Don't under stand what you are trying to do, with using G18, if you are just cutting an arc G17 X Y plane then you would not use a G18, if your work plane is using a G17 then your arc on arc off you would be using a G17 may be these snips will help you figure out what you want to do, you can not arc on arc off with a G18 or a G19 if your work plane is X and Y G17
