This can be done, I use a "Main Program" (it controls the offset) and a "Sub Program" (it controls the tool path)
O2120 (MAIN PROGRAM)
G10 P0 X0.0 Z0.0 [SETS WORK OFFSET TO ZERO]
G65 P2121 L1 [RUNS SUB PROGRAM]
G10 P0 X0.0 Z0.450 [SETS WORK OFFSET IN TO 0.450] {THIS MAY BE NEGATIVE ON YOUR CONTROLLER}
G10 P0 X0.0 Z0.900 [SETS WORK OFFSET IN TO 0.900]
REPEAT AS MANY TIMES AS YOU LIKE
G10 P0 X0.0 Z0.0 [SET WORK OFFSET BACK TO ZERO] {I DO THIS AT THE END FOR SAFETY}
G28 U0.0
M30
O2121 (SUB PROGRAM)
(1" MATERIAL)
(1.7" ON PULL STICK)
(20.125" SAW CUT)
G20 G40
(0.087 WIDE PART OFF)
T1111
G99
G50 S2000
G96 S8000 M03
M08
G00 X1.05
G00 Z-0.430
G01 X-0.05 F0.008
G50 S25
M09
T0000
G28 U0.0
M18
M99
Hope this helps.
Tony
