Hi Mactec54
I have a mate coming over tues he is a sparky and has all the gear to test it
after testing will go from there
Karl
Ok none of this may be causing your problem, but you will have to check all your voltages, the VFD if the voltage was to high it would fault so that part should be ok, checking for noise plug in an old TV near you cabinet or machine and see how the screen reacts, you will see the noise on the screen if there is any, this saves buying a meter to check for EMF / EMI
So this leaves the drives and the low voltage to check
The motion card check that you have 24v, this can not be more than the 24v
Then check your drives to see that the voltage in within there spec, usually they can be with in 15% to 20% of spec
Mactec54
Hi Mactec54
Karl
Hi Guys
After checking everything voltages cables it was the Rapid FRO% setting i reduced it from 100% to 15% and returned the motors settings back to how they were and it worked perfect i just have to set the Rapid FRO% before i start each job
Thanks again your help got me on the right path it was a speed issue
Karl
That means your velocity setting is too high. Rapid Override should be at 100%, and your velocity settings in motor tuning should be 15% of what you have them set to.
UCCNC 2017 Screenset
Ok i will reduce the velocity down to 15% and see how that goes with the rapid FRO% at 100
Karl
