.773   x8.928
    a2784.000   z-0.773   x8.884
    a2785.000   z-0.774   x8.839
    a2786.000   z-0.774   x8.794
    a2787.000   z-0.774   x8.750
    a2788.000   z-0.774   x8.705
    a2789.000   z-0.775   x8.660
    a2790.000   z-0.775   x8.705
    a2791.000   z-0.775   x8.750
    a2792.000   z-0.776   x8.794
    a2793.000   z-0.776   x8.839
    a2794.000   z-0.776   x8.884
    a2795.000   z-0.776   x8.928
    a2796.000   z-0.777   x8.973
    a2797.000   z-0.777   x9.018
    a2798.000   z-0.777   x9.062
    a2799.000   z-0.777   x9.107
    a2800.000   z-0.778   x9.151
    a2801.000   z-0.778   x9.196
    a2802.000   z-0.778   x9.241
    a2803.000   z-0.779   x9.285
    a2804.000   z-0.779   x9.330
    a2805.000   z-0.779   x9.375
    a2806.000   z-0.779   x9.419
    a2807.000   z-0.780   x9.464
    a2808.000   z-0.780   x9.509
    a2809.000   z-0.780   x9.553
    a2810.000   z-0.781   x9.598
    a2811.000   z-0.781   x9.643
    a2812.000   z-0.781   x9.687
    a2813.000   z-0.781   x9.732
    a2814.000   z-0.782   x9.777
    a2815.000   z-0.782   x9.821
    a2816.000   z-0.782   x9.866
    a2817.000   z-0.782   x9.911
    a2818.000   z-0.783   x9.955
    a2819.000   z-0.783   x10.000
    a2820.000   z-0.783   x9.955
    a2821.000   z-0.784   x9.911
    a2822.000   z-0.784   x9.866
    a2823.000   z-0.784   x9.821
    a2824.000   z-0.784   x9.777
    a2825.000   z-0.785   x9.732
    a2826.000   z-0.785   x9.687
    a2827.000   z-0.785   x9.643
    a2828.000   z-0.786   x9.598
    a2829.000   z-0.786   x9.553
    a2830.000   z-0.786   x9.509
    a2831.000   z-0.786   x9.464
    a2832.000   z-0.787   x9.419
    a2833.000   z-0.787   x9.375
    a2834.000   z-0.787   x9.330
    a2835.000   z-0.787   x9.285
    a2836.000   z-0.788   x9.241
    a2837.000   z-0.788   x9.196
    a2838.000   z-0.788   x9.151
    a2839.000   z-0.789   x9.107
    a2840.000   z-0.789   x9.062
    a2841.000   z-0.789   x9.018
    a2842.000   z-0.789   x8.973
    a2843.000   z-0.790   x8.928
    a2844.000   z-0.790   x8.884
    a2845.000   z-0.790   x8.839
    a2846.000   z-0.791   x8.794
    a2847.000   z-0.791   x8.750
    a2848.000   z-0.791   x8.705
    a2849.000   z-0.791   x8.660
    a2850.000   z-0.792   x8.705
    a2851.000   z-0.792   x8.750
    a2852.000   z-0.792   x8.794
    a2853.000   z-0.792   x8.839
    a2854.000   z-0.793   x8.884
    a2855.000   z-0.793   x8.928
    a2856.000   z-0.793   x8.973
    a2857.000   z-0.794   x9.018
    a2858.000   z-0.794   x9.062
    a2859.000   z-0.794   x9.107
    a2860.000   z-0.794   x9.151
    a2861.000   z-0.795   x9.196
    a2862.000   z-0.795   x9.241
    a2863.000   z-0.795   x9.285
    a2864.000   z-0.796   x9.330
    a2865.000   z-0.796   x9.375
    a2866.000   z-0.796   x9.419
    a2867.000   z-0.796   x9.464
    a2868.000   z-0.797   x9.509
    a2869.000   z-0.797   x9.553
    a2870.000   z-0.797   x9.598
    a2871.000   z-0.797   x9.643
    a2872.000   z-0.798   x9.687
    a2873.000   z-0.798   x9.732
    a2874.000   z-0.798   x9.777
    a2875.000   z-0.799   x9.821
    a2876.000   z-0.799   x9.866
    a2877.000   z-0.799   x9.911
    a2878.000   z-0.799   x9.955
    a2879.000   z-0.800   x10.000
    a2880.000   z-0.800   x9.955
    a2881.000   z-0.800   x9.911
    a2882.000   z-0.801   x9.866
    a2883.000   z-0.801   x9.821
    a2884.000   z-0.801   x9.777
    a2885.000   z-0.801   x9.732
    a2886.000   z-0.802   x9.687
    a2887.000   z-0.802   x9.643
    a2888.000   z-0.802   x9.598
    a2889.000   z-0.802   x9.553
    a2890.000   z-0.803   x9.509
    a2891.000   z-0.803   x9.464
    a2892.000   z-0.803   x9.419
    a2893.000   z-0.804   x9.375
    a2894.000   z-0.804   x9.330
    a2895.000   z-0.804   x9.285
    a2896.000   z-0.804   x9.241
    a2897.000   z-0.805   x9.196
    a2898.000   z-0.805   x9.151
    a2899.000   z-0.805   x9.107
    a2900.000   z-0.806   x9.062
    a2901.000   z-0.806   x9.018
    a2902.000   z-0.806   x8.973
    a2903.000   z-0.806   x8.928
    a2904.000   z-0.807   x8.884
    a2905.000   z-0.807   x8.839
    a2906.000   z-0.807   x8.794
    a2907.000   z-0.807   x8.750
    a2908.000   z-0.808   x8.705
    a2909.000   z-0.808   x8.660
    a2910.000   z-0.808   x8.705
    a2911.000   z-0.809   x8.750
    a2912.000   z-0.809   x8.794
    a2913.000   z-0.809   x8.839
    a2914.000   z-0.809   x8.884
    a2915.000   z-0.810   x8.928
    a2916.000   z-0.810   x8.973
    a2917.000   z-0.810   x9.018
    a2918.000   z-0.811   x9.062
    a2919.000   z-0.811   x9.107
    a2920.000   z-0.811   x9.151
    a2921.000   z-0.811   x9.196
    a2922.000   z-0.812   x9.241
    a2923.000   z-0.812   x9.285
    a2924.000   z-0.812   x9.330
    a2925.000   z-0.812   x9.375
    a2926.000   z-0.813   x9.419
    a2927.000   z-0.813   x9.464
    a2928.000   z-0.813   x9.509
    a2929.000   z-0.814   x9.553
    a2930.000   z-0.814   x9.598
    a2931.000   z-0.814   x9.643
    a2932.000   z-0.814   x9.687
    a2933.000   z-0.815   x9.732
    a2934.000   z-0.815   x9.777
    a2935.000   z-0.815   x9.821
    a2936.000   z-0.816   x9.866
    a2937.000   z-0.816   x9.911
    a2938.000   z-0.816   x9.955
    a2939.000   z-0.816   x10.000
    a2940.000   z-0.817   x9.955
    a2941.000   z-0.817   x9.911
    a2942.000   z-0.817   x9.866
    a2943.000   z-0.817   x9.821
    a2944.000   z-0.818   x9.777
    a2945.000   z-0.818   x9.732
    a2946.000   z-0.818   x9.687
    a2947.000   z-0.819   x9.643
    a2948.000   z-0.819   x9.598
    a2949.000   z-0.819   x9.553
    a2950.000   z-0.819   x9.509
    a2951.000   z-0.820   x9.464
    a2952.000   z-0.820   x9.419
    a2953.000   z-0.820   x9.375
    a2954.000   z-0.821   x9.330
    a2955.000   z-0.821   x9.285
    a2956.000   z-0.821   x9.241
    a2957.000   z-0.821   x9.196
    a2958.000   z-0.822   x9.151
    a2959.000   z-0.822   x9.107
    a2960.000   z-0.822   x9.062
    a2961.000   z-0.822   x9.018
    a2962.000   z-0.823   x8.973
    a2963.000   z-0.823   x8.928
    a2964.000   z-0.823   x8.884
    a2965.000   z-0.824   x8.839
    a2966.000   z-0.824   x8.794
    a2967.000   z-0.824   x8.750
    a2968.000   z-0.824   x8.705
    a2969.000   z-0.825   x8.660
    a2970.000   z-0.825   x8.705
    a2971.000   z-0.825   x8.750
    a2972.000   z-0.826   x8.794
    a2973.000   z-0.826   x8.839
    a2974.000   z-0.826   x8.884
    a2975.000   z-0.826   x8.928
    a2976.000   z-0.827   x8.973
    a2977.000   z-0.827   x9.018
    a2978.000   z-0.827   x9.062
    a2979.000   z-0.827   x9.107
    a2980.000   z-0.828   x9.151
    a2981.000   z-0.828   x9.196
    a2982.000   z-0.828   x9.241
    a2983.000   z-0.829   x9.285
    a2984.000   z-0.829   x9.330
    a2985.000   z-0.829   x9.375
    a2986.000   z-0.829   x9.419
    a2987.000   z-0.830   x9.464
    a2988.000   z-0.830   x9.509
    a2989.000   z-0.830   x9.553
    a2990.000   z-0.831   x9.598
    a2991.000   z-0.831   x9.643
    a2992.000   z-0.831   x9.687
    a2993.000   z-0.831   x9.732
    a2994.000   z-0.832   x9.777
    a2995.000   z-0.832   x9.821
    a2996.000   z-0.832   x9.866
    a2997.000   z-0.832   x9.911
    a2998.000   z-0.833   x9.955
    a2999.000   z-0.833   x10.000
    a3000.000   z-0.833   x9.955
    a3001.000   z-0.834   x9.911
    a3002.000   z-0.834   x9.866
    a3003.000   z-0.834   x9.821
    a3004.000   z-0.834   x9.777
    a3005.000   z-0.835   x9.732
    a3006.000   z-0.835   x9.687
    a3007.000   z-0.835   x9.643
    a3008.000   z-0.836   x9.598
    a3009.000   z-0.836   x9.553
    a3010.000   z-0.836   x9.509
    a3011.000   z-0.836   x9.464
    a3012.000   z-0.837   x9.419
    a3013.000   z-0.837   x9.375
    a3014.000   z-0.837   x9.330
    a3015.000   z-0.837   x9.285
    a3016.000   z-0.838   x9.241
    a3017.000   z-0.838   x9.196
    a3018.000   z-0.838   x9.151
    a3019.000   z-0.839   x9.107
    a3020.000   z-0.839   x9.062
    a3021.000   z-0.839   x9.018
    a3022.000   z-0.839   x8.973
    a3023.000   z-0.840   x8.928
    a3024.000   z-0.840   x8.884
    a3025.000   z-0.840   x8.839
    a3026.000   z-0.841   x8.794
    a3027.000   z-0.841   x8.750
    a3028.000   z-0.841   x8.705
    a3029.000   z-0.841   x8.660
    a3030.000   z-0.842   x8.705
    a3031.000   z-0.842   x8.750
    a3032.000   z-0.842   x8.794
    a3033.000   z-0.842   x8.839
    a3034.000   z-0.843   x8.884
    a3035.000   z-0.843   x8.928
    a3036.000   z-0.843   x8.973
    a3037.000   z-0.844   x9.018
    a3038.000   z-0.844   x9.062
    a3039.000   z-0.844   x9.107
    a3040.000   z-0.844   x9.151
    a3041.000   z-0.845   x9.196
    a3042.000   z-0.845   x9.241
    a3043.000   z-0.845   x9.285
    a3044.000   z-0.846   x9.330
    a3045.000   z-0.846   x9.375
    a3046.000   z-0.846   x9.419
    a3047.000   z-0.846   x9.464
    a3048.000   z-0.847   x9.509
    a3049.000   z-0.847   x9.553
    a3050.000   z-0.847   x9.598
    a3051.000   z-0.847   x9.643
    a3052.000   z-0.848   x9.687
    a3053.000   z-0.848   x9.732
    a3054.000   z-0.848   x9.777
    a3055.000   z-0.849   x9.821
    a3056.000   z-0.849   x9.866
    a3057.000   z-0.849   x9.911
    a3058.000   z-0.849   x9.955
    a3059.000   z-0.850   x10.000
    a3060.000   z-0.850   x9.955
    a3061.000   z-0.850   x9.911
    a3062.000   z-0.851   x9.866
    a3063.000   z-0.851   x9.821
    a3064.000   z-0.851   x9.777
    a3065.000   z-0.851   x9.732
    a3066.000   z-0.852   x9.687
    a3067.000   z-0.852   x9.643
    a3068.000   z-0.852   x9.598
    a3069.000   z-0.852   x9.553
    a3070.000   z-0.853   x9.509
    a3071.000   z-0.853   x9.464
    a3072.000   z-0.853   x9.419
    a3073.000   z-0.854   x9.375
    a3074.000   z-0.854   x9.330
    a3075.000   z-0.854   x9.285
    a3076.000   z-0.854   x9.241
    a3077.000   z-0.855   x9.196
    a3078.000   z-0.855   x9.151
    a3079.000   z-0.855   x9.107
    a3080.000   z-0.856   x9.062
    a3081.000   z-0.856   x9.018
    a3082.000   z-0.856   x8.973
    a3083.000   z-0.856   x8.928
    a3084.000   z-0.857   x8.884
    a3085.000   z-0.857   x8.839
    a3086.000   z-0.857   x8.794
    a3087.000   z-0.857   x8.750
    a3088.000   z-0.858   x8.705
    a3089.000   z-0.858   x8.660
    a3090.000   z-0.858   x8.705
    a3091.000   z-0.859   x8.750
    a3092.000   z-0.859   x8.794
    a3093.000   z-0.859   x8.839
    a3094.000   z-0.859   x8.884
    a3095.000   z-0.860   x8.928
    a3096.000   z-0.860   x8.973
    a3097.000   z-0.860   x9.018
    a3098.000   z-0.861   x9.062
    a3099.000   z-0.861   x9.107
    a3100.000   z-0.861   x9.151
    a3101.000   z-0.861   x9.196
    a3102.000   z-0.862   x9.241
    a3103.000   z-0.862   x9.285
    a3104.000   z-0.862   x9.330
    a3105.000   z-0.862   x9.375
    a3106.000   z-0.863   x9.419
    a3107.000   z-0.863   x9.464
    a3108.000   z-0.863   x9.509
    a3109.000   z-0.864   x9.553
    a3110.000   z-0.864   x9.598
    a3111.000   z-0.864   x9.643
    a3112.000   z-0.864   x9.687
    a3113.000   z-0.865   x9.732
    a3114.000   z-0.865   x9.777
    a3115.000   z-0.865   x9.821
    a3116.000   z-0.866   x9.866
    a3117.000   z-0.866   x9.911
    a3118.000   z-0.866   x9.955
    a3119.000   z-0.866   x10.000
    a3120.000   z-0.867   x9.955
    a3121.000   z-0.867   x9.911
    a3122.000   z-0.867   x9.866
    a3123.000   z-0.867   x9.821
    a3124.000   z-0.868   x9.777
    a3125.000   z-0.868   x9.732
    a3126.000   z-0.868   x9.687
    a3127.000   z-0.869   x9.643
    a3128.000   z-0.869   x9.598
    a3129.000   z-0.869   x9.553
    a3130.000   z-0.869   x9.509
    a3131.000   z-0.870   x9.464
    a3132.000   z-0.870   x9.419
    a3133.000   z-0.870   x9.375
    a3134.000   z-0.871   x9.330
    a3135.000   z-0.871   x9.285
    a3136.000   z-0.871   x9.241
    a3137.000   z-0.871   x9.196
    a3138.000   z-0.872   x9.151
    a3139.000   z-0.872   x9.107
    a3140.000   z-0.872   x9.062
    a3141.000   z-0.872   x9.018
    a3142.000   z-0.873   x8.973
    a3143.000   z-0.873   x8.928
    a3144.000   z-0.873   x8.884
    a3145.000   z-0.874   x8.839
    a3146.000   z-0.874   x8.794
    a3147.000   z-0.874   x8.750
    a3148.000   z-0.874   x8.705
    a3149.000   z-0.875   x8.660
    a3150.000   z-0.875   x8.705
    a3151.000   z-0.875   x8.750
    a3152.000   z-0.876   x8.794
    a3153.000   z-0.876   x8.839
    a3154.000   z-0.876   x8.884
    a3155.000   z-0.876   x8.928
    a3156.000   z-0.877   x8.973
    a3157.000   z-0.877   x9.018
    a3158.000   z-0.877   x9.062
    a3159.000   z-0.877   x9.107
    a3160.000   z-0.878   x9.151
    a3161.000   z-0.878   x9.196
    a3162.000   z-0.878   x9.241
    a3163.000   z-0.879   x9.285
    a3164.000   z-0.879   x9.330
    a3165.000   z-0.879   x9.375
    a3166.000   z-0.879   x9.419
    a3167.000   z-0.880   x9.464
    a3168.000   z-0.880   x9.509
    a3169.000   z-0.880   x9.553
    a3170.000   z-0.881   x9.598
    a3171.000   z-0.881   x9.643
    a3172.000   z-0.881   x9.687
    a3173.000   z-0.881   x9.732
    a3174.000   z-0.882   x9.777
    a3175.000   z-0.882   x9.821
    a3176.000   z-0.882   x9.866
    a3177.000   z-0.882   x9.911
    a3178.000   z-0.883   x9.955
    a3179.000   z-0.883   x10.000
    a3180.000   z-0.883   x9.955
    a3181.000   z-0.884   x9.911
    a3182.000   z-0.884   x9.866
    a3183.000   z-0.884   x9.821
    a3184.000   z-0.884   x9.777
    a3185.000   z-0.885   x9.732
    a3186.000   z-0.885   x9.687
    a3187.000   z-0.885   x9.643
    a3188.000   z-0.886   x9.598
    a3189.000   z-0.886   x9.553
    a3190.000   z-0.886   x9.509
    a3191.000   z-0.886   x9.464
    a3192.000   z-0.887   x9.419
    a3193.000   z-0.887   x9.375
    a3194.000   z-0.887   x9.330
    a3195.000   z-0.887   x9.285
    a3196.000   z-0.888   x9.241
    a3197.000   z-0.888   x9.196
    a3198.000   z-0.888   x9.151
    a3199.000   z-0.889   x9.107
    a3200.000   z-0.889   x9.062
    a3201.000   z-0.889   x9.018
    a3202.000   z-0.889   x8.973
    a3203.000   z-0.890   x8.928
    a3204.000   z-0.890   x8.884
    a3205.000   z-0.890   x8.839
    a3206.000   z-0.891   x8.794
    a3207.000   z-0.891   x8.750
    a3208.000   z-0.891   x8.705
    a3209.000   z-0.891   x8.660
    a3210.000   z-0.892   x8.705
    a3211.000   z-0.892   x8.750
    a3212.000   z-0.892   x8.794
    a3213.000   z-0.892   x8.839
    a3214.000   z-0.893   x8.884
    a3215.000   z-0.893   x8.928
    a3216.000   z-0.893   x8.973
    a3217.000   z-0.894   x9.018
    a3218.000   z-0.894   x9.062
    a3219.000   z-0.894   x9.107
    a3220.000   z-0.894   x9.151
    a3221.000   z-0.895   x9.196
    a3222.000   z-0.895   x9.241
    a3223.000   z-0.895   x9.285
    a3224.000   z-0.896   x9.330
    a3225.000   z-0.896   x9.375
    a3226.000   z-0.896   x9.419
    a3227.000   z-0.896   x9.464
    a3228.000   z-0.897   x9.509
    a3229.000   z-0.897   x9.553
    a3230.000   z-0.897   x9.598
    a3231.000   z-0.897   x9.643
    a3232.000   z-0.898   x9.687
    a3233.000   z-0.898   x9.732
    a3234.000   z-0.898   x9.777
    a3235.000   z-0.899   x9.821
    a3236.000   z-0.899   x9.866
    a3237.000   z-0.899   x9.911
    a3238.000   z-0.899   x9.955
    a3239.000   z-0.900   x10.000
    a3240.000   z-0.900   x9.955
    a3241.000   z-0.900   x9.911
    a3242.000   z-0.901   x9.866
    a3243.000   z-0.901   x9.821
    a3244.000   z-0.901   x9.777
    a3245.000   z-0.901   x9.732
    a3246.000   z-0.902   x9.687
    a3247.000   z-0.902   x9.643
    a3248.000   z-0.902   x9.598
    a3249.000   z-0.902   x9.553
    a3250.000   z-0.903   x9.509
    a3251.000   z-0.903   x9.464
    a3252.000   z-0.903   x9.419
    a3253.000   z-0.904   x9.375
    a3254.000   z-0.904   x9.330
    a3255.000   z-0.904   x9.285
    a3256.000   z-0.904   x9.241
    a3257.000   z-0.905   x9.196
    a3258.000   z-0.905   x9.151
    a3259.000   z-0.905   x9.107
    a3260.000   z-0.906   x9.062
    a3261.000   z-0.906   x9.018
    a3262.000   z-0.906   x8.973
    a3263.000   z-0.906   x8.928
    a3264.000   z-0.907   x8.884
    a3265.000   z-0.907   x8.839
    a3266.000   z-0.907   x8.794
    a3267.000   z-0.907   x8.750
    a3268.000   z-0.908   x8.705
    a3269.000   z-0.908   x8.660
    a3270.000   z-0.908   x8.705
    a3271.000   z-0.909   x8.750
    a3272.000   z-0.909   x8.794
    a3273.000   z-0.909   x8.839
    a3274.000   z-0.909   x8.884
    a3275.000   z-0.910   x8.928
    a3276.000   z-0.910   x8.973
    a3277.000   z-0.910   x9.018
    a3278.000   z-0.911   x9.062
    a3279.000   z-0.911   x9.107
    a3280.000   z-0.911   x9.151
    a3281.000   z-0.911   x9.196
    a3282.000   z-0.912   x9.241
    a3283.000   z-0.912   x9.285
    a3284.000   z-0.912   x9.330
    a3285.000   z-0.912   x9.375
    a3286.000   z-0.913   x9.419
    a3287.000   z-0.913   x9.464
    a3288.000   z-0.913   x9.509
    a3289.000   z-0.914   x9.553
    a3290.000   z-0.914   x9.598
    a3291.000   z-0.914   x9.643
    a3292.000   z-0.914   x9.687
    a3293.000   z-0.915   x9.732
    a3294.000   z-0.915   x9.777
    a3295.000   z-0.915   x9.821
    a3296.000   z-0.916   x9.866
    a3297.000   z-0.916   x9.911
    a3298.000   z-0.916   x9.955
    a3299.000   z-0.916   x10.000
    a3300.000   z-0.917   x9.955
    a3301.000   z-0.917   x9.911
    a3302.000   z-0.917   x9.866
    a3303.000   z-0.917   x9.821
    a3304.000   z-0.918   x9.777
    a3305.000   z-0.918   x9.732
    a3306.000   z-0.918   x9.687
    a3307.000   z-0.919   x9.643
    a3308.000   z-0.919   x9.598
    a3309.000   z-0.919   x9.553
    a3310.000   z-0.919   x9.509
    a3311.000   z-0.920   x9.464
    a3312.000   z-0.920   x9.419
    a3313.000   z-0.920   x9.375
    a3314.000   z-0.921   x9.330
    a3315.000   z-0.921   x9.285
    a3316.000   z-0.921   x9.241
    a3317.000   z-0.921   x9.196
    a3318.000   z-0.922   x9.151
    a3319.000   z-0.922   x9.107
    a3320.000   z-0.922   x9.062
    a3321.000   z-0.922   x9.018
    a3322.000   z-0.923   x8.973
    a3323.000   z-0.923   x8.928
    a3324.000   z-0.923   x8.884
    a3325.000   z-0.924   x8.839
    a3326.000   z-0.924   x8.794
    a3327.000   z-0.924   x8.750
    a3328.000   z-0.924   x8.705
    a3329.000   z-0.925   x8.660
    a3330.000   z-0.925   x8.705
    a3331.000   z-0.925   x8.750
    a3332.000   z-0.926   x8.794
    a3333.000   z-0.926   x8.839
    a3334.000   z-0.926   x8.884
    a3335.000   z-0.926   x8.928
    a3336.000   z-0.927   x8.973
    a3337.000   z-0.927   x9.018
    a3338.000   z-0.927   x9.062
    a3339.000   z-0.927   x9.107
    a3340.000   z-0.928   x9.151
    a3341.000   z-0.928   x9.196
    a3342.000   z-0.928   x9.241
    a3343.000   z-0.929   x9.285
    a3344.000   z-0.929   x9.330
    a3345.000   z-0.929   x9.375
    a3346.000   z-0.929   x9.419
    a3347.000   z-0.930   x9.464
    a3348.000   z-0.930   x9.509
    a3349.000   z-0.930   x9.553
    a3350.000   z-0.931   x9.598
    a3351.000   z-0.931   x9.643
    a3352.000   z-0.931   x9.687
    a3353.000   z-0.931   x9.732
    a3354.000   z-0.932   x9.777
    a3355.000   z-0.932   x9.821
    a3356.000   z-0.932   x9.866
    a3357.000   z-0.932   x9.911
    a3358.000   z-0.933   x9.955
    a3359.000   z-0.933   x10.000
    a3360.000   z-0.933   x9.955
    a3361.000   z-0.934   x9.911
    a3362.000   z-0.934   x9.866
    a3363.000   z-0.934   x9.821
    a3364.000   z-0.934   x9.777
    a3365.000   z-0.935   x9.732
    a3366.000   z-0.935   x9.687
    a3367.000   z-0.935   x9.643
    a3368.000   z-0.936   x9.598
    a3369.000   z-0.936   x9.553
    a3370.000   z-0.936   x9.509
    a3371.000   z-0.936   x9.464
    a3372.000   z-0.937   x9.419
    a3373.000   z-0.937   x9.375
    a3374.000   z-0.937   x9.330
    a3375.000   z-0.937   x9.285
    a3376.000   z-0.938   x9.241
    a3377.000   z-0.938   x9.196
    a3378.000   z-0.938   x9.151
    a3379.000   z-0.939   x9.107
    a3380.000   z-0.939   x9.062
    a3381.000   z-0.939   x9.018
    a3382.000   z-0.939   x8.973
    a3383.000   z-0.940   x8.928
    a3384.000   z-0.940   x8.884
    a3385.000   z-0.940   x8.839
    a3386.000   z-0.941   x8.794
    a3387.000   z-0.941   x8.750
    a3388.000   z-0.941   x8.705
    a3389.000   z-0.941   x8.660
    a3390.000   z-0.942   x8.705
    a3391.000   z-0.942   x8.750
    a3392.000   z-0.942   x8.794
    a3393.000   z-0.942   x8.839
    a3394.000   z-0.943   x8.884
    a3395.000   z-0.943   x8.928
    a3396.000   z-0.943   x8.973
    a3397.000   z-0.944   x9.018
    a3398.000   z-0.944   x9.062
    a3399.000   z-0.944   x9.107
    a3400.000   z-0.944   x9.151
    a3401.000   z-0.945   x9.196
    a3402.000   z-0.945   x9.241
    a3403.000   z-0.945   x9.285
    a3404.000   z-0.946   x9.330
    a3405.000   z-0.946   x9.375
    a3406.000   z-0.946   x9.419
    a3407.000   z-0.946   x9.464
    a3408.000   z-0.947   x9.509
    a3409.000   z-0.947   x9.553
    a3410.000   z-0.947   x9.598
    a3411.000   z-0.947   x9.643
    a3412.000   z-0.948   x9.687
    a3413.000   z-0.948   x9.732
    a3414.000   z-0.948   x9.777
    a3415.000   z-0.949   x9.821
    a3416.000   z-0.949   x9.866
    a3417.000   z-0.949   x9.911
    a3418.000   z-0.949   x9.955
    a3419.000   z-0.950   x10.000
    a3420.000   z-0.950   x9.955
    a3421.000   z-0.950   x9.911
    a3422.000   z-0.951   x9.866
    a3423.000   z-0.951   x9.821
    a3424.000   z-0.951   x9.777
    a3425.000   z-0.951   x9.732
    a3426.000   z-0.952   x9.687
    a3427.000   z-0.952   x9.643
    a3428.000   z-0.952   x9.598
    a3429.000   z-0.952   x9.553
    a3430.000   z-0.953   x9.509
    a3431.000   z-0.953   x9.464
    a3432.000   z-0.953   x9.419
    a3433.000   z-0.954   x9.375
    a3434.000   z-0.954   x9.330
    a3435.000   z-0.954   x9.285
    a3436.000   z-0.954   x9.241
    a3437.000   z-0.955   x9.196
    a3438.000   z-0.955   x9.151
    a3439.000   z-0.955   x9.107
    a3440.000   z-0.956   x9.062
    a3441.000   z-0.956   x9.018
    a3442.000   z-0.956   x8.973
    a3443.000   z-0.956   x8.928
    a3444.000   z-0.957   x8.884
    a3445.000   z-0.957   x8.839
    a3446.000   z-0.957   x8.794
    a3447.000   z-0.957   x8.750
    a3448.000   z-0.958   x8.705
    a3449.000   z-0.958   x8.660
    a3450.000   z-0.958   x8.705
    a3451.000   z-0.959   x8.750
    a3452.000   z-0.959   x8.794
    a3453.000   z-0.959   x8.839
    a3454.000   z-0.959   x8.884
    a3455.000   z-0.960   x8.928
    a3456.000   z-0.960   x8.973
    a3457.000   z-0.960   x9.018
    a3458.000   z-0.961   x9.062
    a3459.000   z-0.961   x9.107
    a3460.000   z-0.961   x9.151
    a3461.000   z-0.961   x9.196
    a3462.000   z-0.962   x9.241
    a3463.000   z-0.962   x9.285
    a3464.000   z-0.962   x9.330
    a3465.000   z-0.962   x9.375
    a3466.000   z-0.963   x9.419
    a3467.000   z-0.963   x9.464
    a3468.000   z-0.963   x9.509
    a3469.000   z-0.964   x9.553
    a3470.000   z-0.964   x9.598
    a3471.000   z-0.964   x9.643
    a3472.000   z-0.964   x9.687
    a3473.000   z-0.965   x9.732
    a3474.000   z-0.965   x9.777
    a3475.000   z-0.965   x9.821
    a3476.000   z-0.966   x9.866
    a3477.000   z-0.966   x9.911
    a3478.000   z-0.966   x9.955
    a3479.000   z-0.966   x10.000
    a3480.000   z-0.967   x9.955
    a3481.000   z-0.967   x9.911
    a3482.000   z-0.967   x9.866
    a3483.000   z-0.967   x9.821
    a3484.000   z-0.968   x9.777
    a3485.000   z-0.968   x9.732
    a3486.000   z-0.968   x9.687
    a3487.000   z-0.969   x9.643
    a3488.000   z-0.969   x9.598
    a3489.000   z-0.969   x9.553
    a3490.000   z-0.969   x9.509
    a3491.000   z-0.970   x9.464
    a3492.000   z-0.970   x9.419
    a3493.000   z-0.970   x9.375
    a3494.000   z-0.971   x9.330
    a3495.000   z-0.971   x9.285
    a3496.000   z-0.971   x9.241
    a3497.000   z-0.971   x9.196
    a3498.000   z-0.972   x9.151
    a3499.000   z-0.972   x9.107
    a3500.000   z-0.972   x9.062
    a3501.000   z-0.972   x9.018
    a3502.000   z-0.973   x8.973
    a3503.000   z-0.973   x8.928
    a3504.000   z-0.973   x8.884
    a3505.000   z-0.974   x8.839
    a3506.000   z-0.974   x8.794
    a3507.000   z-0.974   x8.750
    a3508.000   z-0.974   x8.705
    a3509.000   z-0.975   x8.660
    a3510.000   z-0.975   x8.705
    a3511.000   z-0.975   x8.750
    a3512.000   z-0.976   x8.794
    a3513.000   z-0.976   x8.839
    a3514.000   z-0.976   x8.884
    a3515.000   z-0.976   x8.928
    a3516.000   z-0.977   x8.973
    a3517.000   z-0.977   x9.018
    a3518.000   z-0.977   x9.062
    a3519.000   z-0.977   x9.107
    a3520.000   z-0.978   x9.151
    a3521.000   z-0.978   x9.196
    a3522.000   z-0.978   x9.241
    a3523.000   z-0.979   x9.285
    a3524.000   z-0.979   x9.330
    a3525.000   z-0.979   x9.375
    a3526.000   z-0.979   x9.419
    a3527.000   z-0.980   x9.464
    a3528.000   z-0.980   x9.509
    a3529.000   z-0.980   x9.553
    a3530.000   z-0.981   x9.598
    a3531.000   z-0.981   x9.643
    a3532.000   z-0.981   x9.687
    a3533.000   z-0.981   x9.732
    a3534.000   z-0.982   x9.777
    a3535.000   z-0.982   x9.821
    a3536.000   z-0.982   x9.866
    a3537.000   z-0.982   x9.911
    a3538.000   z-0.983   x9.955
    a3539.000   z-0.983   x10.000
    a3540.000   z-0.983   x9.955
    a3541.000   z-0.984   x9.911
    a3542.000   z-0.984   x9.866
    a3543.000   z-0.984   x9.821
    a3544.000   z-0.984   x9.777
    a3545.000   z-0.985   x9.732
    a3546.000   z-0.985   x9.687
    a3547.000   z-0.985   x9.643
    a3548.000   z-0.986   x9.598
    a3549.000   z-0.986   x9.553
    a3550.000   z-0.986   x9.509
    a3551.000   z-0.986   x9.464
    a3552.000   z-0.987   x9.419
    a3553.000   z-0.987   x9.375
    a3554.000   z-0.987   x9.330
    a3555.000   z-0.987   x9.285
    a3556.000   z-0.988   x9.241
    a3557.000   z-0.988   x9.196
    a3558.000   z-0.988   x9.151
    a3559.000   z-0.989   x9.107
    a3560.000   z-0.989   x9.062
    a3561.000   z-0.989   x9.018
    a3562.000   z-0.989   x8.973
    a3563.000   z-0.990   x8.928
    a3564.000   z-0.990   x8.884
    a3565.000   z-0.990   x8.839
    a3566.000   z-0.991   x8.794
    a3567.000   z-0.991   x8.750
    a3568.000   z-0.991   x8.705
    a3569.000   z-0.991   x8.660
    a3570.000   z-0.992   x8.705
    a3571.000   z-0.992   x8.750
    a3572.000   z-0.992   x8.794
    a3573.000   z-0.992   x8.839
    a3574.000   z-0.993   x8.884
    a3575.000   z-0.993   x8.928
    a3576.000   z-0.993   x8.973
    a3577.000   z-0.994   x9.018
    a3578.000   z-0.994   x9.062
    a3579.000   z-0.994   x9.107
    a3580.000   z-0.994   x9.151
    a3581.000   z-0.995   x9.196
    a3582.000   z-0.995   x9.241
    a3583.000   z-0.995   x9.285
    a3584.000   z-0.996   x9.330
    a3585.000   z-0.996   x9.375
    a3586.000   z-0.996   x9.419
    a3587.000   z-0.996   x9.464
    a3588.000   z-0.997   x9.509
    a3589.000   z-0.997   x9.553
    a3590.000   z-0.997   x9.598
    a3591.000   z-0.997   x9.643
    a3592.000   z-0.998   x9.687
    a3593.000   z-0.998   x9.732
    a3594.000   z-0.998   x9.777
    a3595.000   z-0.999   x9.821
    a3596.000   z-0.999   x9.866
    a3597.000   z-0.999   x9.911
    a3598.000   z-0.999   x9.955
    a3599.000   z-1.000   x10.000
    a3600.000   z-1.000   x9.955
Turning Hexagon on 2 axis Lathe
