Need Help! G76 - cutting threads in one pass.
Results 1 to 7 of 7
Thread: G76 - cutting threads in one pass.
    Jan 2005
    Default G76 - cutting threads in one pass.
    Got some internal threads that I'm wanting to chase after being re-bored.
    Threads cycle is thus:
    G76P020055Q10R0.001
    G76X0.375Z-0.490P135Q40F0.0250R0
    To cut them in one pass for chasing, I'm using:
    G76P000055Q10R0
    G76X0.375Z-0.490P135Q135F0.0250R0
    It's cutting two passes as full depth, rather than one. Where am I screwing up here?
    Thanks.
    Gold Member dcoupar's Avatar
    Mar 2003
    Default Re: G76 - cutting threads in one pass.
    G'day, Mate.
    Please check the value of parameter 5142... should be 0.
    What happens if you change Q135 to Q140? (Try it away from the part please).
    I know that I've done this successfully on older controls, but I may not have done it on the 0iTD.
    Dave
    Mar 2003
    Well, I'm a little confused at this point. According to the 0iT-D Lathe Operator's manual, the value of the first two digits in the P000055 range from 1 to 99. It also says that the value is stored in prm 5142.
    Let's try P010055, and in both blocks make the Q135... again, away from the part.
    Jan 2005
    OK, so as per above:
    G76P010055Q135R0
    Cuts two passes at 0.375"
    When I change Q135 to Q140 it cuts 3 passes. One at 0.374" and two at 0.375".
    When I go into the settings, my parameters jump from 5011 to 5213. So I'm obviously not looking in the right area?
    I'm using the settings area - where one also has G54 and parts count setting?
    cheers
    Jan 2005
    Using the System button on keypad (I can't believe I missed that!), went into setting 5142 (G76 FINISHING REPETITION), this is currently set to "1".
    I went into Handy page, and changed settings to write enable (while in MDI) and tried to changing the parameter to zero to see what that would do. It allows the input of "0", but it still cuts 2 passes. When I go back into the parameter, it's changed itself back to 1!
    Gold Member
    Feb 2006
    india
    Quote Originally Posted by dcoupar View Post
    ... the value of the first two digits in the P000055 range from 1 to 99...
    That is correct, and because of this reason, I think two passes would always be there.
  7. #7
    Mar 2003
    Mike,
    Maybe I'm imagining things, but I could swear I've done this successfully... maybe not.
    Is this issue keeping you from making parts?
    You might want to post this on the Daewoo/Doosan forum. They have a couple of really smart guys monitoring and answering questions.
